What other manual transmissions fit on the 2007-2008 TL-S?
I have a question regarding what manual transmissions fit on the 2007-2008 TL-S besides those years? Can I get a transmission from any other similar v6 honda like an accord? I am just wondering for future reference. Are those even available to be purchased for cheap to rebuild?
Thanks in advance!
Thanks in advance!
J series Accord 6MT cases should bolt up.
However, the gearing is longer, and they have no LSD.
The base model 3G TL manual trans will also bolt up, but I'm not sure if gearing is different.
You said you were asking for future reference...
Are you planning on destroying your trans in the future? Or...?
Kudos to the kid for being proactive?
montero65 (07-12-2024)
Keep this thread updated, if possible, I'd like to know if the 'play' is caused by the below worn internal trans parts:
I posted before and someone said something similar. I have just never tackled it before and would like to try and rebuild my transmission to learn. I am assuming it is probably what is causing the the play in my shift level.
That is generally not a transmission problem although I am not familiar with the TL manual. Have you checked the linkage?
That was myself.
There is one here for free if you look for it.
I know its not a transmission issue per se but its still housed within the transmission it self. I would have to open it up to see. Not dissembling all the gears but just looking for the pertinent things.
2 doesn’t move but 3 does. however, its not greatly impacting drivability or anything. It’s just annoying and unusual. Comparatively, I drove a friends 2013 honda accord v6 and it was super notchy which i feel allows me to know that I am in gear.
08-17 Accord has the round bell housing, and if the OP has a manual already, the LSD can swap over with the corresponding final drive and countershaft.
How do I know? I put an 3G TL final drive, countershaft & LSD in an 08 accord trans.
https://acurazine.com/forums/2g-cl-p...-swap-1001141/
Lastly, the gearing on the 08-17 accord is shorter, due to the larger 3.55 final drive vs 3.285
08 Accord v6 6spd
1st: 3.933
2nd: 2.478
3rd: 1.700
4th: 1.250
5th: 0.976
6th: 0.771
Reverse: 4.008
Final Drive Ratio: 3.550
3G TL Type-S
1st 3.933
2nd 2.478
3rd 1.700
4th 1.250
5th 0.975
6th 0.770
Reverse 4.008
Final 3.285
