after debadging...
Old Apr 25, 2005 | 02:32 PM
special-ed's Avatar
Iro Ridg .308
after debadging...
what do you recommend to take off the left over adhesive? i've heard that lighter fluid actually makes for good cleaning but not sure.. thanks!
tried searching the debadging threads but didn't find anything.
Old Apr 25, 2005 | 02:37 PM
special-ed's Avatar
Iro Ridg .308
sorry. put in wrong forum...
Old Apr 25, 2005 | 02:41 PM
ncatbagan's Avatar
rubbing alcohol
Old Apr 25, 2005 | 02:57 PM
kona's Avatar
goo gone or goo off
Old Apr 25, 2005 | 02:59 PM
GrayFox's Avatar
Goo Gone followed by a dose of Cleaner/Wax.
Jerry
Old Apr 25, 2005 | 03:08 PM
AsianTL's Avatar
Asian07RL
Goo gone and follow by any wax.
Old Apr 25, 2005 | 03:17 PM
special-ed's Avatar
Iro Ridg .308
thanks guys
Old Apr 25, 2005 | 03:25 PM
Hawhyen51's Avatar
I would run a claybar over the areas to remove any residue before applying polish/wax.
Old Apr 25, 2005 | 06:38 PM
caball88's Avatar
3M adhesive remover.
Old Apr 25, 2005 | 06:51 PM
ndx2's Avatar
6MT & LSD
speaking of debadging, there was a question i wanted to ask... but felt it wasn't worth an entire thread:
where are the holes located on the center emblem? how big are the holes, and how far are they apart from each other? can they be covered up with the 2G "A C U R A" lettering? has anyone done this? i've seen someone do that on a TSX.
Old Apr 25, 2005 | 07:02 PM
cM3go's Avatar
I considered it, but the way the trunk lid is on the 3rd gen, there is a crease where the Acura logo is, so the "A C U R A" wouldn't sit properly
Old Apr 25, 2005 | 07:25 PM
ndx2's Avatar
6MT & LSD
yeah, that's why i wanted to know where the holes were. is it behind the "A" in the middle? are they horizontal, or vertical? cuz if the holes are in the center of the emblem, then the letters would fit ok. i can't wait to get my copy of the TL service manual...
Old Apr 25, 2005 | 07:37 PM
cM3go's Avatar
Actually its only 1 hole.... it MIGHT work... someone who has removed their emblem to paint it can tell us...
Old Apr 25, 2005 | 07:45 PM
ndx2's Avatar
6MT & LSD
eh, crap. i don't think it'll work if it's just one. i thought it would be two, so that the top part of the U could cover them up. but if it's just one, then it probably won't work... and even if it does, it won't look right. i dunno why, but i don't like the acura emblem in the rear.
Old Apr 25, 2005 | 07:50 PM
cM3go's Avatar
Take it off and have a body shop fill the hole
Old Apr 25, 2005 | 09:44 PM
crazymjb's Avatar
Try boiling water and a sponge(but NOT the steel wool side). Its free
Old Apr 26, 2005 | 05:09 AM
dtpjigzer's Avatar
Yeah, its STOCK!!!
heres how i did it..... on a hot day... let the car get some heat on it... run floss in between the emblem. there will be adhesive left. den use your thumb to rub the left over adhesive off. on a hott day, it should come right. thats how i did mine... no marks left behind.
Old Apr 26, 2005 | 10:30 AM
SLVR04TL6PD's Avatar
I used a heat gun from 2-4 feet away ( it was October) and followed with bug and tar remover, and then cleaner wax, then carnuba.....
badeh2
2G CL Photograph Gallery
26
Mar 24, 2007 01:29 AM
ItalnMuslNYC
2G TL Photograph Gallery
29
Aug 20, 2004 06:40 PM
Casper98CL
Aug 8, 2001 03:41 PM
