DRL Bulb only for DRL?
Old Nov 6, 2006 | 11:01 PM
tidus888's Avatar
Team Anthracite
I find this weird....
I realize that when you use low-beam or high-beam.. it all comes from the projector.... so what is the use of the middle light... only for DRL? (i am in canada btw)
Old Nov 7, 2006 | 09:29 AM
tidus888's Avatar
Team Anthracite
anyone?!?!?!
Old Nov 7, 2006 | 02:04 PM
07 TL-S's Avatar
I have a 07 TL-S and it's only for DRL, not sure about the 07 base model TL, but I would assume it's the same.
Old Nov 7, 2006 | 02:21 PM
csmeance's Avatar
in 06 and prior, it is a fog.
Old Nov 7, 2006 | 02:24 PM
CometVR4's Avatar
Is it a Flash-to-Pass also? I hate flashing the HIDs...I feel like I'm damaging the unit.
Old Nov 7, 2006 | 02:35 PM
csmeance's Avatar
the HIDs have a shutter in them that opens when the highs are turned on. The acutal voltage of the bulb is never increases. The projectors are meant to open up more so highs can be turned on, so they must be engineered to that standard, so they souldn't be obtaing any damage.
Old Nov 7, 2006 | 04:29 PM
rockyfeller's Avatar
King of NYC
Yeah but there is huge burst of power from the ballast required for ignition of the light. I'm sure if you used flash-to-pass a lot it's not gonna last in the long run. Plus the bulbs have a warm up period, you can notice how the bulb color temperture changes at startup.
If you had to use it, I'd flash at longer intervals...(i.e. don't rapidly flash, maybe pull the turn stalk for a couple seconds at a time and no shorter. And don't flash more than a couple times.)
I like to use flash to pass as well and I've been so used to flashing so fast it looks like a strobe. It freaks some dumb drivers they pull real fast thinking I'm a cop at 1st glance. Guess I can't do that anymore with my TL.
Old Nov 7, 2006 | 08:28 PM
CometVR4's Avatar
Yes. I was referring to when the headlights were actually switched off and I flash the Highbeams...
Old Nov 7, 2006 | 08:32 PM
tidus888's Avatar
Team Anthracite
i am talking an 04-06 TL
Old Nov 7, 2006 | 10:02 PM
Actuary's Avatar
18,000mi. 29000km
in Canada, flash to pass will activate HID. I turn on my low beam then start flashing
hashbrown
Feb 18, 2022 11:20 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
ripit
Sep 26, 2015 06:19 PM
eastcoastguy
Sep 23, 2015 06:29 AM
