I Refused to Believe I Would Be a Statistic
Old 07-19-2019, 01:59 PM
  #241
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Yeah, I wonder though if it may need some excessively long cure time because of your ambient humidity and temperature.
Can you bring it into work and park it in a vacuum chamber to pull down and get the glue to fully offgas?
Old 07-19-2019, 02:01 PM
  #242
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,651 Likes on 1,116 Posts
The weights were actually on the dash cover for about 13 hrs, so it should have cured by then, all to be undone in 5 minutes.
Old 07-19-2019, 02:03 PM
  #243
Acura TL Builder's Avatar
Use a strong glue like the goop mentioned above.
Its now a solid plastic. Nothing to crack.
With the time you’ve spent on this project. I feel it would have been better time spent by just replacing the dash.
I bet it could be done in less than a days work.
Old 07-19-2019, 02:15 PM
  #244
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
If I can't get this to work, then a dash replacement might be an option. However, I am trying everything in my power to get what I have to work. If I replace the dash, it will just crack again.
Old 07-19-2019, 02:29 PM
  #245
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
What does the service manual say as to how long it would take to replace, and how many people would it take to replace?
Old 07-19-2019, 04:10 PM
  #246
Null and proud of it
Midnight Mystery's Avatar
I'm almost to the point to tell you to put one tiny finishing nail over where it's coming up and just put a dot of black paint on it after.
Dash is ruined, nothing to loose now, and if it looks decent, heck! Go for it!
You're ultimately getting a new dash anyway at this rate.
Old 07-19-2019, 04:11 PM
  #247
Heck. Might as well do like 2G owners did with their transmissions and just buy two dashes. One for tjis year, and one for three years from now.
Spoiler
Old 07-19-2019, 04:15 PM
  #248
rockstar143's Avatar
Received 19,926 Likes on 14,464 Posts
have you considered maybe using thing steel bracing where it's buckling...maybe glue that to the underside of the cover to prevent it from even being able to bow.
Old 07-19-2019, 05:27 PM
  #249
Received 1,762 Likes on 1,416 Posts
You may have seen the thread below already?
It shows what's involved with a dash removal:
https://acurazine.com/forums/3g-tl-p...images-909544/
Acura TL Builder (07-19-2019)
Old 07-19-2019, 05:41 PM
  #250
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I don't follow.
The Coverlay is separating from the dash where the front windshield is, in between the tweeters. It's about three feet wide. I am gluing the center speaker portion down now, and will remove the weights tomorrow night, after being on the Coverlay for 30 hours. I hope that is enough time.
I still have not resigned myself to the new OEM dash yet. I'm hoping this works. If not, well, either I live with it, get a new OEM dash, or get a used TLX A-spec.
Old 07-19-2019, 08:04 PM
  #251
Not the Acura Camry A-SPEC!
Zetas suggested thread is two years old, and the OP there only spent $150 on the dash.
Perhaps use O-rings/grommets on all dash securing bolts to
allow for play?
Crossing my fwangas that the glue works for you!
Old 07-19-2019, 09:05 PM
  #252
cu2wagon's Avatar
Might as well just track down another Traverse.
Old 07-20-2019, 07:08 AM
  #253
I'm assuming coverlay is separating from the dash because of play in it...like it is bowing up. I was suggesting bracing it so it can't.
I don't understand though, if it's a solid piece and hard plastic to cover the dash...shouldn't it just sit on the dash? Shouldn't the glue just
ensure it doesn't vibrate and move?
Old 07-20-2019, 10:06 AM
  #254
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
That's my thought process as well, however, it bowed up from the expansion of the material.
I am planning on calling the manufacturing expert at Coverlay on Monday morning to figure out why it's doing that, and to see if they have anyone that knows the expansion rate vs. temperature graph, etc.
Old 07-20-2019, 10:07 AM
  #255
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
What car do you have?
Old 07-20-2019, 10:22 AM
  #256
cu2wagon's Avatar
A TSX wagon.
