Check emmisons light plus more
I have a 2006 acura tsx my dashboard is looking a lot like Christmas lol.... I have the VSA, ABS light, and check emmisions light on. I know I need a new Abs sensor for the front driver side which comes in tomorrow but these are the codes I got when scanned P1157,P0706,and P0134. Any one know what I need to fix these solutions. Thank you guys!
P0134 - Air/Fuel (A/F) sensor heater malfunction (not circuit fault!), so reset and see if it returns. If it returns, replacement is indicated. Check carefully for corrosion of A/F sensor/harnss connection or dirt/oil in connection.
P1157 - Possible fault in A/F sensor harness causing high voltage.
P0706 - electrical fault in trans range switch or switch circuits. Lots of trouble shooting, but could be dirty connection again.
All of these start w/ a system reset to see what codes comes back. Suggest resetting system w/ Obd2 scanner and rechecking if CEL comes back again (very likely).
Any recent experience w/ immersion of car or exposure to road salt spray?
good luck
good luck
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
HeloDown
Sep 8, 2015 06:51 PM
