finally debadged
Old Oct 4, 2004 | 09:15 AM
badboy's Avatar
finally debadged
so I finally debadged athena. It looks awesome, such a clean look. I will post picture tomorrow. I have redondo red.
If I look closely where the letters used to be, I can see faint outline of the letters, I guess its probably glue, you guys experience this? what can I use to get that off without any damage to the paint?
Thanks for the replies.
Old Oct 4, 2004 | 09:29 AM
te3point5's Avatar
The outline is probably from the fact that there is wax around the letters, but not under them. Just wash and wax the car and it should look fine.
Old Oct 4, 2004 | 09:35 AM
PoochaKannInc's Avatar
Shift_faster
After the paint has been exposed to the elements for a while, the color is slightly off from the original color (which is why it is harder to match body kits and the sort to a car that has 20K miles on it rather than just 1K).
If the surface is smooth, it is not glue. Try the good wash & wax method that te3point5 mentioned, and if it there is a faint outline still present, it should fade as those sections are also exposed to nature like the rest of your paint.
Old Oct 4, 2004 | 09:37 AM
J RIDE 81's Avatar
Team Nighthawk Director
Wax usually will do the trick. G'luck!
Old Oct 4, 2004 | 12:40 PM
whiteTL's Avatar
I debadged my car a week after I got it =X
Old Oct 4, 2004 | 03:47 PM
niz181's Avatar
wax will fix the problem
Old Oct 5, 2004 | 03:17 AM
whiteTL's Avatar
You can use Meguiars Scratch X. That removed most of my blemishes and scratches on my car.
Old Oct 5, 2004 | 01:04 PM
DFBRL8R's Avatar
Where's the pix?
Old Oct 5, 2004 | 01:11 PM
badboy's Avatar
the pics will be here later on today
Old Oct 5, 2004 | 01:35 PM
ludachrisvt's Avatar
Wants an M3 in
someone had to do it ...
Old Oct 5, 2004 | 05:39 PM
badboy's Avatar
need help posting pictures....who do I go to? I don't have a web page to put the pics on.
Old Oct 5, 2004 | 09:27 PM
tigetech's Avatar
Miss my 89 Legend
debage is cleaner look... heres a pic
Old Oct 5, 2004 | 11:46 PM
MrGQDieselNY's Avatar
What rims you got there homie? any pics?
Old Oct 6, 2004 | 12:20 AM
caball88's Avatar
ummmm the tires like like they have been installed backwards. i dunno what type of tires they are but from the tread they look like uni-directional tires. meaning there is a left and a right side to them. i thought that all uni-directional tread should point foward.
Old Oct 6, 2004 | 09:30 AM
JetJock's Avatar
I think the tires are backwards too...every car I've seen with a tread pattern like that have the tread pointing in the direction of travel. Mabe he drives fast in reverse and wants them that way????
Old Oct 6, 2004 | 09:35 AM
badboy's Avatar
can anyone help me put some pictures on this thread?
Old Oct 6, 2004 | 09:39 AM
havokgroup's Avatar
Looks like the tires need to be flipped. The "debadged" looks good.
Old Oct 6, 2004 | 09:43 AM
willz822's Avatar
Isn't that how the tread pattern is supposed to be. If you think about it, the contact patch, where the tires actually make contact with the road, the tread appears to be in the right direction. Isn't the pattern supposed to sweep water away from front to back??? That V pattern would suggest so.
Who knows.....I could be wrong.
Old Oct 6, 2004 | 10:25 AM
Ron A's Avatar
Administrator
All the tires pictures in Tire Rack have the tire mounted on the wheel with the grooves pointing in the same direction as the car in this thread. Here's a sample http://www.tirerack.com/tires/tires....omCompare1=yes
Old Oct 6, 2004 | 10:40 AM
badboy's Avatar
I don't think it matter which direction the tire is mounted on the wheel, the key information is which side of the car is the wheel going to be put on. from looking at the picture on tirerack, it seems that the wheel would be mounted on the drivers side of the vehicle.
In the picture above, it looks like the passenger side back wheel should be mounted on the drivers side.
Old Oct 6, 2004 | 12:03 PM
Ron A's Avatar
Administrator
It definitely matters which direction the tire is mounted on the wheel. That is why all directional tires have a statement on the sidewall that says something like: This side must face out, or words to that effect.
If you put it on the wheel inside out, it will still be inside out regardless of which side of the car it is mounted.
The following is from the Tire Rack Owner’s Manual:
Directional tires only: Refer to the "rotation arrow" branding on the tire's sidewall. The arrow indicates the direction in which the tire should turn.
Asymmetric tires only: All tires should show sidewall branding indicating side facing outward.
Directional and asymmetric tires: Look for "side facing outwards" branding. Look for "rotation arrow" to determine side of vehicle.
Old Oct 6, 2004 | 12:12 PM
badboy's Avatar
I agree with you Ron, but what I meant to say what that once you have the tire on the wheel, you can easily tell which side( either drivers or passengers) of the car the tire should be mounted, depending on the unidirectional tread. From the picture on tirerack, it looks like the wheel, with the tire on, should be put on the drivers side. Same applies with the picture shown above.
vpasla1
Sep 17, 2016 07:24 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
