climate control "auto" button
Old Nov 28, 2004 | 05:53 PM
vp911's Avatar
hi... i just noticed in some pictures of the tl dash... there is an "auto" button for BOTH the driver and passanger... why is that?
can the air flow for both people be controlled seperately?
Old Nov 28, 2004 | 06:00 PM
varanelli's Avatar
Yes.
92NSX's Avatar
RTFM.
Both front sides have climate control.
Old Nov 28, 2004 | 06:31 PM
ResearchFreak's Avatar
"HMS Ruby"
The fan speed has to be the same on both sides, but you can adjust the temperature and where the fan blows on each side separately.
Old Nov 28, 2004 | 06:38 PM
vp911's Avatar
ok, so then why the auto button on both sides?
Old Nov 28, 2004 | 07:07 PM
Repecat's Avatar
Gratis dictum
Because if you select a different mode on one side, it is no longer on "auto". The other side will remain on automatic.
Old Nov 28, 2004 | 07:08 PM
baby_igor's Avatar
And the DUAL light will illuminate letting you know your HVAC systems are autonomous
Old Nov 28, 2004 | 08:19 PM
clocks's Avatar
I have a question about "Auto". Does the AC always run when you have Auto on, even if it is blowing warm air? I thought I read this a while back, that the air compression runs 100% of the time when you have AUTO set.
Old Nov 28, 2004 | 08:55 PM
tophfisher's Avatar
8th Gear
I also have the same question about A/C
Old Nov 28, 2004 | 08:58 PM
badboy's Avatar
yes, when you have auto on, the ac compressor runs all the time, even if it is blowing warm air.....for times when you need heat, turn off a/c by pressing the a/c button, it will display "a/c off" and adjust the temperature...thats what I do.
Old Nov 28, 2004 | 09:18 PM
clocks's Avatar
Thanks.
Kind of defeats the purpose of having an "auto" function, as it switched off when you manually turn off the a/cc. I won't use it during the winter as I don't want the hit to my gas mileage.
Old Nov 28, 2004 | 09:23 PM
caball88's Avatar
Originally Posted by clocks
Thanks.
the a/c acts as a dehumidifier when the heat is on. so when you use the auto function in the winter it does serve a purpose. plus the actual effect on gas mileage is pretty minor. i think there was a 1-2 mpg difference with a/c turned on vs off. there was more of a difference when in slow moving traffic but most of the time traffic was relatively smooth.
Old Nov 28, 2004 | 09:24 PM
chas22's Avatar
A/C runs in auto
I think Honda really goofed on this, You would think that if the A/C shows nothing at all that it should be off by default. Just bewere that if you push auto, you also need to push the A/C button so it says off or you will be running the compressor in freezing weather. My Honda pilot does the same thing.
Old Nov 28, 2004 | 09:44 PM
clocks's Avatar
In Chicagoland traffic I sit a lot. Per the trip computer I average about 17 MPH. I don't like the idea of the a/c running the whole time. I am only getting 17-18 mpg.
Old Nov 28, 2004 | 09:48 PM
johnstl's Avatar
This info is in the owners manual! Sit down & read it cover to cover & you will learn alot about this car!!
Old Nov 28, 2004 | 09:58 PM
Lore's Avatar
CEO, Team Anthracite
Playing devil's advocate, vikrampatel may not have a TL yet, and thus may not have an owner's manual. His original post mentioned that he saw the auto button in PICTURES of the TL dashboard. Now, I don't know if this is true or not but it's a possibility!
Old Nov 28, 2004 | 10:14 PM
rets's Avatar
Moderator Alumnus
LOL. Lore, good catch.
Old Nov 28, 2004 | 10:24 PM
MOMOTL's Avatar
TL Asian GAL!!!
Funny thing I also noticed is when you press auto the a/c turns on without saying a/c on. However, when you turn a/c OFF it will show A/C OFF. BUt if you press a/c on, then it will read "A/C ON". Why wouldn't they have A/C ON when you press auto then????
Old Nov 28, 2004 | 11:03 PM
johnstl's Avatar
I thought about that after I sent my post...my bad!!
Old Nov 28, 2004 | 11:09 PM
Repecat's Avatar
Gratis dictum
Because "they" don't need to. When "Auto" is displayed, the A/C is on by default, and that is explained in the owners manual. You really don't need a redundant A/C ON icon. Additionally, when the A/C is on, it's not "on" constantly but the compressor is only functional intermittantly. I, for one, welcome the dehumidification function of the A/C.
soupi
14
Nov 15, 2015 11:15 AM
hashbrown
Sep 29, 2015 12:13 PM
adreano17
Sep 29, 2015 08:48 AM
dirleton
Sep 29, 2015 08:26 AM
thegipper
Sep 28, 2015 01:01 PM
