Replacing the Stock Subwoofer
Old Sep 16, 2015 | 03:07 PM
akbears15's Avatar
I'm new to this forum and i'm just looking for some help. I drive a 2004 Tl completely stock. Recently i was foolish and blew out the factory sub woofer. I had the bass and sub woofer turned up to +6 so it really is no surprise especially since it is a stock system from 2004. Anyways, I've been doing some research but is it possible to use an aftermarket sub in the stock housing above the rear seats in the TL. If not, do i have to get a housing in the trunk of my car in order to do the replacement?
Again, really new at this so bare with me but I am trying to do a complete audio upgrade from head unit to tweeters, door speakers, etc i just need some advice and help getting there so any feedback is great
Old Sep 16, 2015 | 06:24 PM
polish_pat's Avatar
You can install aftermarket parts. Check in the TL garage here https://acurazine.com/forums/third-g...ewbies-553554/
Some threads: https://acurazine.com/forums/audio-b...system-570204/
https://acurazine.com/forums/audio-b...s-shut-700991/
Old Sep 17, 2015 | 02:28 PM
sockr1's Avatar
i'm selling my stock subwoofer if interested. it's fully functional and not blown. this is from a 2008 type s
https://acurazine.com/forums/car-par...-parts-935958/
Old Oct 11, 2015 | 05:38 PM
DBConz's Avatar
Registered Idiot
so i just took my sub out and it's blown.
what are you guys getting to replace your OEM sub?
not looking to change the amp, just replace it with a better quality speaker.
Old Oct 15, 2015 | 01:42 AM
pohljm's Avatar
there isnt any, and if there were it would just compound the problems inherent with the location. replace with stock or do something worthwhile.
Old Oct 17, 2015 | 10:10 PM
cprime's Avatar
I've seen on a few threads that many have replaced their woofer with a JL 8w3v2. I don't think you can find these anymore though, I've only found some v3 which don't fit without having to do some metal cutting.
I think mine is blown, so I'm looking to get another. Since the space is limited, I was thinking of getting a shallow sub but will any shallow 8" sub fit?
Old Oct 22, 2015 | 09:07 PM
stevemk07's Avatar
Basically nobody does that so you will have to do your own research on mounting specs. If you can get rid of the rattles back there and reinforce the structure a bit and perhaps seal up the area around the sub a bit it may be worth it... hard to say though. Easy solution is to put a box in the trunk. You don't need a big sub and subs mounted in the corner of the car/trunk sound good in our vehicles. I have mine facing towards the front directly behind me (driver seat).
Old Oct 22, 2015 | 09:16 PM
cprime's Avatar
Thanks for the input. I'd rather not put a box in the trunk to keep as much space as possible. I had one in my previous car and a few times I would have wanted not to have one. I might end up with one, but like I said, I would rather not if possible.
Old Oct 22, 2015 | 09:23 PM
stevemk07's Avatar
Look in to infinite baffle then. Probably about the same amount of work as putting something decent in the stock sub location and will yield better results due to being able to fit up to 2 15" Subs and require relatively little power.
Old Oct 24, 2015 | 12:26 PM
cprime's Avatar
That's something I looked at quickly too since I saw some threads about them. I'll have to look more into it.
Old Oct 25, 2015 | 12:50 PM
cprime's Avatar
Any model in particular? I'm not looking for the top of the line one, just something to improve the original system.
Old Oct 26, 2015 | 11:00 PM
stevemk07's Avatar
Search the numerous threads on the subject for some ideas... My guess is any subwoofer will sound pretty decent, even the cheap ones.
Old Oct 29, 2015 | 07:12 PM
QuickTL07's Avatar
you need to look in to IB sub-woofer, that could do good in free air application. Sub needs to be specific to its component,
Old Oct 29, 2015 | 09:29 PM
pohljm's Avatar
even a cheap 15" Pyle Blue Wave
Old Oct 30, 2015 | 07:28 AM
cprime's Avatar
Yeah that's one of the subs I'm looking at right now.
Old Nov 5, 2015 | 07:06 AM
QuickTL07's Avatar
Make sure everything is sealed off from the trunk to the cabin. If not, you wont get the same response of bass that you might be looking for, or had with stock subwoofer.... I have pulled mine out all the the way
AndrewS
19
Mar 14, 2024 06:59 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
sockr1
Oct 1, 2015 01:31 AM
HOWELLiNC
3G TL Photograph Gallery
Sep 17, 2015 10:04 PM
yahelou
Sep 6, 2015 09:12 PM
