Power steering fluids?
Old Feb 28, 2012 | 12:54 PM
3GTLCHICK's Avatar
I searched but didn't find solid answers.
can someone tell me if I should use honda only fluid?
Is there a quality fluid on the shelf at a parts store anyone might recommend?
tia
Old Feb 28, 2012 | 12:56 PM
s_vares's Avatar
Try to get a fluid that says "honda/Acura compatable" and you will be okay
Honda PS fluid is thinner than regular stuff, which is ATF
Old Feb 28, 2012 | 01:01 PM
SharksBreath's Avatar
BANNED
i like the amsoil PSF.
Old Feb 28, 2012 | 02:03 PM
3GTLCHICK's Avatar
Any particular on the shelf stuff work well? The mechanic is saying dealer only.
Old Feb 28, 2012 | 05:02 PM
I hate cars's Avatar
Use either Honda or Amsoil. Honda is thicker than most others and uses more zinc. Amsoil is a much better fluid, will hold up better and steering will be lighter when it's cold.
I haven't found an off the shelf fluid I would use other than OEM.
Old Feb 28, 2012 | 05:54 PM
swoosh's Avatar
takin care of Business in
^^^ I concur....thow i have experience with only Honda PSF, I will be trying the Amsoil this go around...
Old Feb 28, 2012 | 09:58 PM
3GTLCHICK's Avatar
Thanks for the advice. I will check dealer.... I need lots to flush system out, amsoil would likely be too pricey from what I hear.
Old Feb 28, 2012 | 10:09 PM
swoosh's Avatar
^^^ you just need 2 bottles TOPSSS
Old Feb 28, 2012 | 10:24 PM
Bearcat94's Avatar
AZ Community Team
Agree. Removed my pump an and did pretty much a full flush with 2 bottles of Amsoil.
Old Feb 29, 2012 | 12:10 AM
3GTLCHICK's Avatar
I bought a new reservoir and want to try to get out as much as possible. there has been bubbles in there for a while- I was told and it was explained to me as an oxidation issue with current oil?
Prestone has honda fluid at wally world, I wonder if its decent, at least for just a flush..
My other half swears by his amsoil transmission fluid in his GTO and Camaro, I don't want to risk it.
Maybe the time has come for a new car.
Old Feb 29, 2012 | 07:04 AM
johnny3's Avatar
Use OEM, I had a bad experience using an after market fluid (had to replace rack & pinion assy).
Rather than flush just do a change fluid, 2 bottles,
then do another change 2 weeks or so later using 2
more bottles.
Old Feb 29, 2012 | 07:13 AM
Inaccurate's Avatar
What was the aftermarket fluid? If you can't recall exactly, can you please describe the best that you can?
Old Feb 29, 2012 | 08:21 AM
Lol. Bubbles and oxidation are two different things. Bubbles is aeration caused by a leak in the system. Have you done the o-ring yet? Bubbles is not a problem with the oil. Oxidation usually shows up as a thickening of the oil and it's hard to see without getting an analysis done.
I would listen to your other half, sounds like good advice on the Amsoil. I've run it in the trans or power steering for nearly 100,000 miles.
Old Feb 29, 2012 | 10:41 AM
swoosh's Avatar
my work here is done
Old Feb 29, 2012 | 01:18 PM
Majofo's Avatar
Amsoil.
Tia, How you doin?
Old Feb 29, 2012 | 08:15 PM
johnny3's Avatar
It was some brand that was supposed to be ok for all cars including Honda/Acura that a family member was getting at Oriellys. The car was a 97 TL, it had a leaking PS hose & was needing a 12 oz bottle of fluid every 2/3 weeks, by the time I found out about it & put the hose on it the problem had been going on for 6 months or more. 3 or 4 months later the steering rack was leaking really bad & I had to replace it.
Learned the lesson the hard way, only OEM Honda PS fluid in my Acuras & Hondas.
Old Feb 29, 2012 | 08:27 PM
BANNED
^unless it's safe for hondas/acuras...like amsoil is.
sounds like somebody didn't do their homework.
Old Feb 29, 2012 | 08:34 PM
kingkong_dav's Avatar
KingKong_Dav
use acura fluid, no asmoil, never heard of it...
Old Feb 29, 2012 | 08:41 PM
BANNED
^yeah I've never heard of asmoil either.
Old Feb 29, 2012 | 09:02 PM
Sometimes it's just better to say nothing.
Old Feb 29, 2012 | 09:37 PM
swoosh's Avatar
for some reason i like kingkong_dav....he can get under people's skin without saying much LOL....
as mentioned above....i would ONLY go with recommended fluids:
Honda/Acura stuff: Recommended by Honda/Acura
Amsoil: Recommended by many members on the forum
Old Feb 29, 2012 | 09:41 PM
BANNED
^you take it back swoosh!
Old Feb 29, 2012 | 09:42 PM
swoosh's Avatar
we are still friends right Aaron ???
Old Feb 29, 2012 | 09:50 PM
BANNED
^yeah if you get my ECU shipped tomorrow
Old Feb 29, 2012 | 09:57 PM
swoosh's Avatar
lemme see what i can do
Old Mar 1, 2012 | 04:14 AM
3GTLCHICK's Avatar
Well, guess I'll pick it up from the dealer. Thanks guys.
The car went to the dealer a while back for a power steering recall, I dont know if the seal was replaced? It was ordered and will be put in when he does it. I dread going to the dealer, cerritos acura sucks in many ways.
Old Mar 1, 2012 | 11:37 AM
Majofo's Avatar
Can we change his name to kingkong_dingdong?
Old Mar 1, 2012 | 12:02 PM
JBONN's Avatar
Vegas Bum
Went to the dealer a few weeks ago and they told me its all the same as long as it says compatible with honda's/acura's...save yourself a few bucks!
Old Mar 7, 2012 | 07:34 PM
3GTLCHICK's Avatar
Honda dealer, 4 pints were $21 otd.
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
