Wow... Lots of crazy new LEDs from autolumination
#83
i bought the lights from super bright leds they look pretty good i put them on the door pretty sharp. for the overhead lights when i took the cover i couldnt pull the lamps out. they are in there pretty good. anyway thanx for the advice for the lights
#84
Originally Posted by Kennedy
Pics as promised, sorry about the crappy cellphone pics.
I told you those 1W LEDs we're just about perfect...
This hot was difficult to get, as my building's security lights was kicking out major glare.
![](http://usera.imagecave.com/kennedyusmc/Acura/DSC00125.JPG)
Much better close up:
![](http://usera.imagecave.com/kennedyusmc/Acura/DSC00126.JPG)
![](http://i2.photobucket.com/albums/y7/leedogg/Car/CIMG1322.jpg)
#85
Originally Posted by kappa821
how do u replace the lights for the license plate........i cant figure out how to get into those lights
#86
Originally Posted by hrj_1985
Ive bought this one and tested it out.
It has the same brightness as 32 leds. I got the red one, the difference is this one is more reddish than 32 leds.
#87
Originally Posted by MAZDASPEED
I'm interested in using these as brake lights (in red obviously) but I haven't found anyone willing to pony up the cash (myself included) on the off chance that they will be at least as bright as the stock incandescents...Seeing as you have already bought these, do you think they are bright enough for use as brake lights?
#89
Team Anthracite Member
Guys, I'm still looking to replace the crappy silver off/orange on turn-signal bulbs I put in my headlights after clearing and blackening them. Will these LEDs still require a huge resistor if I want to use them as turn-signal bulbs?
#90
#91
At this point, I wouldn't mind if it was orange/orange... But so far there is no bright-enough LED flasher which fits through the OEM bulb hole?
#92
Port & Polish Everything
Please read this thread before posting.
1) NONE of the LEDs in discussion here are offered by Tec-Toys
2) Many have had quality issues with LEDs bought from Tec-Toys (failures), insufficient brightness, or color issues.
3) Tec toys is buying leds from www.superbrightleds.com and reselling them with markup. No need to do that when you can buy them direct from the source.
#93
Weather Watcher
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Great info guys. I'm about to make this switch. I wanna buy the 1W blue LEDs for the trunk, domes, front doors and 1W LEDs for the reverse and license plate. These would work fine in terms of fitment right? Also how do the 1W LEDs compare to the 6LED bulbs I have now brightness-wise(sp)? Lemme know - thanks..... love this forum!
#95
Originally Posted by csmeance
remove the liner on the trunk lid. There should be about 12 clips and 2 rubber inserts that areon the edge of the trunk lid. Insie, you will see everything for the lights.
very stupid question but how do u take the 12 clips out......i know the rubber inserts just twist but how about the other ones.......
i put the superwhiteled in from superbrightleds on my doors and they look good....thank you for the recommendation i just have to buy a couple more now
#103
Originally Posted by pimpin-tl
I can test the back up lights. Tell me which one we can both agree on that will produce the most light and will work in the back ups.
#106
Iro Ridg .308
LEDs are in.
Now that it's thawing out outside, I'll try to throw these in and snap a few photos. Hang in there.
![](http://usera.imagecave.com/kennedyusmc/Acura/DSC00166.JPG)
#107
Hows the weather?
50 degrees this weekend. I promise to get the testing done Friday/Saturday night.
The one on the far left is the "switchback", I'm desperate to make that my front running light.
#108
2 inches of rain expected in Northern Virginia tonight... Sorry guys, it's been cold.
Yeah the weather is pretty crappy out here. Good luck on gettin the switchback to work. if you do wanna do it for me too!!!!! haha
GL
#111
TESTED... We have a winner!
First, Let me set up the test:
See this LED in LeeDog's hand (from www.superbrightleds.com 1W)?
I have those all over my car... interior, license plate, and reverse lights. For reference, here's what the license plate looks like with those leds:
Lets call that LED "Zero" for reference, as it's what we're comparing.
I found these new leds from autolumination and decided to try them out, it only took a month to get it done, sorry for the delay. See below:
Let's number these LEDS 1-5, from left to right
1) The switchback, it won't fit anywhere without a dremel. I'll do that when I clear the headlights
2) LED towers for rear turn signals... I'll test these at a later date.
3) Tested as reverse lights runner up
4) Tested as license plate illumination
5) Also tested as the reverse light... The winner!
Pictures:
3 on the left, Zero on the right
#3 was a little brighter, and a little more blue, but nothing to right home about. As you can see from the pics, they we're of about equal brightness.
