Compustar remote starter install DIY on 2008 5AT TL
Old Dec 22, 2019 | 07:09 PM
peter6's Avatar
I decided that I will get a remote starter for my car. However, because I’ve seen how some shops install them, I decided that I don’t want to pay $100 (or whatever) to somebody else if I can do the job.
From short and lazy research, I decided to go with Compustar remote starter. Seems like a nice unit, has decent manual, and can be upgraded. Time will tell if that was a good choice or not.
I went to https://compustar.idatalink.com/prod...product_id/686 and selected my car (2008 TL auto). If you press on “Download guide” you will get a nice pdf with install info. It should be the same for 2004-2008 auto TLs. No idea if works on manuals and I didn’t bother to check. Guide more or less will apply to most Honda vehicles that use ADS-THR-HA2 wiring harness. General guides for the unit contain error codes and other troubleshooting tips so it’s nice to have one as well.
Here are pdfs if for some reason you can’t find them:
https://www.dropbox.com/sh/hjbabshig...f91K6CGca?dl=0
Parts list:
- Remote starter “brain” - FT-DC3-LC, also called “CM-DC3” - ~$100 on Amazon
- ADS-THR-HA2 – wiring harness – makes install much easier and cleaner - ~$30 from bestbuy
- iDatalink ADS-USB – required to flash (and later update) remote starter - $32 from ebay
- Compustar RF-2WG15-FM – 2 way remote with lock/unlock/trunk buttons. ~$85 from ebay. Technically you can select any remote you want, as long as it’s compatible with “brain”. You can also go without remotes, and use factory OEM remote to start the car (3x lock function), but since factory remote has limited range, I recommend getting something extra. “2 way” means that remote will confirm if car has started. 1 way are cheaper, but if you don’t see the car, you have no idea if it started (if you were in range). I got two remotes and only one remote is “2 way”.
And since you will have an USB cable to update the “brain” you can… well, update it if needed, without the shop. You can also change some settings if you want. A lot of freedom for $32.
This “brain” also supports additional alarm system. I won’t use it now, maybe in the future. Just something to keep in mind when comparing options.
Flashing the correct firmware on the remote starter module.
Spoiler
Installing the remote starter.
Spoiler
Since there are many different remotes, installing remote is separate section.
Spoiler
At this point go through testing at pages 8 and 9 of Acura specific manual.
Since everything works good it’s time to actually put the wires where they should be. For wires running close to body or panels, I wrapped them with wiring harness tape (like one here:
Amazon Amazon
). It’s a fabric tape that will muffle any noise from wires moving around. Zipties are also recommended. I learned that trick when doing my Nexus 7 install and later having all kinds of noises when hitting bumps.
From positive things, it had enough range to start from my apartment (3rd floor and maybe 1000 ft, car not in sight). It will confirm locking and starting if you have a 2 way remote. If you have KP window roll-up module, it will still work with Compustar remote. Acura’s window roll down will NOT work with Compustar remote. Maybe it can be wired to aux functions, but I won't bother today.
From bad things, despite changing unlock pulse to “1” it still unlocks all the door. And despite turning OFF blue LED for the antenna it will still flash (following red light at driver’s door). If you want to update / change settings later, module won't connect with computer. You either need to disconnect the wires from the module, or take car's battery cable off.
I didn’t connect horn and that’s fine. I didn't test if factory alarm still works, but it should. I will let you know if it doesn't. I turned parking lights OFF in settings and they are OFF when car is running. Only DRLs are ON and they look pretty sweet from some distance.
If I ran into some major issues I will update this thread. Overall it took me around 2h to install it in the car. Maybe 20 minutes to flash the module.
Old Dec 22, 2019 | 08:23 PM
Good job, Peter!
Old Dec 22, 2019 | 09:51 PM
vpasla1's Avatar
Great guide! Definitely gives me some confidence to look into it for myself. I'm looking forward to an update in a couple of months.
