Underbody cover part number
Under the car in front of the drivers side rear wheel is a plastic cover. Mine got partially damaged, so I ripped it off to prevent it from flopping around. Would like to replace it as it looks like it protects some module or electrical/fuse box. Anyone know what this cover is called or what the part number is? I searched the hondaacuraonline parts catalog (https://www.hondaacuraonline.com/v-2...e--3-2l-v6-gas), but can not seem to locate it there. Thanks.
I had been having a slew of noises coming from underneath that started with some rusted/broken exhaust hangers and a loose heat shield on my 3rd cat. After getting those taken care of, I had 3 of the alum exhaust heat shields come loose from rusted out bolts. I ripped out the rear ones, and secured the big one by the cat with self tapping screws. I was STILL having noises, so I was looking underneath for the culprit and noticed that plastic cover was loose and hanging down a bit. Turns out it just uses plastic push pins to hold it in place (they must have broken off somehow), so I probably could have secured it back easily. But in my frustrations with noises from under the car, I just ripped it off instead, breaking it in the process. That plastic seemed to be a bit brittle from years of road exposure.
Turned out, that wasn't even the noise. Finally found it to be a rusted out dust shield on the brakes. That's now gone and finally am free of noises.
I'll look on eBay or in some salvage yards to see if I can find another one for cheaper.
I apparently did not read as intently just saw "plastic rear driver's side wheel"
