Does the ASpec Body Kit Actually Improve Handling / Performance?
RBP > WDP, NBP, SSM etc
1 Post
Hey Guys
so after I finally got my ASPEC Body Kit put on, NO SPRINGS, just the body kit, obviously the car looks "more aerodynamic" but I don't feel any difference in handling...although everyone I speak to says, "oh you have a body kit now, your car should handle a bit better/you should feel a slight difference"....
I did it purely for looks and that's all I expected...
can you guys confirm/deny this?
its more for looks than aerodynamics, it should only help when going maybe 130+, but maybe, it could hinder performance due to added weight, but its just a thought.
Three years ago, when Acura was actively marketing A-Spec for the 3G TL, it was advertised as reducing the coefficient of drag somewhat. In theory, therefore, it does help performance and gas mileage, at least minimally.
.:KCCO:.
in theory, it does.
in actuality, it doesn't. to feel any effect, you will need to be going very very fast.
a rear spoiler will not have useable downforce unless you are going close to 180mph. at that point, it is helpful.
1 Post
actually, I heard, that if you put a sticker on each skirt, only ONE, of the vinyl type, it will cause the inertia of the air which registers a density of less than .8, to hyper ventilate causing a more fluid response while turning the car at an embankment of 16 degrees or more on concrete roads while temperatures of the air are above 82 degrees farenheit with a dewpoint wet bulb reading of -0.5
1 Post
Originally Posted by acjetter
you should just hand over your keys if you think a body kit going to make a difference in how the car handles.
Originally Posted by zoostation
Does the A-Spec suspension lower the car?
Its the rear sway that makes a big difference in cornering. Much less body roll.
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
1fatcrxnem1
22
06-01-2018 01:23 AM
Zonian22
11-14-2015 01:20 PM
09-04-2015 08:03 AM
Zonian22
09-02-2015 08:19 AM