And a 4Runner.
Amongst other things.
Old 07-20-2019, 10:28 AM
  #257
I wonder if you were supposed to leave that bitch on the dash in the sun for a few hours first so it conformed and contorted and THEN glue that bitch down.
Acura TL Builder (07-20-2019)
Old 07-20-2019, 10:38 AM
  #258
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Not sure RS. The instructions don't mention that at all.
Old 07-20-2019, 10:41 AM
  #259
I know but as an engineer you probably are already trying to approach from all angles and understand.
Old 07-20-2019, 11:07 AM
  #260
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I still have the weight on the Coverlay around the center speaker.
Old 07-22-2019, 01:50 PM
  #261
TLNick's Avatar
Sorry gatr!
I was hoping this was going to work.
I'm thinking of maybe letting LineX spray mine down.
Old 07-22-2019, 02:40 PM
  #262
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Interesting path...
Old 07-23-2019, 09:00 AM
  #263
TLNick's Avatar
Interesting path...
Nah, I was just being sarcastic. Although, it probably wouldn't look worse than mine looks now.
Old 07-23-2019, 05:58 PM
  #264
Oem replacement
Old 07-23-2019, 06:00 PM
  #265
put balsa wood to support the part you fucked up...throw that suede bitch back on and get back to enjoy that fuckin lanai already!
Old 07-23-2019, 07:15 PM
  #266
True. Fill in the holes then conform suede or vinyl to it.
Kinda like an armrest or something. Just use spray glue and wrap away!
Old 07-24-2019, 06:11 AM
  #267
I mean people talk so much shit as if it's a shag carpet...
would I have preferred the look of OEM pretty brand new dash?! Sure...at what cost and trouble though. Then when I saw the replacement start cracking
I realized I didn't hate the suede enough to ever go down that road again. Not giving a fuck about the dash cracking anymore was a pretty priceless feeling.
Old 07-24-2019, 09:24 AM
  #268
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Because you're not bat shit crazy nuts like I am!
Old 07-24-2019, 09:26 AM
  #269
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Oh! So I figured out that so far, I am not going to add more glue to the front center where the front window vents are near the windshield. That is prime expansion and contraction real estate. It's noticeable to my OCD ass, but not all that much. I'm satisfied for now. Now if the airbag cover starts warping, I'm filling in the cracks and foam patches and inquiring about a vinyl or leather wrap for the dash.
Old 07-24-2019, 10:15 AM
  #270
how does it look now, let's see pics
Old 07-24-2019, 11:52 AM
  #271
cu2wagon's Avatar
Might be time to think about a VIP table to mount on the dash. Help cover up the busted up parts. Plus a place to put your dong pump and salt pipe.
Majofo (07-24-2019)
Old 07-24-2019, 11:57 AM
  #272
BreezyTL's Avatar
Right, all this talk and no pics. WTF!
Old 07-24-2019, 12:16 PM
  #273
I think that's your most permanent fix, IMO!
Old 07-24-2019, 12:18 PM
  #274
Old 07-24-2019, 12:40 PM
  #275
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Slpr04UA6 (08-01-2019)
Old 07-24-2019, 12:42 PM
  #276
dude, that looks great.
better than suede. Nicely done.
and I doubt you're more anal than me, just maybe more hard headed.
Old 07-24-2019, 12:50 PM
  #277
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Would YOU consider selling a car because the dash cracked?!
Check. Mate.
Acura TL Builder (07-24-2019)
Old 07-24-2019, 01:57 PM
  #278
BreezyTL's Avatar
Check. Mate.
Yes!
Old 07-24-2019, 03:14 PM
  #279
That cover looks very good!
Old 07-24-2019, 04:05 PM
  #280
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Thank you all. What you don't (necessarily) see is that the front part of the dash cover, near the windshield, is lifted up from the dash. I probably will leave it like that because no one else seems to notice (or care).
Quick Reply: I Refused to Believe I Would Be a Statistic
