Blown Subwoofer?
Old May 18, 2011 | 07:18 PM
04 TL 04's Avatar
Blown Subwoofer?
Hello acurazine, im looking for an expert in this area, because im not too knowledgible at audio. I have a jl audio 500.1 amp that was connected to a 10w7 subwoofer. One day the sub stopped playing so i tryed to connect a sony xplode sub to the amp, and that sub worked for awhile. I knew i was going to blow the xplode from all that power, and that day has come. When i try to push down on the xplode with my hand it wont move at all, but i can push in the w7. When i push in the w7 though there is a slight skeaking noise. I find it hard to believe that I blew the W7 from 500 watts. Anyone have any insight?
Old May 18, 2011 | 07:21 PM
AcRightLINY's Avatar
baller on a budget, b!tch
I think under the right conditions, any amp can blow any sub. Also, I'm not too sure if you're supposed to press on the sub like that. lol.
Old May 18, 2011 | 09:22 PM
Joelito2983's Avatar
Dominic@n TL
It really depends on the frecuency.......i learned that the hard way....
Old May 19, 2011 | 09:05 AM
04 TL 04's Avatar
alright, thanks for the replies, does anyone know how to check if a sub is blown for sure?
Old May 19, 2011 | 09:14 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Multimeter
If the Sony is blown..toss it. If the Sony isn't blown...toss it. Why the hell would they name a sub "Xplode" is beyond me haha
Old May 19, 2011 | 11:05 AM
RJANACONDA's Avatar
Registered TL Lover
the sony xplodes are KNOWN for blowing so i would bet they are blown that is exacly what they do XPLODE LMAO not laughing at you
Old May 19, 2011 | 11:18 AM
03tLsNBP's Avatar
MechEng
i believe its "XPLOD" but nevertheless, still a retarded name for a subwoofer.
Old May 19, 2011 | 11:34 AM
RJANACONDA's Avatar
Registered TL Lover
yeah i thought so to then it didnt look right so i threw on the "e" spelling was never my foretay
Old May 19, 2011 | 11:55 AM
jda123's Avatar
Dogmatic Dinosaur
Take the W7 to an authorized JL dealer and have them check it out. It is worth some time and effort.
Old May 19, 2011 | 06:32 PM
04 TL 04's Avatar
ya i hated that xpolde haha, but I was given it for free and was without a subwoofer so why not. but just took it in today and found out it was blown, bought a brand new 12w6, so problem solved
Old May 19, 2011 | 07:59 PM
eggyhustles's Avatar
Damn, that sucks. Sounds like a coil rub issue with the w7. probably needs to be reconed
Old May 19, 2011 | 09:17 PM
04 TL 04's Avatar
do you know around how much JL would charge for a recone?
Old May 19, 2011 | 10:32 PM
They will bend you over and rape you with no lube for a recone. You can't get a recone kit directly from JL. You would have to send it in and let them recone it, but it will set you back atleast $300.
Team PSI could've did it if it were the 12" version.
Here's a recone they did
So I got in a 12W7 the other day. The surround was done. It has been rubbing against something enough to wear all the way through the foam surround.
So LETS CUT IT APART......
The first hurdle to jump, the basket. I surely dont have any weird, edgeless, extra big cones here... I guess I'll need to use a new basket. to do this, I have to re-drill and tap new screw holes on the top plate. :angry5:
That's a PITA of a process there. It's not fast, or easy, or cheap to do.
Now, on to the soft parts....
The old coil was kinda, meh. I decided to make some new nice flatwind coil for it. Dual 1.4 ohm
The owner requested that I use a 12 spoke basket, here it is with the new basket, coil, suspension, and leadwire...
Is that PINK thread......
Direct connect leads
Looks at that coil!
Now she's all done, new cone and all.
http://www.caraudioclassifieds.org/f...ebirth-w7.html
Old May 20, 2011 | 09:32 AM
04 TL 04's Avatar
Wow that looks like some hard work to recone. I might think about sending the 10 in to JL one day if im feeling rich haha. She was a beast of a sub while she lasted...
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
ripit
Sep 26, 2015 06:19 PM
polish_pat
Sep 25, 2015 12:24 PM
STC
Sep 23, 2015 04:36 PM
