Blown Subwoofer?
Blown Subwoofer?
Hello acurazine, im looking for an expert in this area, because im not too knowledgible at audio. I have a jl audio 500.1 amp that was connected to a 10w7 subwoofer. One day the sub stopped playing so i tryed to connect a sony xplode sub to the amp, and that sub worked for awhile. I knew i was going to blow the xplode from all that power, and that day has come. When i try to push down on the xplode with my hand it wont move at all, but i can push in the w7. When i push in the w7 though there is a slight skeaking noise. I find it hard to believe that I blew the W7 from 500 watts. Anyone have any insight?
They will bend you over and rape you with no lube for a recone. You can't get a recone kit directly from JL. You would have to send it in and let them recone it, but it will set you back atleast $300.
Team PSI could've did it if it were the 12" version.
Here's a recone they did
http://www.caraudioclassifieds.org/f...ebirth-w7.html
So I got in a 12W7 the other day. The surround was done. It has been rubbing against something enough to wear all the way through the foam surround.
So LETS CUT IT APART......
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7010.jpg)
The first hurdle to jump, the basket. I surely dont have any weird, edgeless, extra big cones here... I guess I'll need to use a new basket. to do this, I have to re-drill and tap new screw holes on the top plate. :angry5:
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7001.jpg)
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7016.jpg)
That's a PITA of a process there. It's not fast, or easy, or cheap to do.
Now, on to the soft parts....
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7008.jpg)
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7007.jpg)
The old coil was kinda, meh. I decided to make some new nice flatwind coil for it.
Dual 1.4 ohm
The owner requested that I use a 12 spoke basket, here it is with the new basket, coil, suspension, and leadwire...
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7012.jpg)
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7035.jpg)
Is that PINK thread......![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7032.jpg)
Direct connect leads
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7041.jpg)
Looks at that coil!
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7042.jpg)
Now she's all done, new cone and all.
![](http://i143.photobucket.com/albums/r154/TeamPSI/w7/W7054.jpg)
Looks at that coil!
kb1rl
09-30-2015 10:17 AM
ripit
09-26-2015 06:19 PM
polish_pat
09-25-2015 12:24 PM
