Exhaust Ideas
Check the sticky thread with the Comptech catback sound clip. That is the only full out-the-box catback exhaust out there. There are pics of a Mugen exhaust but no other information.
Some people have just changed the mufflers to Magnaflows, or played around with taking out one or more resonators.
Depends on how much you want to spend. I like the looks of the comptech system except for the tips dont line up with the bumper (personal opinion on this). I swapped the two rear mufflers for small magnaflow mufflers, have cut out the front resonator and replaced it with a magnaflow one and for a couple weeks left the middle muffler on. Just recently (this past week) I cut out the mid muffler and welded in a straight pipe. My tone sound pretty much the same as the comptech one. I am trying to get a good quality sound clip up but am having some problems. To retain the stock look I cut the tips off of the OEM system and welded them to the new mufflers.
Opting for the comptech system gives you only one option for the sound unless you want to go through the process of either removing or adding another SS resonator and then tig welding (so no rust) it on there. I gave myself a little versatility because I was not sure how the exhaust was going to sound. The system you choose depends greatly on what you are looking for (ie tone, interior resonance, pitch, etc).
Originally Posted by VelfarreClubber
I like how the g35 coupe sounds, is it possible i can swap out the mufflers? will it sound the same/similar?
In contrast, the TL has 2 mufflers each with 1 exit point
For the rear mufflers I used 11375 (you can get them in stainless) and just a regular 4" round magnaflow resonator for replacing the front one. I left the midmufler alone originally, I was going to put in a 6" round magnaflow but instead just welded in a straight pipe.
Originally Posted by roho96
Does the 05 TL have true dual exhaust?
starts as dual, off the engine....
comes together in one pipe....
and back out to dual at the back of the car
joflewbyu2
10-08-2015 11:16 AM
SUPRMN84
10-07-2015 09:46 PM
johnpancakes014
09-27-2015 12:58 PM
