Quick question regarding usage of 5AT
Old Nov 4, 2005 | 07:26 PM
Wiretapped's Avatar
Can anything bad happen to the tranny if I change from neutral to drive when the car is moving? How about changing from reverse to drive when the car is still rolling backwards?
Old Nov 4, 2005 | 07:28 PM
NFLblitze1's Avatar
Youse Gots Sacked
yes...thats VERY bad for ur transmission.....i have a habit of doing that myself....its VERY bad for the tranny
Old Nov 4, 2005 | 07:35 PM
KaMLuNg's Avatar
where are you putting it from neutral to drive when you are moving???
but blitze is right.. bad for any tranny...
Old Nov 4, 2005 | 09:06 PM
massr1's Avatar
How is this bad? The gears in the tranny are still moving in neutral, and when you go into drive there's no noticable jerk. Please elaborate.
Old Nov 4, 2005 | 09:32 PM
crazymjb's Avatar
Depends how well you match the speed, if you throw it into drive while rolling at high speed you will probably just slow down REALLY fast. As far as from reverse to drive that stresses the engine and tranny. I would not view either to be lethal though it may reduce the life. On mythbusters they repetativly through a car going 60 into reverse, tranny lasted.
Old Nov 4, 2005 | 09:41 PM
Actuary's Avatar
18,000mi. 29000km
couple month ago I did that N - > D by accident while going down a hill. I was parked on downhill and I thoguth I was in D when I pulled out, but in fact I was in N. I was about 20MPH and when I switched to D, I heard gears minorly rubbing.
from D - R or N - R I believe new TL won't do that as long as you are over certain speed. 10MPH?
Old Nov 5, 2005 | 03:48 AM
Wiretapped's Avatar
Well I'm used to poping into neutral at a redlight but you know how somtimes the light change before you roll to a stop and there's people behind you, so you gota get moving asap...
Old Nov 5, 2005 | 04:49 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
The transmission isn't stupid - it will compensate. You can be rolling at 60 in neutral, pop it in drive and it will NOT jerk or slow you down, it will just go immediately to the appropriate gear. It's not bad for your transmission.
The shifting to D while still rolling backwards, however, stresses the whole drivetrain.
Old Nov 5, 2005 | 08:35 AM
NFLblitze1's Avatar
Youse Gots Sacked
doing this in neutral as its not so good for the tranny its WORSE to do this in reverse...if your rolling back and then u pop it into drive it is TERRIBLE for hte tranny and as CoupeV6 said...it stresses the whole drivetrain
Old Nov 5, 2005 | 11:50 AM
Wiretapped's Avatar
Can someone confirm this?
Old Nov 5, 2005 | 04:31 PM
NFLblitze1's Avatar
Youse Gots Sacked
he is right...it will automatically do it for you....BUT...doing this in reverse is not a good thing to do. as well as doing this in park....is not a good thing either....
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
