Check Engine Light
Old Jul 5, 2004 | 07:09 PM
GaleForce's Avatar
You touch my tra la la...
Check Engine Light
Its on again (*grumbles*). I know it isn't due to my resonator change because no one else has had the exhaust changed with the light on, and because this is the third time already. Still though, they don't know that, and I've heard some bad stories about dealers being dumbasses, so I am thinking about going and paying the 25 bucks to have the resonator welded back in during my lunch break so that they don't refuse service or tell me my warranty is voided and I messed my car up. I don't think its a bad idea, but I'd like a second opinion from you guys.
Btw, if they see the welds, I'll just say I didn't touch the car. I'm going to take the car out tonight for a drive to see if the light stays on under all conditions. Thanks for the help.
Old Jul 5, 2004 | 09:03 PM
GaleForce's Avatar
Bumpage.
Old Jul 6, 2004 | 07:12 AM
GaleForce's Avatar
Bumpage.
Old Jul 6, 2004 | 07:41 AM
cliff's Avatar
Team NightHawk VP
if you know for sure that the resonator didnt cause it, then they cant void the warrenty. they cant void the warrenty unless they prove that it is caused by the removed resonator. car should have set a DTC(diagnostic trouble code).
Old Jul 6, 2004 | 10:49 AM
GaleForce's Avatar
Still, I don't want to be given a hard time, and I am thinking it would be best, because if they can't fix it, I am filing for the lemon law. They could use that "mod" against me since the MIL sometimes comes on for emissions problems.
Old Jul 6, 2004 | 01:02 PM
rescueswimmer's Avatar
gale, understand your frustration. Did you have some troubles with gas mileage and the check engine light befor? Did they ever fix the mileage problem? If so what was the resolution? Getting the resonator put back on is a good idea. Especially with an engine code some dealers can find all sorts of reasons the light came on especially messing around with the exhaust, even though it probabaly had absoulutly nothing to do with the light. Good luck and keep us posted.
Old Jul 6, 2004 | 05:31 PM
nick04tl's Avatar
dont you think the dealer will notice that the exhaust has been cut and rewelded because im sure the exhaust shops welds arent as perfect as the factory ones
Old Jul 6, 2004 | 06:53 PM
GaleForce's Avatar
Yeah but the fact that all the resonators are in place and there are no leaks means that it won't be causing the problem. And if they see the welds I'll just shrug it off and say I never saw them.
Old Jul 6, 2004 | 07:08 PM
Road Rage's Avatar
Not a Blowhole
Wouldn't it make sense to determine what the DTC is first? Find someone with a scan tool, or AutoZone will usually pull it for you. It is hard to believe a simple removal of the resonator would cause this - perhaps something got damaged in the process? I assume you pulled the resonator to get more or a different exhaust note, or both, right?
Old Jul 6, 2004 | 07:24 PM
GaleForce's Avatar
Yeah I know, but still, if its not there they could always use it against me in court if the car turns out to be a lemon. Say since its an emissions light and they couldn't find the problem chances are its the exhaust (when I know it isn't).
Anyway, I had put put back in today. :P
But yeah, it would make sense to find out the DTC first, but since when did dealers make sense? I just wanted to avoid the problem. And yeah, I took the resonator out to get a different exhaust note, and a bit louder.
Old Jul 6, 2004 | 08:25 PM
Road Rage's Avatar
Not a Blowhole
Yeah, I hear ya, and cannot fault your strategy at all. but why then did you do it in the first place? And if the DTC goes away, are you going to remove the res again?
Old Jul 6, 2004 | 08:27 PM
GaleForce's Avatar
Nah, I decided not to mess with my exhaust anymore. Spent over 100 dollars getting both taken off, then one back one, then the other back on. I feel like I just wasted the money, and I did, so I'm done with my exhaust. I did it in the first place to get a nicer sounding exhaust really, but knowing dealers its going to cause more problems than enjoyment.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
