Fuse Tap!
Old Jul 1, 2012 | 08:28 PM
Japs08's Avatar
Question Fuse Tap!
Hello, I have a question for all expert out there. I just completed hard wiring my Escort Solo S2 and tapped it into the radio fuse. My question is, do I have to power the radar on & off each time I start the car or is there any other way? BTW, I don't have a switch hook up. Thanks for your response in advance!
Old Jul 1, 2012 | 08:35 PM
SharksBreath's Avatar
BANNED
what number is the radio fuse?
I would tap into #32 (the ACC fuse). your radar will turn on automatically when you start the car and shut off when you turn off the car.
like this...
http://kadakia.com/2008/02/valentine...07-acura-tl-s/
Old Jul 1, 2012 | 08:37 PM
Dsrtne1's Avatar
+1 This is what I did with my Passport 8500 and it works perfectly
Old Jul 1, 2012 | 08:38 PM
Japs08's Avatar
Radio Fuse #20
Old Jul 1, 2012 | 08:52 PM
wilztlxs's Avatar
TLX-S
Since the Solo S2 is a battery operated detector, yes, you will need to power it on manually every time you get in the car. It will turn off when you turn the car off.
I have the Solo S2 hardwired in my wife's Mecedes and it has to be turned on each time after she starts the car.
Old Jul 1, 2012 | 09:01 PM
Japs08's Avatar
Thanks for your response!
When I turned the ignition off and pulled the key out the radar was still on.
Old Jul 1, 2012 | 09:09 PM
Azndjay's Avatar
MV612
you should hardwire to roof console better..
https://acurazine.com/forums/3g-tl-2004-2008-93/how-remove-overhead-console-556355/
Old Jul 1, 2012 | 10:21 PM
wilztlxs's Avatar
TLX-S
try tapping the #32 (the ACC fuse) instead
Acura604
20
Aug 5, 2017 12:55 AM
soupi
14
Nov 15, 2015 11:15 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
ripit
Sep 26, 2015 06:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
