2006 TL Bluetooth Phone Problem
Old Jan 2, 2008 | 02:26 PM
chuckcobb's Avatar
5th Gear
I have a 2006 TL - my previous phone (which was a Treo 650) worked fine with the HFL in the TL. I recently upgraded my phone to an AT&T Tilt (HTC 8930 which is a Windows Mobile 6.0 phone) and I was able to pair it successfully with the Acura HFL; however, I'm not able to get the same bluetooth functionality that I had with my Treo. Here's what happens with my new Windows Mobile 6.0 phone...
- I can initiate calls from the HFL through the phone and that works fine (for example, if I say "call xxx-xxx-xxxx" into the HFL, it will place the call through the phone successfully
- I can also receive calls through the HFL - if I get an incoming call, I can answer it through the HFL and that works fine
- When I attempt to iniitiate a call through the phone into the HFL, the phone places the call without engaging the HFL. In other words, if I dial the number from the phone rather than dialing it through the HFL, the phone will dial it and call the number itself without connecting the HFL
This worked fine on my Treo, but doesn't work properly on my new Windows Mobile 6 phone. Has anyone else run across this problem? Is there a solution available?
Thanks,
Chuck Cobb
Old Jan 2, 2008 | 07:44 PM
pohljm's Avatar
after the phone connects push the hfl button and say "transfer" that should activate the hfl
Old Jan 7, 2008 | 12:20 PM
chuckcobb's Avatar
5th Gear
Thanks for your response...that helps, but I never had to do that with my previous phone - the HFL always activated automatically. Do you think that's a problem in the phone, the HFL, or a combination of both (compatibility issue)?
Old Jan 7, 2008 | 12:23 PM
blkaspec's Avatar
Full of water...
i think thats how it is suppose to work. i didnt think it could transfer automatically.
Old Jan 7, 2008 | 02:57 PM
leedogg's Avatar
RAR
I've always had to do the transfer method with my treo...
Old Jan 7, 2008 | 03:03 PM
TeknoKing's Avatar
I have the same issue, I have Blackberry 8820.
I don't think saying transfer every time is convenient.
Old Mar 3, 2008 | 12:11 PM
damagoh's Avatar
I too have a 2006 TL and have just upgraded my phone from a treo 650 to an AT&T tilt phone. However, I have been unsucessful at pairing the HFS with my new phone. I have the tilt phone in visible mode, but HFS cannot seem to find the device. Does any one have any hints? Is there a way to put HFS in discover mode? My phone can find HFS but the HFS won't allow pairing in that direction. thanks!
Old Mar 5, 2008 | 12:08 PM
nipseyrussell's Avatar
steelworker
if i understand the question correctly....
if i turn on the HFL first, then dial the number on the phone, it automatically pushes through to the HFL
if i have already dialed on the phone and then want to transfer, then phohljm's response covers that.
MilanoRedDashR
38
Sep 28, 2019 09:13 AM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
brandnewcolony
Sep 12, 2015 10:39 AM
ivegotthenav
Sep 11, 2015 07:51 PM
