Broken Motor Mount
Broken Motor Mount
04 TLs in the shop! Turns out the front motor mount is broken... Would like to hear from other TL owners who have had the same issue and what was the cause and resolution ( i.e. how did it break and was it covered under warrenty or did you have to pay and if so, how much). Thanks!
You know...I am beginning to suspect a similar issue in mine. I get a "thunk" in my steer wheel that can be felt slightly in the floor board of the car upon acceleration from a dead stop. I have been trying to figure out if it's suspension or a motor mount. I have brought it to the attention of the dealer at the last oil change and they couldn't reproduce it.
CAHobbs, what sort of symptoms are you having? How was it diagnosed? I am very curious as to the details of your situation. Thanks.
dsc888
dsc888
dsc888
dsc888
Anyway, my wife and I started to noticed that many times when we began to gradually but quickly accelerate on a hill or small incline from 1800 to 2200 RPM in what ever highest gear the car was in there was a unusual vibration coming from the front of the car as if the engine was lugging. It could be felt through the steering wheel and under the driver’s feet. Looking back now, this might explain why sometimes I would get wheel hop when trying to merge into fast moving traffic from a stop sign as the engine was probably rocking back and forth.
One way you might be able to check the front mount is to have someone in the car, hood open, engine running, brakes ON and in low gear. Stand to the side of the engine from a safe distance and make sure the driver has the brakes on real good! Have the driver give some gas to load up the engine and then let off quickly. What you’re watching for is the engine to rock backwards then return to its normal position.. As the car tries to move forward, the engine torque will cause the engine to rotate in the opposite direction (Top of the engine towards the driver). This movement should be smooth and around one to two inches or so. If the engine rocks quickly and then "drops" back into place when the gas is let off quickly, then you may very well have a broken front motor mount. Another (safer) way is to use an engine hoist and attach it to the side of the engine towards to radiator. Slowly lift the engine while examing the motor mounts for excessive movement. Be careful doing this as to not damage any linkages, plumbing or wiring.
Let me know what you find out about your issue when it's resolved.
Good luck!
tehLEGOman
Received 1,983 Likes
Is your TL supercharged? I forget if yours is or not.
yup so im gonna order the type s motor mount I saw the type s at acura and I looked at the mount...shit looks beefier than that on the previous stick tl's.... which I personally think honda realized oops we f-mucked up
[Then I traded in on a 2006 TL and got a whole new set of problems. ]
I just had to have all three motor mounts on our Odyssey replaced it has 100,000 miles on it. The tech mentioned that it was not uncommon to see the front motor mount go out at 60,000 This is a fluid filled bladder with a vacuum line that seems to deteriorate and then leak. It looks to be of the same design as the one on our 06 TL.
Just a thought.....
I don't have the sound you are talking about when you accelerate but i do have excessive vibrations in the steering wheel and pedals when accelerating. Is it the bad mounts causing the vibrations?
It could be.... if you look at my earlier post, I described how our vibration felt.
That said, I want to emphasize that our front wheels were rebalanced 3 times and also run at different tire pressures and lastly, they were balanced using a “load balancer” and even rotated with the back wheels to eliminate them as the problem.
I would always start with the tires and wheels first before looking elsewhere for the source of the vibrations.
To give you an idea of just how difficult it is to isolate “road” vibrations, here is a small list of things that can cause it, courtesy of Discount Tires:
Very often the wheel/tire assemblies on a vehicle may be in balance but you still feel a vibration! Here are some of the other causes of vibration:
• Bent wheel
• Tire out of round (radial or lateral runout)
• Wheel to axle mounting error
• Inconsistent tire sidewall stiffness (force variation)
• Brake component wear or failure
• Drive train or engine component wear or failure
• Suspension wear or failure
• Wheel bearing wear or failure
• Wheel alignment is out
So, after you have insured that your tires and wheels aren’t the problem, it wouldn't hurt to get the mounts checked out assuming that your TL doesn’t have am enormous amount of mileage which could mean something else is wearing out.
Good Luck and keep us posted, OK?
dude ive been through 3.... just buy new one because acura notes down that they are broken....hence abuse.....lol no one here abuses their car though so I dont understand y it would break hahhahaa.....yea anyways its like 45 shipped =)
King of NYC
dsc888
dsc888
WDP Director of R & D
Originally Posted by rockyfeller
Something similar going on here......(my car is only 2 months old, this sucks!) Mine happens only at startup though. At the end of startup right precisely when the engine turns on I get a weird slight "thunk" as well through the steering/floorboard or somewhere. Sounds like something is loose like a motor mount or something. It started so smooth when the car was new. Funny things is there is no type of clunking any other time. I wonder if anyone has had anything similar?
My 04 does the same as you describe.... Not every start, but the majority..
Hmmmmmmm
rockyfeller and KJSmitty,
What your probibly hearing is the ABS system doing a self-check. This is normal for may Hondas and Acuras. As you have noted, it only happens when you first start up. It seems to be more noticable in colder weather.
There have been many threads on this noise, here is an example: https://acurazine.com/forums/showthread.php?t=107082.
Hope this helps!
Hope this helps!
Quoting Rockyfeller "Mine happens only at startup though. At the end of startup right precisely when the engine turns on I get a weird slight "thunk" as well through the steering/floorboard or somewhere."
Now, if your ABS check is at the moment you release the key from the start position,,, you may have issues. The ABS check is once you're actually moving etc.. What is being discussed here is a "thunk" that occurs during engine start - a noise that reflects the engine may be rocking further than should be due to a possible broken mount.
