The "OK" Button Is The Devil!
Old Apr 22, 2004 | 09:10 PM
boltjames's Avatar
Team Camel Executive VP
I can't take it anymore. Every time I start up the car, it haunts me. I can't just put on the seat belt and go. No. I have to strategize. Have to come up with the appropriate time in the departure sequence to glance at the nav screen and hit the button. One time, I didn't pay attention and the screen went black. Black! I had to pull off the road to consider options. I shut off the engine and did it the right way. Whew. That was close. One other time, I started driving and realized that I'd never actually seen the precise moment that the button materialized. I'd glance and it wasn't there. Then I'd glance back and it was there. Maybe it was me? Could the nav sense that I looked back and forth like one of those soap dispensers at better truck stops? I tried blowing on it. That didn't do it. A spitball? Nope.
I am a N.I.S. There's no turning back now.
boltjames
Navigation Idiot Savant
Old Apr 22, 2004 | 09:19 PM
TLGator's Avatar
:lol1:
Try some epoxy on the Navi screen. And a couple of extra clips. Also, debadge all the buttons. There, don't you feel better?
Old Apr 22, 2004 | 09:21 PM
lakeman's Avatar
I had issues with the "go" sequence at first myself. Then I found out that all I had to do when the screen went blank was to hit the joystick button twice and everthing was back to normal. Now I don't do any sequencing, just drive - much more fun - cause the NAVI is just two punches away.
Old Apr 22, 2004 | 09:24 PM
TLGator's Avatar
Joystick button TWICE? My God man! You're wasting precious finger muscle energy! Just press the MAP or MENU button ONCE! Or press the voice command switch ONCE!
Efficiency, sir! Be efficient!
Old Apr 22, 2004 | 09:27 PM
lakeman's Avatar
I'll have to try that. I found that if you had not acknowledged the "legal page" first that it would not activate the map. I will go out an try it right now. thanks.
Old Apr 22, 2004 | 09:44 PM
boltjames's Avatar
My son has one of those rubber-tipped suction dart guns so I've got an idea:
I think I can mod a headrest to launch a single spring-loaded dart at the nav screen to simulate the 'touch' of the OK button. There's got to be a way to gut a cellphone and use it's Bluetooth receiver as a detonator. If I can get to the protocol chip on the HFL's circuit board, I should be able to program a precise 'delay' to the pairing process so that the moment the OK button appears the HFL attempts to pair to the detonator and that'll launch the dart which will hit the OK button.
Anyone know XML? Anyone have a camel-colored rubber tipped suction dart? I'm going to need some help with this one.
Old Apr 22, 2004 | 09:47 PM
lakeman's Avatar
TLGator, tried it. didn't work for me. When I hit the map button after the screen when black, the legal screen came up again. When I tried voice commands, same thing. The reason I hit the joystick twice is to 1) acknowledge the legal screen, and 2) to get the map screen. By ignoring the NAVI for a minute or so, no "timing" or sequencing is needed. Just a quick "punch punch" on the joystick.
Old Apr 23, 2004 | 09:52 PM
TLGator's Avatar
lakeman - You're right, my idea was worthless. Thanks for the tip, I've started using it.
Old Apr 23, 2004 | 09:55 PM
GaleForce's Avatar
You touch my tra la la...
What is the issue? I haven't gotten my TL yet.
Old Apr 24, 2004 | 11:31 AM
lakeman's Avatar
The TL NAVI goes through a "boot up" when you crank the car. It takes a few seconds to get to this "legal disclaimer screen." After it shows up it takes about a half a minute- seems like forever if you are waiting to drive - before it posts an "OK" button. Then you can then hit the touch screen and the map comes up. The problem is you can't speed it up, but if you wait too long the screen goes blank. It took me a while to figure out how to get it back. Then I learned the little trick that when the screen goes blank to just hit the joystick button (push it in the center) twice and the map comes up. This saves the aggravation of trying to "time" when the OK button shows up.
Old Apr 24, 2004 | 12:02 PM
jjtags's Avatar
I don't always use the map on the NAVI so when I drive and the screen goes black and I want to see the audio selection (title and singer for XM for example, I just hit the Audio button and the audio screen comes up) The disclaimer is just for the NAVI (map) and you need to enter a destination while stopped anyway or before you move so just use the map when you need to.
I find that on my daily commute, I don't need the map functions so I just ignore it... sometimes I leave it black when I'm listening to FM and the station is displayed on the top of the dash where the clock and temp are.
Why use the energy when you don't need to. The double joystick punch is good to know about though. You learn something new everyday...
Old Apr 24, 2004 | 12:04 PM
GaleForce's Avatar
Ah, thanks for the info. I did notice it took a while to boot up. When I test drove the car I was sitting in the spot waiting for the OK button, and thought it was turned off for the demo model :p
Came up eventually though. Now I know what you are talking about.
Old Apr 24, 2004 | 12:56 PM
ramilford's Avatar
Energy?
You aren't saving much energy by having the display off. The gyros and nav system are "always on" and only the display can be turned off. If you don't need to refer to it, thjough, it can be distracting but don't turn it off to "save energy".
Old Apr 24, 2004 | 10:27 PM
jjtags's Avatar
I meant save your energy not the car's... If you don't need to use the navi, don't worry about pushing one Ok button or pushing the joystick twice.
No need to worry about the OK button if you're just driving to the store or to work. I'm sure you know the way...
I agree with ramilford that there's no savings on the car's energy by leaving the navi screen off but there's much to be saved in stressing about the OK button when you don't need to.
Old Apr 25, 2004 | 09:23 AM
TLGator's Avatar
What about the lifespan of the screen itself? Does anyone know if these things wear out? This is probably a stupid question, but I know very little about LCDs. Also, what about the touchscreen aspect? Can that wear out? Thanks in advance.
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
thegipper
Sep 28, 2015 01:01 PM
