Bluetooth Stopped Working on '07 TL-S
Old 10-24-2016, 07:49 AM
emas's Avatar
The steering wheel Bluetooth phone activation stopped working. Not sure it helps in diagnosing but happened that day after driving through severe rains and flooding.
Would appreciate any assistance pointing me in the direction of diagnosing and repairing.
Thank you.
Old 10-25-2016, 01:07 AM
Registered but harmless
Will Y.'s Avatar
Received 1,102 Likes on 763 Posts
Thank you.
Check the HFL status using the MID-- if it says "Booting Up" after you've had the car running for more than a few minutes, the HFL is bad.
Otherwise, check the HFL operation-- is it working?
If not, disconnect the battery for a few minutes and reconnect (make sure you have the radio and Navi codes, as you'll need to reenter them); then check HFL operation.
EvilVirus (10-26-2016)
Old 10-25-2016, 09:55 AM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
for repair, check this thread and search for godin technologies. it gave my unit 8 more months of life before it died again.
https://acurazine.com/forums/3g-tl-a...792642/page23/
if it is dead or does eventually die, make sure to unhook it right away. i thought i was special and didn't unhook mine, and a week later my battery was dead (it was a brand new battery). make sure you unhook it. i ended up buying a $20 bluetooth unit on amazon and it works great using the OEM 3.5mm jack to play out of my car speakers for phone calls.
eastcoastguy's Avatar
Probably doesnt matter what weather you were driving in, sounds like the Bluetooth just decided to go out, very common problem and will need to be replaced.
Old 10-26-2016, 09:31 AM
emas's Avatar
You are correct... suggestions on best place to buy one?
Old 10-26-2016, 09:32 AM
Received 8,611 Likes on 6,650 Posts
Acura Parts | OEM Acura Parts | Factory Acura Parts
Acura Parts | Genuine Acura OEM Parts | Acura Parts Cheap
Old 10-26-2016, 10:18 AM
Former Sponsor
ExcelerateRep's Avatar
I would troubleshoot first by unpairing device then repair it. Also is the phone new? on certain cars or phones there are software updates. Scan the car at a dealer. Is bluetooth not even recognized?
Old 10-27-2016, 10:41 AM
imakeholesinu's Avatar
https://www.amazon.com/BLUETOOTH-200...ands+Free+Link
Damn those prices are insane! I bought my new one for half of this just a few months ago from amazon.
Old 10-27-2016, 12:29 PM
Dont forget there is now a core charge included in the cost that gets refunded when you send in your old unit. They are still about the same price.
Old 10-27-2016, 03:48 PM
There is a core charge for a bluetooth unit?
Old 10-28-2016, 07:40 AM
ronricks's Avatar
Yep. Mine went out a few weeks ago. Sucks but I use it a lot and is one of the big features of the car. I went ahead and had mine replaced because I was afraid it was going to drain the battery.
Old 10-28-2016, 08:01 AM
emas's Avatar
Pulled mine out last night to avoid any problems with a battery drain. Picking up the new part at the dealer on Saturday. Pretty easy DIY, only tricky thing is the angle of the 2 torx screws. posting DIY video.
Old 01-03-2017, 02:38 PM
tmandel's Avatar
Bumping this thread -- I have the battery drain problem on my '07 TL-S. The vehicle was dead this morning for the 4th time, and this is with a battery that's @ 1 month old.
AAA came out and jumped the vehicle, and we've left it running/charging today. When I navigate to the Hands Free Link on my MID, however, the unit doesn't report "booting up". Instead the MID reads: "No Information Available." Now, let me say that we have never used the HFL functionality at all. We've never even tried to link a phone to it, and certainly we haven't used other voice commands either. Hence I can't say that it ever worked, or when it stopped working.
At present, however, pushing the "Call" button on the steering wheel -- which (according to the manual) should give me a beep, whereupon I would say, for example, "System", to which it would respond with a sentence -- does nothing. Pressing the button produces no "beep", and (obviously) commands are met with silence.
So, MID says "no information." And system doesn't do anything either.
My main goal is to avoid battery drain. Can I safely disconnect the HFL module (as in EMAS's video above) without compromising any other systems? I.e. if I disconnect it will this affect functioning of anything else whatsoever?
Thanks in advance for any informed responses!
Old 01-04-2017, 12:56 AM
Will Y.'s Avatar
Yes, you can disconnect the HFL.
The only functions you will lose are the HFL and Voice Command, which uses the HFL's mic.
Old 01-04-2017, 02:42 PM
tmandel's Avatar
Thanks, Will -- I appreciate the speedy reply!
I should also have asked if you or anyone understands why the MID would say "No Information Available." In any case, I will disconnect it. Thanks again.
Old 01-04-2017, 04:00 PM
It might say that because you do not have a phone paired.
Old 01-12-2017, 03:38 PM
tmandel's Avatar
The Acura battery drained again, before I had time to look further into the issue of the HFL. While it was dead, I removed the HFL unit, following the excellent diy video provided by emas (about 5 posts above). Thank you, emas -- you made it easy! Then I had the car jumped and ran it for a few hours.
I've driven it, and so far -- as Will Y. advised me above (thanks, Will) -- there are no associated problems w/ anything now that the HFL is out. Next is to let enough time pass to find out whether this solves the battery-drain problem. If so, I will proceed to replace the HFL unit with a new one. If it doesn't make the problem go away (he said, while biting his tongue!), I'll re-install the HFL unit and continue trying to debug this issue.
Fingers crossed!
Old 01-13-2017, 12:09 PM
cbptls's Avatar
I had to disconnect my HFL unit as well.
I was able to locate a site that sells the replacement without asking for a core charge, thought this would be of interest if you are looking to have working bluetooth in your car.
Product Code: 39770-SEP-A62ZA-327807
Old 01-13-2017, 03:30 PM
tmandel's Avatar
Have you actually ordered/received that part, cbptls? From the page, it looks to me like that part is the trim piece. I could be altogether wrong of course!
Old 01-13-2017, 04:00 PM
Until you actually order it, you cant tell if they are going to charge you the core charge. Some sites do not list it but then will contact you to update.
Flipster23
Norcal
262
05-04-2023 02:47 PM
EE4Life
12-20-2022 05:16 PM
EE4Life
03-12-2020 07:29 PM
Michael Bower
06-30-2018 12:31 PM
EE4Life
05-14-2016 07:14 AM
Quick Reply: Bluetooth Stopped Working on '07 TL-S