Originally Posted by KJSmitty
You are correct, the ABS check has been discussed since late 2003 and I don't think one would confuse that with an "engine start-up noise".......
I don’t believe the motor mount is an issue during engine startup as it requires the engine to be under some type of load before it can rotate enough to lift the broken motor mount then the load has to be released quickly to cause the engine to "drop" back in place causing the "clunk".
Unless you’re in gear when you start your car, there is no load on the engine during start up, therefore the engine will not lift off of the mount. I doubt the 3.2 has the torque to lift the engine while in neutral or park.
As I stated earlier, the typical broken motor mount "clunk" only happens when you put a load on the engine. Putting the car in gear and taking off adds the load because the engine is now fighting the weight of the car, the engine torques opposite the rotation of the drive shafts causing the engine to lift off the front motor mount. The engine falls back in place when the load is suddenly reduced like during the next shift or when the car is no longer accelerating.
Look towards the beginning of this post and try the method I described and see if the engine “moves”.
Let me know, ok?
Good luck!
[SIZE=2][FONT=Comic Sans MS]I disagree, I have had the ABS clunk right after startup and other times, after moving about 60 feet down the road.
In all of my years I have never known an ABS system to perform a self-check without the need for the vehicle to be moving. Bottom line, never the moment I release the key from "start". Interesting..... Every 3G TL that has been discussed have all had the ABS noise while moving and near/at 5+ mph and at about the same time the doors lock (if applicable).
When starting any internal combustion, electric, steam etc. engine the fact that it goes from near 0 rpm to about 1200 rpm (in our case) on average produces significant engine rotation/torque. Any "loose" or broken mount will be subject to movement during engine start.
The 3.2 and even my old civic 1.6 has/had plenty of torque during initial startup to "shake" the engine enough to expose an engine mount issue. Doesn't have to literally "lift" the engine just "shake" it in the mounts. All vehicle/engines will do this at start. The more rigid/tight the engine mounts, the less the shake. I've replaced engine mounts that had separated rubber damping material that rattled in neutral all day long due to a rough idle. Yet didn't rattle at all in gear due to the torque applied and the subdued rough idle etc..
Big picture, I was responding to rockyfeller's question specifically. Your "method" of identifying a loose and/or broken mount is legitimate - yet given the comprehensive description of rockyfeller's noise I knew perfectly well what he was describing as well as the fact my TL exhibits the same thing. Is this thunk/thud during start an indication of a loose or broken mount? I don't believe so but it does have me wondering every time I hear it. One of these days I will get the wifey to set the brake - hold the breaks and rev the engine while in gear... If nothing else just to witness how much the engine moves in the mounts.. Hopefully she wont run over me (collect the life ins.)!!
Thanks CAHobbs
- Cheers!
King of NYC
Hope this helps!
CL Expert
For all those with the thunk at startup...
I noticed this in all my 6thgen V6 Accords, and now in my Automatic TL.
In my case, it is the shift lever/parking pawl...
To avoid the noise, I pull the E-brake all the way up BEFORE shifting into Park.
If you've got the same noise, it'll seem to come from under the driver floorboard and maybe under the front console too.
Had broken motor mounts too: My defective trannies killed the mounts. The tranny would rev up high and then slam into gear (basically a neutral drop) because the tranny was broken. With broken mounts, there was also thunk/clunk in the floorboard when first accelerating from a stop. Idle was a bit rougher in Reverse than in Drive (kind of buzzy). When accelerating from a stop going uphill the clunk was most noticeable. I was able to best reproduce the clunk for the dealer by using the accelerator to hold the car on a moderate incline and letting it rock back and forth by applying and releasing the throttle. There would be a highly audible and easily felt thunk as the car would roll forward and backwards. After the mounts were fixed shifts from the New automatic were smoother too.
I'm trying to remember if I had another thunk at startup with the broken mounts, though.
Wasn't there a TSB on motor mounts in 2004 TLs? I seem to recall it in one of the Acura service bulletins. I'll have to look to be sure....
I don't know if I have a motor mount that broken but can you guys tell me if I do?
I get a clunking or some sort of noise from the front end when I go over speed bumps.
Its kind of a creaking noise. Sometimes it sounds like when you rattle a metal canister around.
Could this be a borken motor mount?
King of NYC
Thanks rockyfeller!
We look forward to hearing what you discover!
https://acurazine.com/forums/showthread.php?t=147528
I know if been a long long time, but I was wondering if you ever found a TSB on the motor mounts? Oh, and now I have what appears to be a bad rod bearing too. Murphy's law.....
Been checking the Service Bulletins but the old eyes aren’t what they used to be..
Happy Motoring!
my tech at acura said if the side MM blows its because something is off on the suspension... and if one of the hydraulic ones blow something is blown either sensor wise or the mechanism that keeps the mount up, the thunk in the steering wheel is a rubber bushing under the rack n pinion... it took them 2 weeks to diagnose that sucker and that included the side motor mount being broken too. The type S motor mount I thought would be different maybe in size or something else but its the same from what ive seen and compared.
King of NYC
LIST/RAMEN/WING MAHSTA 짱
There's a GB happening for aftermarket motor mounts to fix this issue: https://acurazine.com/forums/showthread.php?t=178215
Turd Polisher
I wish I had the balls + a DIY to do this myself ..
My car is doing the same exact thing.
If I'm at a dead stop, press the accelerator it makes vibration in the pedals @ 900rpm.
Time to make an appointment.
xsilverhawkx
09-28-2015 06:51 PM
