Help: Compatibility
Are 2008 base model TL bumpers compatible with my 2006 base model TL?
Any help is appreciated!! |
The answer to your question is YES
You should take the time and search the forums as it will help you understand your car better. :2cents: |
a couple of threads BELOW yours is this thread
https://acurazine.com/forums/third-g...bumper-926800/
Originally Posted by 04WDPSeDaN
(Post 15352139)
All 3rd gen bumpers can be used for each model year. The TL body doesn't get wider, smaller or longer. A few key notes:
- 07/08 have lower foglights - 07/08 have different grills and grill trim - 07/08 base and Type-S A-spec kits are different from each other also different from 04-06 A-spec kits. If you get a bumper cover you will still need the following -Fog light housings -Fog light harness -Bumper Grill trim -Grill -Hood grill trim -Lower grill vents (Except if you get the A-spec kit you won't need these) -Acura center grill trim. -Bumper might need painting depending if you get one used or new -A-spec OEM kit comes painted.
(Post 15352184)
before
https://farm7.staticflickr.com/6117/...4fbd09bd_o.jpg after https://lh4.googleusercontent.com/-9...o/DSC_8979.jpg |
https://cimg3.ibsrv.net/gimg/acurazi...81bd9aee4e.jpg
(Post 15356141)
https://acurazine.com/forums/third-g...bumper-926800/ Heres my 06 base model TL with an 07/08 a-spec lip.. Theres placement for my foglights on my lipkit, however it doesn't correspond to my bumper / fit correctly. I'm just trying to install my oem TL foglights but my bumper doesn't allow it.. How would i make this work? |
I still need some help!
Originally Posted by Tylervuu
(Post 15377837)
FYI there is no difference in the fog lights of the 07-08 base and type-s.
OP as you stated, it doesn't correspond to your base bumper; so your options are to either modify it i.e. cut an opening so the fogs will fit or buy a 07-08 bumper. |
(Post 15377983)
Installed Type S a spec bumper, you'll need Type S fog lights :)
