CAI install question
Old Jul 15, 2008 | 07:53 AM
silver_alty's Avatar
After watching the CAI install video by Sandieagodrive, is there anyway to remove the OEM intake without having to drill into the plastic? I am saying this just in case the OEM intake has to go back in. I just don’t want the dealership to hassle me about it.
Thanks.
Old Jul 15, 2008 | 07:58 AM
Kraftycutter's Avatar
I didn't drill anything on mine . . . although i did have to use a hacksaw, but that's another story.
Old Jul 15, 2008 | 08:00 AM
blkaspec's Avatar
Full of water...
i drilled the rivets out, but it would be no issue to use some small bolts or something to reinstall if i ever needed to
Old Jul 15, 2008 | 09:02 AM
Esco5710's Avatar
where can i see that video???
Old Jul 15, 2008 | 09:08 AM
Cdat's Avatar
Slow Paper> No Paper
^^ Garage.
Old Jul 15, 2008 | 09:23 AM
jmkiang's Avatar
zaino'd
All you gotta do is take some pliers, pull the end facing the front of the car. The "screw" is aluminum so if you pull hard enough, the end of shear off. Then just poke the other end out.
Does that make sense??
Old Jul 15, 2008 | 09:28 AM
TeknoKing's Avatar
Did anyone remove stock without using brutal force?
I think I will be finally getting my AEM, and I will install it this weekend, but I need to preserve stock so it can go back in the car when necessary.
Old Jul 15, 2008 | 09:35 AM
jmkiang's Avatar
zaino'd
I didn't damage anything when I removed the stock intake.
For that small aluminum thing, you can just use a zip tie or a rivet (I think).
Old Jul 15, 2008 | 09:53 AM
MinDawg's Avatar
there is other way to remove rivets. drill out or pullout. it will have same effect on your OEM part though = HOLE
Old Jul 15, 2008 | 10:19 AM
i think i am about to buy the AEM :-)...i live in detroit (farmington hills/ novi area)...anybody interested in helping me out with the install??
Old Jul 15, 2008 | 10:38 AM
jmkiang's Avatar
zaino'd
Its a pretty simple DIY. Just find the video from removing the front bumper and installing the CAI. Just remember that the video shows an Injen CAI installation. With the AEM CAI, the vibration mount isn't in the same location as the Injen one.
Old Jul 15, 2008 | 10:42 AM
^yeah i noticed that.
Old Jul 15, 2008 | 10:48 AM
JnC's Avatar
JnC
Former Sponsor
I didnt take the rivets out neither did I use force to yank it out. To take the whole assembly out in one piece you would have to do a few extra steps.
Follow the video to the point where it says to take out rivets.
1) At this point you'd have to take off the extra shroud pinned to the undercarriage.
2) To take the shrouding off you would have to unbolt the wind deflector mounted a the front of the radiator and AC condenser.
3) Reason you would take off the shrouding is to access the bolt that holds the return air siphon in place.
4) Once the shrouding and the bolt is off you can just take the whole air intake assembly off without any force .
Old Jul 17, 2008 | 08:57 AM
i just ordered my AEM intake (polished) from excelerate this morning...i am also waiting for my new shift knob to come in and i have to get 4 new tires today.....gees i am going to be eating dry wall for the next two weeks but i guess its worth it right :-/
Old Jul 17, 2008 | 09:32 AM
jmkiang's Avatar
zaino'd
^ Definitely.
What shift knob did you get? If its an aftermarket one, check this out first.
https://acurazine.com/forums/showpos...57&postcount=8
And use blue Loctite.
Just an FYI
Old Jul 17, 2008 | 11:03 AM
^just the OEM one. mine is somewhat fading plus i like the leather/ aluminum look
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