Now introducing #5 on the left, Zero on the right
Wow... MUCH brighter. These are keepers. Go for these.
Let's compare those great superbrightleds license plate bulbs:
Zero on the left, #4 on the right.
Wow there too, much brighter, and more natural looking light from #4.Go for #4 for your license plate leds.
Last pic, since #5 is multidirectional, I put one in the trunk... much brighter than stock:
I plan to order 2 more for the vanity mirrors.
Needless to say, a good investment here. I'll keep the superbrightleds (Zero) in the interior for now, but need to order 4 more #5's for the reverse and vanity lights, and 1 #4 for the other license plate.
1 installation note. The leds fit in the housing, bit they're a little loose. I used a little silicone to secure them in the housing to keep them from vibrating loose. I recommend you do the same.
Questions?
Pictures:
Questions?
#112
Questions?
Questions?
Would you say that #4 gives off a blue-ish hue like the zeros do? It's hard to tell from the pic.
I put the zeros in after seeing your original pic, and have already had 2 people ask why I have blue license plate lights.
#113
..Kenny for testing these out for us and doing a write up
It was worth the wait.
To clarify..the #5 are the (194 SMT Tower) right? and #4 are the (194 Supernova Bulbs)?
Did you test the #5 bulb for the plate ?
Last question, the trunk light...how do you take off the cover?
sorry for all the questions :o)
#114
King of NYC
Nice post Kennedy! I'm goin for the same combo!
So #4 is from superbrightleds.com and #5 is from autolumination.com?
It looks like they're both from autolumination.com, supertbrightleds.com seems to sell only "zero"
Only problem....$40+shipping for a set of these little LEDs, Ouch!
#115
in regards to kennedys post:
i have zeros all over the inside of my interior and the door......i like the way they look they give off a white look instead of that blueish tint.......the only thing is that they might be a little to bright for the interior have not driven the car enough at dark but i do like it when i unlock the door and it lights up all white inside sick.........the only thing is that i dont know if these lights are going to be bright enough for the license plate or reverse lights i have to still try this out........when i finish ill post pics
has anyone tried to change the fog lights to white.....any reccomendation for lights?
also am trying to do the sidemarkers anyone know the number on this and recommendation for lights and how do i take the side marker off? thanx
#116
Tony,
1) Yep #5 is - "SMT Tower 194 Leds"
Seen here: http://autolumination.com/194.htm
2) No #5 is an omni-directional bulb. You need a focused beam bulb for the license, which #4 is perfect for. BTW, #4 is called the SuperNova.
3) The cover plate pries off with a flat tool. Search "Vanity mirror" and you'll see the how to for how to remove those crazy covers
Rocky,
No please reread. "Zero" is from superbrightleds.com (the little white one). #1-#5 are from autolumination. #4 is the "Supernova, #5 is the 194 SMT tower.
Rocky,
#117
Kappa,
To prevent threadjacking.
1) The superbright leds 1W white are not too bright for interior, at least for me. I'd buy and try 1 before committing. I'll have some for sale as soon as these replaceements come in.
2) I personally run 3000K (yellow) HIDS in the fogs, and changed out the stock bulbs for 6000K D2S bulbs. Any 9006 HID retrofit kit will work, you can get as "white ir blue" as you want. The Cheap Nokya bulbs are also known for being whiter (artic whte).
3) I've modified my front and rear sidemarkers using this post as a guide:
https://acurazine.com/forums/showthr...e+side+markers
Stock are 3mm high flux, I used the 5mm High flux leds, as thier brighter. It is a bit of work to swap those leds out though.
#118
Kappa,
not to sure what threadjacking is but i have the zeros in interior and door already and i said i like the white look they give but i havent been inside the car enough to get a perspective on if they are too bright
for 3: i was going through that thread and i thought u could just swap the lights like the interior am i wrong? seems like a pretty diff mod
#119
"threadjacking" is defined as asking supefulous questions in the middle of a well flowing stream of posts, taking the discussion off-topic. My reponse was intended to quickly answer your questions, albeit slightly off topic, and get the thread back on track... You asked about fogs light bulbs and side markers, which have nothing to do with the LEDs in discussion here.
In response to yuor last post:
1) Sorry, didn't catch you already have the "Zero's". I think they're fine, but if you think they're to bright, that's your call.
2) No, you cannot replace leds in the sidemarkers without cutting them open. From the pics, you can see that the leds are soldered to a circuit board inside... They're not "bulbs per se. That's da truff.
Cool now?
Back on topic, anyone else have any input or thoughts on the autolumination bulbs?
Cool now?
