Turn signal reset after replacing?
Old Aug 14, 2013 | 06:30 PM
AyFeltaTL's Avatar
So both of my turn signals both only flashed when i used them with the turn signal lever, not when i locked the car nor when i unlocked my car or when i have my light switch on. So i burnt out my right blinker and went on to replace it and now that i replaced it, it flashes now when i lock it, unlock it, and turn my lights on its on constantly...now when i ride at night i have my right blinker on all the time and the left one off all the time. How can it back to having it off all the time other then when i need to use it as a blinker?
Old Aug 14, 2013 | 07:01 PM
vietxquangstah's Avatar
have you tried replacing the drivers side blinker?
Old Aug 14, 2013 | 07:40 PM
AyFeltaTL's Avatar
No, because I'm afraid it will be turned on permanently like the new light and I don't want that...
Old Aug 14, 2013 | 07:48 PM
AcuraTrooper's Avatar
9th Gear
I'd try replacing the left one. or check your fuses?
Old Aug 14, 2013 | 08:27 PM
You must be new to the TL or don't understand how the turn signals work.
They are dual filament bulbs. They serve two purposes. Parking lights (When you flip your headlight switch forward one time from the OFF position or turn your headlights on completely)
When you have your headlights on both of your parking lights are supposed to be on constantly. When you hit your turn signal with your headlights on they will get brighter and dim, brighter and dim.
When your headlights are off and your parking lights are off than your turn signals will only blink when the signal is engaged and turn off completely when the signal is done.
Do you get what I'm saying? It's normal for it to be "constantly" on when your headlights are on.
Just replace your drivers side bulb and call it a day
Old Aug 14, 2013 | 09:57 PM
crbnfbr's Avatar
I'm guessing you have an 07+ with the wing mirror signals?
Old Aug 15, 2013 | 02:08 AM
AyFeltaTL's Avatar
I'm not new at all I've owned my tl for almost two years now and I honestly want it so the bulb I had to just replace didn't turn on because I just blacked out my headlights so it's kind of that dull yellow color going with the nice color of my headlights... So what you're saying is my driver side bulb is wrong for only working when I wanted to use it as a blinker? It's an 05 as well..
Old Aug 15, 2013 | 03:18 AM
paperboy42190's Avatar
if you dont want the parking light park to come on, just cut the wire or get a single filament bulb. conversely you can also get switchbacks that light up white but blinks amber. up to you
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
yahelou
Sep 6, 2015 09:12 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
