HELP! Getting these codes!!
Old Mar 2, 2024 | 09:32 AM
MRTL06's Avatar
Vtec Powaa
Exclamation HELP! Getting these codes!!
There is no engine light btw but when the shop scanned the OBD2 with their snap on scanner all this came up:
P2243: HO2S (A/F Sensor) B1S1 VCENT Line Voltage High
P0700: A/T System Malfunction
P0848: 3rd Pressure Switch Circuit High (Got this part: HYXUAN Transmission Pressure Switches 2ND-3RD Automatic Oil Pressure Sensor Switch Set Compatible With Hon-da 28600-P7Z-003+28600-P7W-003, From Amazon, replaced the black one only but D light started flashing after a short drive)
And THese: 11-1, 13-1, 15-1, 17-1, 32-1, 34-1, 36-1, 38-1, 41-1.
Old Mar 2, 2024 | 12:47 PM
Pair of TLs's Avatar
For the umpteenth time, DO NOT buy these pressure switches from ebay or amazon!
Old Mar 2, 2024 | 01:23 PM
MRTL06's Avatar
Vtec Powaa
Old Mar 2, 2024 | 02:18 PM
jeffstlnote's Avatar
Look, I'm really not bashing. I'm not trying to preach either. Poster is 22, and trust me I get it. When I was 22 it was all about money/cost. I'm not implying that's the case here but I suspect it probably is. My lousy 2 cent advice...don't do that. Who knows what you're getting from Amazon, much less and worse Ebay. OEM is $74.95 a piece for those pressure switches.
I think I found the ones you got off Amazon - they were $17.99 to $20.99 for both. Again...I get it, but it's cheap for a reason buddy.
Old Mar 2, 2024 | 05:37 PM
MRTL06's Avatar
Vtec Powaa
Ordered a new 3rd gear pressure switch. Cleared all the codes and im not getting any TPMS codes anymore only:
P0848 3RD pressure SW circuit high, P0700 A/T System malfunction, P0443 EVAP canister purge valve circuit malfunction, and 22-1 Left front pulsar failure (This was after replacing the speed sensor, had this code ONLY for the FR but now seems to be on for the FL now) and 84-1 Sensor logic failure
Old Mar 3, 2024 | 02:16 PM
MRTL06's Avatar
Vtec Powaa
bump
Old Mar 3, 2024 | 04:14 PM
where did you order the switch this time? Confirming the part number
Old Mar 3, 2024 | 04:51 PM
I thought you were working on / took care of the 'pulsar' issue with a wheel bearing replacement on the thread below?
ABS Light Code 11-01 and 13-01 and Ebrake light - AcuraZine - Acura Enthusiast Community
Old Mar 3, 2024 | 09:11 PM
MRTL06's Avatar
Vtec Powaa
That was for the right side. Now after fixing it showed up for the left side.
Old Mar 3, 2024 | 09:12 PM
MRTL06's Avatar
Vtec Powaa
28610-RKE-004, https://www.torontohondaparts.com/oe...re-28610rke004
Hay otsuka
Mar 11, 2020 10:01 PM
jonnieh
1G TSX Problems & Fixes
Feb 11, 2014 09:01 AM
hondakid23
Apr 4, 2013 12:37 AM
ep3kid914
Jun 20, 2012 08:59 PM
dc2kid
Oct 19, 2009 09:13 PM
