G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
Old 02-26-2012, 02:16 PM
  #721
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
I have hyperflashing and I only have LED's in the rear. Do I need a.12 or a .24 resistor?
Old 02-26-2012, 02:47 PM
  #722
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ if you plan to get the LED's upfront then get the 0.22 or 0.24 and call it a day....
if you plan on NEVER getting the LED's upfront then 0.12 will work (0.24 will work as well)...
TLDude876 (02-26-2012)
Old 02-26-2012, 04:21 PM
  #723
Silvertl88's Avatar
Originally Posted by swoosh
^^^ looks good bro....but y dont u just roll the windows down rather than opening the door again and again LOL
thanks Swoosh...that would have been too easy haha
Old 02-26-2012, 04:26 PM
  #724
TLDude876's Avatar
If I ever get LED's up front, can I solder 2 .12 ohm resistors in the one spot?
Old 02-26-2012, 04:42 PM
  #725
swoosh's Avatar
hahaha....that is ture
Yezzir....
but remember in series and not in parallel....
so it would be like this : -=R1=-|-=R2=-
or you can just remove that 0.12 and solder a 0.24
Old 02-26-2012, 08:24 PM
  #726
vietxquangstah's Avatar
If you mean "can I solder one .12 resistor in for now, than when I get LEDs for the front can I go back and solder an extra .12 resistor to the one that is already in place" The answer is !
Why? Because if you have 1 resistor soldered in place and 2 months later decide to get LEDs for the front, when you go back to solder in the other 0.12 resistor to the 0.12 that is already soldered in place, you just soldered them in PARALLEL which makes the resistance value go DOWN to 0.06.
I would recommend you to save yourself the hassle and just go ahead and solder a 0.24 resistor in place that way you are safe and can run 0 LEDs, 1 pair of LEDs for the rear, and can add LEDs for the front whenever you'd like without having to open the relay and solder again.
TWO 0.12 ohm resistors soldered in SERIES will also work.
THIS IS AN EXAMPLE OF TWO 0.12 RESISTORS SOLDERED IN PARALLEL - THIS IS WHAT YOU DO NOT WANT TO DO
When you solder two 0.12 ohm resistors in parallel like that, total resistance will total 0.06 ohms which WILL NOT work for FR and Rear. You need 0.22 or 0.24 which will require you to SOLDER THEM IN SERIES like this
swoosh (02-26-2012)
Old 02-26-2012, 09:49 PM
  #727
swoosh's Avatar
^^^ VIET, great great pix bro....
i believe he was saying in 1 spot as in jam 2 resistors, hence i, mentioned do it in series....i doubt he meant one on top of the other but its always great to clarify and your pictures do that
Old 02-26-2012, 10:44 PM
  #728
Shoeface's Avatar
WOW....really bro ? I am using the 0.22 ohm resistor which i send you....i got 2 of them in, using 1 and send the other one to you....and the hyperflash is gone
did u solder it properly or why didnt the first one work ???
I think I just F'd up the relay the first time using the 0.12 resistor. I haven't replaced the shunt resistor in the new relay yet, but well get to it next week sometime.
Old 02-26-2012, 10:48 PM
  #729
swoosh's Avatar
^^^ LOL....
well make sure this time you do it with care
if your up in KC, holla, will do it for you...
Old 02-27-2012, 11:11 AM
  #730
2007 6SMT Type-S
SurfingScotty's Avatar
Here is some pics and video of what the V-LEDS 1157 60 SMT 6K switchback looks like in oem 08 type s headlights. The amber reflector is still in there and you can only see it at night and does not effect the light output.
i love this mod!
http://youtu.be/IP8eDr5anIQ
This is how mine looked, too. Only once the parking lights had been on for about 10-15 mins, I would turn on the (let's say) left blinker which would flash orange but at the same time, the right blinker would flash white only with less intensity. Go drive around the block and check again before you start jumping for joy.
Note: I also have rear LED’s and they have never flashed any other way than how they are supposed to, even with the front’s going haywire.
Old 02-27-2012, 08:18 PM
  #731
Chapter Leader (Midwest Region)
McCollins23's Avatar
Finally got around to installing my resistors today. I put 2 .12 ohm resistors in series in, works great. Thanks to Silvertl88 for the resistors and OP for making this thread.
Old 02-27-2012, 08:58 PM
  #732
swoosh's Avatar
^^^ bitch you didnt thank Niki Minaj this time around....WHY ??? WHY ???????
Old 02-27-2012, 10:36 PM
  #733
HaHaHaHa
Old 02-28-2012, 08:58 AM
  #734
Silvertl88's Avatar
they have been working as they should for a couple days now so i think all is good but i will continue to check...thanks
Old 02-28-2012, 11:46 AM
  #735
Got The Midas Touch
MOS805's Avatar
Damn now if I could only figure out if this works for my Avalon, I loved it with my TL's switchbacks. I been searching but I have found 0 people that have done switchbacks or LEDs for their turn signals on an Avi .. It seems like I will be pioneering some things with my new car, hopefully not all will fail lol.
Old 02-28-2012, 01:23 PM
  #736
rockstar143's Avatar
Received 19,991 Likes on 14,500 Posts
I'm sure you can just do whatever ebay switchback bulbs and just do the normal resistor you crimp on...
or look under your dash, I BET you have a similar module. OR, maybe Toyota's don't hyperblink with LEDS.
Old 02-29-2012, 06:31 PM
  #737
Mondo375's Avatar
This DIY is awesome! Thanks to this thread and SilverTl88 for the resistors! No more hyper flashing! The Mrs. Will be pleased, she hated it lol
Old 03-08-2012, 10:39 PM
  #738
04TL4P3's Avatar
without reading through 20 pages, where can i find the .24 resistor?
