Cabin a/c filter(s)
Old Dec 18, 2003 | 12:39 PM
pjp
Cabin a/c filter(s)
Does the TL have cabin A/C filters? If yes, how many and how are they removed?
Old Dec 18, 2003 | 01:45 PM
rets's Avatar
Moderator Alumnus
Re: Cabin a/c filter(s)
The owner manual never said it. Probably behind the glove box?
Or TL doesn't have it at all... the Acura technical info seems to have no answers on it.
Old Dec 18, 2003 | 02:36 PM
Right out of the sales brochure:
Dual-zone, Dual-mode Automatic Climate Control System with micron air-filtration system
Old Dec 18, 2003 | 02:56 PM
Ken1997TL's Avatar
2nd and 3rd generation TL's have micron air filtration systems. Its a filter behind a panel in your glovebox.
Old Dec 18, 2003 | 05:00 PM
pjp
How is the glove box removed? I cant seem to get the black tabs at each corner of the box to budge. Other cars require that you warp the box back to allow it to drop. There is also a arced tab that perhap that extends from the side of the box into the dash. I suspect this is what slows the opening of the box and gives you that "quality" opening process.
Old Dec 18, 2003 | 05:55 PM
rets's Avatar
Moderator Alumnus
I did once to remove it. I removed two things like tabs or nodes from each side, and it's very easy to separate it. But I couldn't put it back right, left a big gap on its right and it rattled, then my dealer did that for me... It's my first time to take apart my cabin stuff...
U would do better...
P.S. We even don't know if the minder would tell you when to replace it.
Old Dec 18, 2003 | 10:07 PM
I picked my car up yesterday and I too could not find anything in the manual but did remember that the sales brochure had that information. Anyone know when your suppose to change them?
Old Dec 19, 2003 | 01:06 AM
BlackShadow's Avatar
O.G.
I have a 99 TL and I just came back from getting my a/c filter changed. There were 2 pieces to it and they are behind the glove box. I will try to get the pics up asap for you guys.
Old Dec 19, 2003 | 08:08 AM
FTM's Avatar
FTM
Post
The A/C cabin filters should be replaced every 30,000 miles under normal conditions. If you live in urban areas they should be replaced about every 15,000 miles or so. If you have the 30K service done at the dealership this is part of that service.
Biggie_B
May 27, 2025 05:51 PM
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
hashbrown
Sep 29, 2015 12:13 PM
