Switchback Turn Signal Question/s
Former Whiner
Hey AZine switchback crew,
I've read the scattered threads but my question is pertaining to where to buy and why?
I have 60LED switchback from Autolumination and one of them is blowing my fuse immediately. I have emailed them with this problem but no reply yet.
I believe Steven Bell has stated that the 60LED will NOT work. I am a little stumped as I had them on for roughly 2-3 months without a problem. Is it too many LEDs or simply Autolumination is ?
I read V-LEDS sell the switchback turn signals as well.
Should I go with them?
Will the colour be the same as Autolumination? (I have 8000K low beams and they match very well to the switchbacks)
Why won't 60LED work?
Do you think Autolumination will do anything about my problem?
Feel free to share your thoughts and I know... lots of questions.
Received 6,470 Likes
Souljah,
Tracy from Autolumination should write you back. Each time I wrote to them, Tracy took back my switchbacks (2 sets) and credited my account. The 60 LED's were the ones that blew my fuses too. So far, the 30 LED's are doing fine-no problems after 2 weeks.
By the way, did you write your original post incorrectly? You've mentioned the 60's twice.
Former Whiner
I don't see where I wrote 60's twice?
I have 60's, were working fine for a couple months
You stated 60's will not work
Ironically, one of my 60's went "bad"
Was curious on why. If it was 60's in general or Autolumination.
Steven, did you get the 30's from Autolumination?
I personally did not have a good experience with autolumination. I wasted so much time to make sure the bulb was actually broken but observing it closely made me sure it wasn't my TL. There was a clear problem with the LED and she still charged me 20% and shipping to return the faulty bulb. The pricing wasn't good neither. So I ended up getting it from V-leds.
One from Autolumination:
One from V-led that works fine:
I'm not a big fun of bad mouthing anything especially online but I really feel it wasn't fair. Tracy was really good at communicating on email though.
See lines 2 & 3 in your first post.
I think it might be 60 LED's deal-I think they just overloaded the TL's system. It blew a fuse inside my engine compartment. That's why I switched to 30's. I don't think it's AutoLumination-I've ordered other bulbs from them and have not had any problems.
Former Whiner
Thank you for the pics. Very helpful
But looks like V-Leds does not carry 60LED.
Do you have pics installed? I really want to try to keep my colour matched scheme.
Sounds odd but 8000K low beams look good with the 60LED autolumination switchbacks.
I tried the 48's, but they burned out too, but I also discovered that I had a bad wiring harness on the driver's side. It might have been because of that faulty wiring in the harness that connects the turn signal. So I'm sticking with 30's-they're plenty bright and seem to match the headlights.
^^^ That looks really good, Tako!
Former Whiner
Tracy has stated that since it was working fine for the couple months, it cannot be the switchback that is the issue with the car....
I just replied my troubleshooting, maybe that will change the direction of our emails...
Veni, vidi, vici
don't you need load resistors for LED SWITCHBACK's? I have my switchbacks installed with load resistor's because what happens is that LED's take less energy to light up. This confuses the car, and causes the car to think that the bulb is somehow lossing power or needs more power, then it starts sending more power to the LED, which could be causing the issue your having. Load resistors consume the extra electricity sent by the car.
She gave me that kinda answer when my switchback was not working at all. I knew I can just plug the switchback to the car and it will just hyperblink without the resistor. She told me that it's might now work without the resistor and told me to do more testing straight with the 12V battery. I wasted few hours knowing it was still bad switchback.
Yes, this is correct.
Former Whiner
Yes bayam0n, resistors are a must and I do have them.
My troubleshooting (post #23):
https://acurazine.com/forums/3g-tl-problems-fixes-114/im-baffled-no-interior-lights-756542/
King of NYC
autolumination has the most variety and selection for sure but V-LEDs, Oznium and SuperBrightLEDs has better quality products and better service.
Usually I don't badmouth unless it is truly deserved. IMO autolumination does deserve it and the board has heard me bash them enough times.
^^^ Yes, I went through 2 sets of LED switchbacks from AutoLumination.com and had to send them back. They found that both sets of bulb were bad. But I'm not sure if it was indeed the bulbs or because of the short in the wiring harness I discovered. I also looked at V-LEDS.com, but I also saw that they were very expensive.
Hmmm.....maybe I was looking at a different type. V-LED's had some switchback LED's for $79.99.
2004 SSM FTMFW !!!!
As for my hid's I got some of brand at least to me they are, there are called "bada bling" I get those local, and as for the switchbacks I order my first set from V-leds but when I purchased from them they only had "Version 2" and they wouldnt alternate when the parking lights were on. Then I found out that the same seller I got the hid kits he sells them and those are the ones that I have now. He told me that he is the one that supplies to V-leds don't know if its true, but I'm happy with my whole front lighting set up
I got a pair of resistors for $8 from V-leds when I originally got a single resistor from autolumination for the same price. The shipping from V-led was free and I became a friend of V-leds on facebook, I got extra discount.
Autolumination ripped me off too
1 of my 60's blew out and took the fuse with it.
I emailed Tracy and they agreed to take back the one bulb. They also agreed to exchange my other bulb for a 48 so this wouldnt happen again.
Long story short my working bulb magically stopped working when they received it so that they could make some more money off of me.
Avoid at all costs!
Avoid at all costs!
Former Whiner
I guess I'll just pick up a set from V-LEDS. I have been emailing Tracy for 2 days now and the best offered was a discount if I wish to purchase a replacement.
SidhuSaaB
05-30-2020 12:40 AM
Greengecko
09-16-2015 08:19 PM