Old 03-08-2012, 10:44 PM
  #739
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
http://search.digikey.com/scripts/Dk...09436382923742
You have to buy a minimum of 10, which ends up costing like 4 bucks.
Then you sell your extras and profit
OR you can see if anyone has any extras
Old 03-09-2012, 10:27 AM
  #740
swoosh's Avatar
^^^ GP for President
guitarplayer16 (03-09-2012)
Old 03-09-2012, 12:15 PM
  #741
04TL4P3's Avatar
Ok thanks, anyone have an extra before i order some? Also whats a good alternative to the $80 vled brand amber turn signal bulbs?
Old 03-09-2012, 10:42 PM
  #742
If you're looking for ambers, I can only recommend two.
1. 120SMT bulbs from Autolumination.
Most say it's a hit and miss for autolumination but I specified the "heavy duty" ones, so they sent me those and it's been good so far! VERY bright.
I run them, and so does bforbrian who recommended them for their brightness.
It's $30 per bulb.
2. Elef bulbs.
These are the "premium" of bulbs.
VERY high quality and low failure rate.
Roger555 uses them, and he knows his LEDs.
This bulb's for reliability.
$35 per bulb
http://www.elef-usa.com/apps/webstor...s/show/1200203
I know I've said this before, but I feel like buying every "top" LED bulbs out there and seeing which one is the best lol
Old 03-17-2012, 01:56 PM
  #743
Mondo375's Avatar
Im on almost a year with my 120 vled ones.
Old 03-17-2012, 02:23 PM
  #744
swoosh's Avatar
Yeah i would never order from Autolumination again....i had 3 sets of 60-60SMT fail on me....
and they are 30 bucks a pop....so you pay 60 + shipping and then have to pay to ship back to them and back to you and back to them and back to you....no sir....i didnt sign up for this shit....
i might order from VLED.....this go around....
I have all LED's in my car from superbrightleds and damn 4 years no problems....
Old 03-17-2012, 05:22 PM
  #745
Shoeface's Avatar
FYI - Round 2!
I finally swapped out the shunt resistor for the 0.12 ohm resistor on my new turn relay and everything is kosher!
Old 03-17-2012, 11:31 PM
  #746
swoosh's Avatar
^^^ Dave, sweeeet !!!!
what went wrong the first go around ???
Old 03-18-2012, 09:13 AM
  #747
Shoeface's Avatar
I think I just fried it by making it too hot when I tried to put on the first resistor. It worked, but only for a little until it died. Since it worked for a little, that's the only thing that makes sense to me.
Old 03-18-2012, 10:01 AM
  #748
stavebomb's Avatar
I've had this mod done since August or September and a pair of 60led switchbacks blew out within a couple weeks. I replaced them with only amber leds an so far it's been fine. I have noticed they make a weird noise when I lock or unlock the car. Anyone else experiencing this?
Old 03-18-2012, 11:28 AM
  #749
swoosh's Avatar
^^^ yes that is just from the relay and completely normal.....
where did you get your switchbacks from ??? it is was autolumination, I have had their switchbacks die out on me within couple days.....and not 1 set, 3 sets.... am never gonna buy from them again !!!
try VLED's or superbrightleds.....
Old 03-19-2012, 10:11 AM
  #750
awz05TL's Avatar
Question
Guys, so yesterday I put in my switchbacks and my headlights look awesome. def getting the look i want but now my side markers are not working, both front and back. i have two .12 resistors since i have leds in front and back, has anyone else encountered this issue or have any suggestions on what could have gone wrong? cause i have no idea.
Old 03-19-2012, 10:43 AM
  #751
Haven't heard anyone else complaining of this...did your solder run across to another point on the board? Did you reinsert the relay fully? Try pulling your switchbacks to see if everything goes back to normal.
Old 03-19-2012, 11:08 AM
  #752
awz05TL's Avatar
Alright, let me make a correction and I might sound dumb now too! lol! the side markers are working when I turn on my headlights but for some reason I am thinking that they blink as well when we turn on the turn signal, does that happen or am I just imagining? lol
Old 03-19-2012, 12:15 PM
  #753
swoosh's Avatar
^^^ ahahaha Awaz....you cracked me up with the text LOL....
its all in your head bro....the side markers do not blink unless:
1> you heavily mod them
2> get the USR blinking side markers (which are not out yet)....
Old 03-19-2012, 12:22 PM
  #754
sidemarkers never flashed when hitting turn signal. the only time they flash is when you hit the unlock button on the key lol
Old 03-19-2012, 12:42 PM
  #755
skd2k1's Avatar
bump...asked this question before but I think it got lost in the convo!
if I wanted amber LEDs that blink only, no parking lights, is that possible without getting the hyper blink? anyone else done this? thanks in advance.
Old 03-19-2012, 12:48 PM
  #756
swoosh's Avatar
^^^ against the laws but all you need to do is pop the middle wire out.....
so the lights wont come on, all that will happen is blink when you indicate....but since you are getting LED's it will hyperflash !!!
Old 03-19-2012, 12:57 PM
  #757
awz05TL's Avatar
lol, yeah right after i asked the question I was like, "am i imagining that they blink when they really dont?" lol! I feel so smart right now!
Old 03-19-2012, 01:02 PM
  #758
^^^we coulda had some serious fun with you...
Old 03-19-2012, 02:18 PM
  #759
awz05TL's Avatar
lol, I bet!
Old 03-19-2012, 02:55 PM
  #760
skd2k1's Avatar
yeah, the hyperflash is what I'm trying to avoid...would it be possible to get a single filament (flash only) led bulb and put that in there with out a hyperblink??
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
