Question on a Engine Replacement
Old Jan 12, 2010 | 05:28 PM
majestywil's Avatar
My boys car engine is done! He has a 07 Acura tl base , not Type S.. He was wondering if he was to buy an Engine from an 06 TL would it fit on his 07 and would he have to do any mod to the car such as change ecu or something?? Thanks in advance!
Old Jan 12, 2010 | 05:34 PM
732's Avatar
732
I have to ask, but what did he do to make it go so quick?
From what I understand it should, but if the engine is done is the transmission messed up as well?
Old Jan 12, 2010 | 05:41 PM
majestywil's Avatar
No the mechanic told him the engine is stuck.. N all he needs a new engine, from what they told him...
Old Jan 12, 2010 | 06:49 PM
VQPower37's Avatar
hydrolock?
Old Jan 12, 2010 | 07:18 PM
BoxOn20s's Avatar
In some states it wouldnt be legal to install a motor that is older than the vehicle model year but if you were gonna do the swap anyway, I would retain the original ECU and install the original sensors since you have no idea if the sensors in the replacement motor are any good.
Old Jan 12, 2010 | 07:39 PM
Turbonut's Avatar
From what I can see from the used parts guide, the 2004-2006 same, and the 2007-2008 same.
Looking at the part numbers, the '06 differs from the '07, just to name a few:
Rear cylinder head, but the front is the same.
Engine assembly
Engine control module
Cylinder block assembly
Engine wiring harness
Do these differences indicate that the '06 engine won't be fine as a replacement, I certainly can't answer that, but I would stay with the '07/'08 to be sure.
Maybe some with more knowledge with be able to answer this.
Old Jan 12, 2010 | 07:47 PM
o4Komodo's Avatar
Rev High; Drive Happy
hmn, not going to lie i was hoping to read about a RB26 type of engine swap or something.
Old Jan 12, 2010 | 09:16 PM
majestywil's Avatar
Thanks guys for the help... I guess I might have to tell him to stick with 07...
Sry 04k didn't mean to trick u lol...
Old Jan 12, 2010 | 10:11 PM
o4Komodo's Avatar
Hahah. It's okay. It was wishful thinking on my part.
Old Jan 13, 2010 | 12:07 AM
ciscopath's Avatar
Engine Replacement would have been a better choice of words. Clicking into the thread, my expectations weren't too high when I noticed that the post count hadn't made it over 200 in less that one hour..HA
Regurgitating what other members have said, stick to the '07-08' engine
Old Jan 13, 2010 | 02:04 PM
LoveMyTL-S's Avatar
Title fixed........
Old Jan 13, 2010 | 03:36 PM
o4Komodo's Avatar
o.o
When did you beome a mod?
Grats!
Old Jan 14, 2010 | 10:06 AM
LoveMyTL-S's Avatar
Originally Posted by o4Komodo
o.o
Grats!
Last year. Thanks.......
Old Jan 14, 2010 | 02:26 PM
Majofo's Avatar
07 has a revised AT so I wouldn't bank on it, 08 will definitely work as well.. The question your friend needs to ask is if he really needs an engine replacement?? Most places prefer to R&R because it's easier on them.. not you. Give us more specifics.. like is it a seized piston/s, bent valves, etc..
Old Jan 14, 2010 | 06:06 PM
BLACKURA_NY's Avatar
I have car ADD
^ Correct
2007+ TL & TL-S have the grade-logic transmission
If an engine replacement is "needed" ... go for a 3.5L Frankenstein build... or atleast a J35A8 swap
Old Jan 15, 2010 | 09:28 PM
prophoenix's Avatar
lol same
Old Jan 15, 2010 | 10:04 PM
vovka2007's Avatar
Originally Posted by prophoenix
lol same
I would think 04-06 would bolt on just fine. But Ecu and sensors would definitely need to be original. A six speed install would be sick too.
Old Jan 17, 2010 | 03:09 PM
YeuEmMaiMai's Avatar
Originally Posted by BLACKURA_NY
^ Correct
uhm TL has had the grade logic for quite some time even before the 5spd at was introduced. Honda has been using it since at least '94 as my old 94 accord had grade logic
wusty23jd
Sep 24, 2015 11:41 AM
Skirmich
Sep 15, 2015 06:41 PM
iCrap
Sep 11, 2015 06:21 PM
HOWELLiNC
Sep 5, 2015 03:09 AM
bailey24
Aug 31, 2015 05:38 PM