Old Dec 27, 2019 | 07:08 PM
peter6's Avatar
After some testing it seems like factory alarm is completely disabled. When "armed" red door security light will blink normally, but if I pull lock knob on the door and open them, car will just unlock as using remote.
To solve that, connection to the horn wire will need to be made (or you will need to install separate siren). You can get to that wire right behind the steering wheel, but since I put everything back together I used other spot.
More info in the spoiler:
Spoiler
Old Dec 30, 2019 | 12:01 PM
capper's Avatar
I think BestBuy sometimes runs a special for $250 for remote start and installation. Not bad!
Old Jul 4, 2020 | 07:00 PM
SexieWASD's Avatar
Just installed mine today. The orange door lock wire seamed a bit short to run down to the fuse box connector. For anyone else doing this, That wire connects to the B-Can bus. The light green wire or the back of the wiper switch is also a B-Can wire and works just the same but is much closer.
Old Dec 16, 2020 | 05:27 PM
YJLTG-TLS's Avatar
How did you guys get successfully registered for software flashing access on the idatalink website?
There are six options, Car Dealership, 12volt Expeditor, 12volt Distributor, Freelance Installer, 12volt Retailler, and OEM Manufactrer.
Then there is the giant box going over how you must be a certified installer etc.
I am more than confident in my ability to wire it (although I will be using the t-harness) and install it as I have installed at least half a dozen other remote starts before but never a FirstTech product.
Any caveats or tips on it or do they just let anyone register no matter what?
Old Dec 16, 2020 | 05:35 PM
SexieWASD's Avatar
I work in a shop as a technician specializing in 12v diagnostics, so I was able to register. They do NOT just let anyone register, however I do remember being able to flash via usb just fine without registering, The only thing I had to register for was to get my op500 firmware to update to work with the dc3. However that is more something that I needed for working on customers vehicles more so than my own, as USB flashing worked fine already.
Old Dec 16, 2020 | 05:36 PM
peter6's Avatar
I think I picked commercial address and car dealership and put some fake info (like 123A Streeeeett Ave.) and it went through. Just try whatever, and if it doesn't work then clear cookies and try on different email.
Or give them some random company's address or small local dealership.
Old Dec 16, 2020 | 06:25 PM
YJLTG-TLS's Avatar
Thanks for the quick reply was afraid to try it without knowing.
By chance would you know if the OEM acura remote unlocks doors while it is remotely started? I know from reading around here, on a lot of older remote starters including compustar+blade al integrations it seemed that the Honda remote receiver/immobilizer received a 12 volt on ignition position signal that disabled the remote functions. Looking at a couple of DC3 installs (but using HA3+ harnesses because they are newer vehicles) it seems to work. Im curious if the DC3 interprets this and works around it or if it still behaves the same way on the 3G TL's. Depending on whether it does or not will probably determine what kind of 2 way remote/interface I get for the winter. For the summer months, I was hoping to just hang on to the OEM remote and use the 3x lock to have it run for a minute or so walking up to it which is probably fine for warmer months, winter months I would carry the 2 way remote or subscribe to the drone LTE service.
Last edited by YJLTG-TLS; Dec 16, 2020 at 06:30 PM. Reason: clarification on differences between new and old
Old Dec 16, 2020 | 08:54 PM
YJLTG-TLS's Avatar
From what i have researched and found online all the possible options on the DC3 can be programmed through usb and the OP500 is only required for the 7000+ units, correct?
Old Dec 17, 2020 | 12:43 AM
SexieWASD's Avatar
Correct, you DO NOT need the op500 for this install.
Old Jan 1, 2021 | 06:34 PM
YJLTG-TLS's Avatar
Installed mine sucesfully. Hardest and most time consuming part was wrapping up the cables and grabbing the yellow cable from the OEM keyless module.
You will need the two wires from the M5 connector for OEM remote operation after its remote started as the install manual notes. After you takeover the remote start it does disable the keyless module just like oem so an accidental press doesn't open your trunk while going 75 mph down the highway.
