Another Double DIN install - LOTS OF PIX!
Old Aug 5, 2008 | 04:57 AM
  #41
Stew4HD's Avatar
Hey bud,
If you tap into the same wires, you'll be reducing the load (yes, reducing) on the amp. Look at the bottom of the factory sub to see what ohms it is. All the other speakers on my TL were 2 ohm.
To answer your question, I believe you can tap into the sub signal.
The formula to figure out the load on the circuit for parallel load is:
Rl : total load
R1: speaker 1
R2: speaker 2
1/Rl = 1/R1 + 1/R2
If the factory sub is 2 ohm and the kicker is 4 ohm, then the total load would be 1.3333 Ohms.
Please keep me posted on your progress.
Old Aug 5, 2008 | 05:25 PM
  #42
tech14's Avatar
2008 NBP TL
Any power issues Stew? How big are the amps you are running? Did you replace the battery or get a capacitor?
Old Aug 5, 2008 | 05:42 PM
  #43
Stew4HD's Avatar
No power issues at all. I am running one 4x75+350 and a 2x75.. no battery or cap
Old Aug 5, 2008 | 05:57 PM
  #44
tech14's Avatar
2008 NBP TL
Arg! I don't get it. I hooked up an Alpine MRP-F600 (100W x 4), and another small 100 watt amp to power the subwoofer. When I run them at a demanding volume, they both turn off and the voltage drops. Power leads are good, grounds are good, so I am thinking it must be the battery. I just bought my 08, but I think it has been sitting on the lot for a year or so. Other than replace the battery, I don't know what to do at this point other than downgrade my amps.
Old Aug 27, 2008 | 05:43 AM
  #45
UsMcMos0844's Avatar
I still am trying to figure out how to replace my stock navi unit with the kenwood that stew has. i want to upgrade the head unit because i know it wont provide the sound quality i need for all the upgrades for the speakers and the subs. doesnt seem like there is an easy way to go about it though.
Old Nov 26, 2008 | 08:37 AM
  #46
bmwproboi05's Avatar
how do you remove the stock h.u? Also how did you get the amp wire into the cabin area.
Old Dec 3, 2008 | 03:30 PM
  #47
tschmidt098's Avatar
looks good im looking at putting 2 10's in and i wasnt gonna change the head unit but you made me want to change it
Old Dec 25, 2008 | 07:23 PM
  #48
ThezeSkillz's Avatar
NOT my TL or ME
Clean install
Old Dec 31, 2008 | 09:38 AM
  #49
F23A4's Avatar
Nice job Stew.
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
handsom-hustla
Nov 13, 2015 05:04 PM
nanos
Nov 12, 2015 08:41 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
