Anybody had a "no outdoor temp" problem?
Since this morning, my outside air temp indicator has read " _ _ _ F". Has anyone seen this or know how to correct it? This is my first problem with the car (other than a few rattles).
Interestingly the AC came on as "Cold" (its coldest setting) when I started the car. I wonder if this is related. I raised the temperature and everything seems to be working normally for the climate control except for the outdoor temp reading.
Mine is always a good 5 degrees higher than it truly is outside. Sometimes it's more like 8-10!!
I even adjusted it to -3. Too bad that is as far as it will go..
Someone said your dealer can adjust it more….no one has confirmed yet though.
It happened to me about 2 months ago. The dealer couldn't figure it out. I also had HFL problems at same time. The fix (provided by Acura to the dealer) was to disconnect battery and then reconnect. All systems rebooted and I have had no issues since.
SidhuSaaB
May 30, 2020 12:40 AM