Important note on M5 Connector: When you cut the yellow wire make sure the Grey/Red wire goes on the vehicle/harness side and the Grey/Black wire goes to the keyless module connector side. Other wise it won't ever disable the module even after takeover.
Also kept the alarm option on the DC3 disabled since in primarily using the OEM remote and tested it and the car alarm still functions/honks when triggered.
Old Jan 1, 2021 | 07:40 PM
peter6's Avatar
Maybe they did some update since I installed mine. Initially when I left alarm option disabled, I could lock the car with the remote, have red light at driver's door blinking, and then I could just pull on the lock and open the door, and nothing would happen. Opening the trunk or hood wouldn't trigger alarm as well.
Old Jan 1, 2021 | 11:36 PM
YJLTG-TLS's Avatar
Maybe, it may also be because I'm using the OEM remote so it still arms the factory alarm where using the Compustar may lock the doors but want to/assume the DC3 is being armed.
If you have time I would be curious if you could check yours for an update. I will check my version tomorrow and post it.
I am having two issues,
The car doesn't lock after remote starting, weirdly when testing after disconnecting and reconnecting the battery it started locking and would automatically rearm after cancelling until I unplugged it to move wires around more recently.
Secondly, although minor, the window power accessory delay remains on for the normal key off no door open timing of ten minutes when cancelling/shutting down a remote start. < This one I could care less about since it uses tiny amounts of power for the illumination lights in the switches.
Old Jan 2, 2021 | 07:01 PM
YJLTG-TLS's Avatar
I am running Version 2.7 on the firmware flash and 3.3 on the decoder (pretty sure this is just what they call the immobilizer controller).
The lock issue was fixed consistently, by changing "Lock After Start" to enable as it is disabled by default.
Old Jan 2, 2021 | 09:25 PM
peter6's Avatar
I'm afraid that in order to check or update my unit I would need to disconnect everything and get is out of the car. One thing I learned from Windows is that if everything works fine, don't bother with updates. From my old screenshots, I'm running 2.7 and 3.2 respectively (vs yours 2.7 and 3.3). Update to the immobilizer unit probably won't do much.
I left my "Lock after start" to keep previous state - if car was locked before, lock it again, if unlocked then keep unlocked. I didn't really check any remote start cancel behavior as I didn't plan on it.
Old Jan 2, 2021 | 10:24 PM
YJLTG-TLS's Avatar
Can I ask where you found the keep previous state option? that's what I would prefer but I can't seem to locate it.
And that's true, if it works fine for you I agree it's not worth pulling it for an immo update.
Old Jan 3, 2021 | 10:22 AM
peter6's Avatar
It was just one of the options. If I remember correctly there were three options, to keep unlocked, lock, and keep previous state. I just checked and my car does exactly that. I can't access settings without taking the module out and connecting it to the computer. I don't think they would remove it, so go slowly through every option and maybe you will find it.
Old Mar 31, 2022 | 06:34 PM
KingTiger101's Avatar
4th Gear
As someone with ZERO car electronics experience looking to do this, did you need any kind of specialty tools to do this using the T harness? I have a soldering iron, some snips, and electrical tape but nothing else... Also for anyone looking to do this in 2022, the remote used is no longer available online without paying a ton extra for an LTE module, but the RF-2WR3-FM seems to be a cheaper replacement.
Stuff like this seems very intimidating imo, but sounds worth it.
Old Apr 2, 2022 | 12:55 PM
YJLTG-TLS's Avatar
If you have the basics for car electronics wiring then yes you will be fine, for full integrations you do want cut and splice the wire for the keyless module to still give you OEM remote control while remote started (otherwise it wont respond when ignition is on) however it works like factory, after you take over the remote start the remote is disabled again.
AZTLS08
Jan 30, 2015 09:50 PM
moreace
New England
Jan 5, 2015 11:36 AM
mp3coupe
Apr 4, 2003 05:38 PM
YuppieCL
Feb 2, 2003 07:43 PM
