HPT Rotating
Old Apr 27, 2004 | 01:38 PM
daven8844x's Avatar
HPT Rotating
Pardon my ignorance but I have the High Performance Tires. Are these directional tires? I need to know if I rotate F->R or criss-cross. Thanks.
Old Apr 27, 2004 | 01:49 PM
caball88's Avatar
if the tire has uni-tread(goes in one direction) then it cannot be rotated between left and right. a uni-tread tire has a distinct right and left tire and cannot be swapped. so you would just rotate front to rear.
Old Apr 27, 2004 | 01:50 PM
JoganJani's Avatar
never stops!
I've HPTs too. They are directional. Change from back to front and front to back. No interchange.
Old Apr 27, 2004 | 01:52 PM
rets's Avatar
Moderator Alumnus
My dealer changed my EL42s only between the front and the back. Is this the new trend to do so? Or they're just stupid???
Old Apr 27, 2004 | 03:38 PM
kelly408's Avatar
no, your dealer is probably not as stupid as they look. not sure what the EL42's are but if they are uni-directional, that means they only rotate one direction (yes, i'm a rocket scientist). therefore you can only swap front to back and vice versa. you can tell by looking at the arrow direction on the sidewall of your tires.
Old Apr 27, 2004 | 03:43 PM
JoganJani's Avatar
never stops!
Also, if the dealer criss-cross then does'nt matter. You'll have to drive in reverse.
Old Apr 27, 2004 | 05:18 PM
lakeman's Avatar
Talking
IMHO The HPT's are not directional. I rotated mine at 5K with the cross rotation. (as explaned in the manual) They are fine at 6500 miles. (No noise, good ride) The most important thing is to rotate them often. At least every 5K miles.
Old Apr 27, 2004 | 06:36 PM
rets's Avatar
Moderator Alumnus
Thanks. I thought Rocket Scientist should stay nearby Disney or Houston...
Unfortunately, we know EL42s are not uni-directional... :o
Old Apr 27, 2004 | 07:33 PM
Lore's Avatar
CEO, Team Anthracite
Take a look a the sidewall. If you see a little arrow-type figure with the word "direction" on it you can be sure that the tires are directional.
Old Apr 28, 2004 | 12:30 PM
kelly408's Avatar
i just checked my potenzas this morning and it doesnt look like they are uni-directional. lakeman is correct. you can change them any which way you want. i didnt want to comment on this yesterday until i verified it.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
