Tuner
Old Jun 16, 2020 | 02:14 PM
Romancarmo21's Avatar
Tuner
Does anyone know what the best tuner for a 2007 type s would be? And if you do please let me know
Old Jun 16, 2020 | 03:55 PM
AM or FM?
Old Jun 16, 2020 | 03:57 PM
csmeance's Avatar
k-tuner or hondata are your best bets
Old Jun 16, 2020 | 06:23 PM
What’s am or fm mean?
Old Jun 16, 2020 | 06:35 PM
peter6's Avatar
From https://www.pbs.org/wgbh/aso/tryit/r...iorelayer.html
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied.
FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
Old Jun 16, 2020 | 07:08 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Old Jun 19, 2020 | 12:19 AM
FancyHonda's Avatar
Feel free to correct me, but I believe the Hondata Flashpro is the more comprehensive tuning solution. It's the one I intend to get for my car to tune out the nasty rev hang.
Old Jun 19, 2020 | 11:54 AM
oraclem20's Avatar
It is the most comprehensive at a non-insane skill level. The anti-rev almost got me, as I have a bored TB and plan on bigger custom TBs. There's also a section to tune throttle response vs rpm and map and a few other things that should be able to tune it out. I'm going to try and use the AEM Infinity 506 however which is a whole ECU replacement with no wiring harness offered (see:insane level) to support what I plan to do to this engine in coming years.
If you're not on a small budget, go with FlashPro, you won't be disappointed in its abilities or the ease of install. The only semi difficult part is getting a new ECU flashed to your VIN if you have an 06-04 TL. Some dealers will do it no question, some are sticklers, however Halferland offers a computer for rent to do this yourself if you end up in the latter situation, after that it's drop in a harness and press play.
If you're on a tight budget and going boost or just want more fuel/ a nitrous window switch with limited other capabilites, the AEM FIC6 piggyback unit is about half the cost with harness. It can't do a ton of timing changes (no advance, critical for high HP or N/A builds) and has to correct around the ECU which will still be constantly trying to retune your car (to a minimal degree if you're good with the FIC, but a few degrees of timing under boost is a big change).
Old Jun 20, 2020 | 12:13 PM
1black_seven's Avatar
Slot Machine Lubricator
+1 Hondata
breck569
Feb 21, 2014 12:47 AM
Wisc Badger
492
Nov 5, 2011 10:33 PM
slickrab
29
Oct 9, 2008 01:13 PM
geminisdc
Console & Computer Gaming
20
Oct 25, 2006 01:01 PM
