Help: Compatibility
Old Feb 28, 2015 | 03:40 PM
Tylervuu's Avatar
Help: Compatibility
Are 2008 base model TL bumpers compatible with my 2006 base model TL?
Any help is appreciated!!
Old Mar 4, 2015 | 03:53 PM
EvilVirus's Avatar
The answer to your question is YES
You should take the time and search the forums as it will help you understand your car better.
Old Mar 4, 2015 | 04:40 PM
a couple of threads BELOW yours is this thread
https://acurazine.com/forums/third-g...bumper-926800/
Originally Posted by 04WDPSeDaN
All 3rd gen bumpers can be used for each model year. The TL body doesn't get wider, smaller or longer. A few key notes:
- 07/08 have lower foglights
- 07/08 have different grills and grill trim
- 07/08 base and Type-S A-spec kits are different from each other also different from 04-06 A-spec kits.
If you get a bumper cover you will still need the following
-Fog light housings
-Fog light harness
-Bumper Grill trim
-Grill
-Hood grill trim
-Lower grill vents (Except if you get the A-spec kit you won't need these)
-Acura center grill trim.
-Bumper might need painting depending if you get one used or new
-A-spec OEM kit comes painted.
before
after
Old Mar 9, 2015 | 07:36 PM
Tylervuu's Avatar
Heres my 06 base model TL with an 07/08 a-spec lip.. Theres placement for my foglights on my lipkit, however it doesn't correspond to my bumper / fit correctly. I'm just trying to install my oem TL foglights but my bumper doesn't allow it.. How would i make this work?
Old Mar 23, 2015 | 11:46 PM
Tylervuu's Avatar
I still need some help!
Old Mar 24, 2015 | 07:22 AM
Installed Type S a spec bumper, you'll need Type S fog lights
Old Mar 24, 2015 | 08:56 AM
EvilVirus's Avatar
FYI there is no difference in the fog lights of the 07-08 base and type-s.
OP as you stated, it doesn't correspond to your base bumper; so your options are to either modify it i.e. cut an opening so the fogs will fit or buy a 07-08 bumper.
Old Mar 24, 2015 | 09:02 AM
Tylervuu's Avatar
I already have the 07-08 fogs but it won't fit because of my bumper
Jul 16, 2017 07:33 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
lanechanger
Oct 13, 2015 10:56 AM
adreano17
Sep 29, 2015 08:48 AM
