Dumbfounded on 05-08 TL's
I'm in the gist of purchasing a new TL and I and I'm lost!
I don't get it...The 2005 TL has 270hp, and the 2006-08 have 258hp. Am I missing something here? I know features were upgraded, but doesn't it make more sense to get a 2005 with all due respect? Or was there a issue with the 2005 TL 270hp being the reason Acura downgraded to 258hp the following year.
They all have 258hp. Acura changed the way it reported horsepower in 2006. Only the TL-S has a different hp rating @ 289hp.
This thread might explain in more detail:
https://acurazine.com/forums/showthr...ght=hp+270+258
Torque steer is a very controversial topic here. You'll get mixed opinions.
If you want to test for torque steer, you simply let go of the wheel at a standstill, and then hit the accelerator and watch the steering wheel to see if it jerks one way or the other.
Thanks! I'm got a appt. for a t-drive... i will look for this especially! Unless there are other issues....I know what to look for in the tanny(having a 02 TL) but the 05 seems pretty solid.
-Thanks again!
-Thanks again!
torque steer isn't a problem unless you let go of the wheel and punch it. the 06 TL's got a torque limit system which cuts torque output in first and second gear to help stop torque steer for the older folks who buy the TL.
Is the torque limiting disabled when the VSA is turned off?
.....not to hijack the thread, but I thought it was in the Manual trans. Something about shifting into third gear?
I think I asked about it in my very first post....
https://acurazine.com/forums/3g-tl-2004-2008-93/new-acura-forum-board-702701/
Replied here:
Replied here:
There isn't any issue with the TL auto transmissions from mid-2004 onwards (the early 2004s had a recall to install an oil jet, IIRC).
The 3d gear issue is with the manual transmissions-- some owners have had issues with the transmission popping out of gear or not shifting well in 3d gear-- which was alleviated by switching to either a GM transmission fluid or different trans fluid formulation.
The '06 has a tire pressure monitoring system which the '05 does not have.
Welcome to AZ and G/L on your search!
Good luck on your search! I think the only people who have problems with torque steer are those that come from RWD or AWD cars (like myself). It is very different for me to have the car pulling one way or the other during WOT. It definitely makes acceleration more exciting (that's the way I am looking at it lol)! I miss AWD... notes to self are that next car should be Turbo AWD.
https://acurazine.com/forums/showthread.php?t=702701
Replied here:
Replied here:
https://acurazine.com/forums/3g-tl-problems-fixes-114/04-auto-transmission-worries-new-user-forum-637673/
There have been other threads as well. Each transmission, be it auto or manual, can have problems and should be looked at and test driven before purchased.
read this thread - especially post #33 by 01tl4tl
https://acurazine.com/forums/showthread.php?t=637673
psheu
Mar 17, 2009 06:20 PM
