The 3G Ramblings & General Discussion Thread
#4085
The lights behind the temp control on my passenger side went out. Off the top of any of your heads, do you remember if it's a fuse or how to replace?
Pic for reference... like you even really need it lol
#4089
**The Catfish**
http://www.v-leds.com/T3-T4-T5-LED/c514857-1-2/
for leds anyway... but the leds are going to be brighter and possibly give you hotspots where theyre brighter than factory bulbs... i dont think that autozone/advance/o'rileys will have them. When they used to go out on customers cars when i worked at best buy, the dealer was the closest place we could go to get them quickly
justnspace (06-25-2012)
#4093
Yea I have the base. Hmm.. true. I replace all the interior lights with some LED's - girl got out of the car last night and was like "damn it's bright in here!". I may change out the white for the light blue and do all the interior.... *thinking out loud*
#4095
**The Catfish**
3g Garage
https://acurazine.com/forums/showthread.php?t=747846 - Part 0 Retrofit of OE Bayonet Housings with an LED
https://acurazine.com/forums/showthread.php?t=746609 - Part 1 Map Light Console
https://acurazine.com/forums/showthread.php?t=746947 - Part 2 Rear Door Window Switch w/ Handle LEDs
https://acurazine.com/forums/showthread.php?t=763640 - Part 3 Steering Wheel LEDs (Audio and Cruise Modules)
https://acurazine.com/forums/showthread.php?t=746972 - Part 3 Overview
https://acurazine.com/forums/showthread.php?t=747870 - Part 4 Center Vents
https://acurazine.com/forums/showthread.php?t=747874 - Part 5 Cluster Console (EASIEST OF THE BUNCH!)
https://acurazine.com/forums/showthread.php?t=750657 - Part 6 Front Passenger Door w/ RL Door-Handle LED
https://acurazine.com/forums/showthread.php?t=750671 - Part 7: Front Driver Door w/ RL Door-Handle LED
https://acurazine.com/forums/showthread.php?t=750880 - Part 8: Knee Panel Lights (VSA, Mirror, etc)
https://acurazine.com/forums/showthread.php?t=755070 - Part 9: Heated Seat Switches
https://acurazine.com/forums/showthread.php?t=755388 - Part 10: Cupholder Illumination!
TheLowLife (06-25-2012)
Sick TLS (06-25-2012)
#4101
Chapter Leader (Houston)
#4103
I like turtles
I have been fighting with the vanity mirror lights trying to remove the cover for 3 days now. Read all the ways of doing it on here, i can put it down at least 3cm with 3 tiny screw drivers, but it just will not come off. Same with the trunk light. Fuck whoever made this car like that
Undying Dreams (06-25-2012)
#4104
Desert Life Sucks!!
Once you get the first one off. You will be able to do it in about 7 seconds per lights. hahaha wish I could help you but after I swapped my lights out I haven't messed with them
Good luck
Good luck
#4105
Received 3,824 Likes
My car
Definitely do the blue LED's.
TheLowLife (06-26-2012)
#4106
I also have trouble with the vanity and trunk lights. Hope the engineer burns in hell for putting a goat fuck of a lens in this car.
#4108
I like turtles
#4109
Great shots UD.
So jearous lowlife.
So jearous lowlife.
#4110
Desert Life Sucks!!
IamaTL there is only 1 side where there is a tab holding it in then the light just kinda drops down and the other side comes out.
Hard to explain. You only need 1 screwdriver to do it though. I wish I could explain more.
See ya'll in a few days, gonna get called out around 3 am so popping in a movie and I am out.
#4112
where you have it in the pic, there should be a spot that the screwdriver won't slide all the way into the light like that. try pushing on that spot and swinging the light down out of the way. try that on each side, that thing should come out pretty easy.
#4113
vleds.com
I got the small LED's and they are plenty bright as you can see. I ordered the same ones for the map lights, front and back and the courtesy lights in the bottom of the door. I still have white ones to add in the vanity and a blue light for the trunk.
Also, if you order from them follow their Facebook, I got 15% off when I ordered mine
Thanks Majofo!
Here's the blue ones I have
http://www.v-leds.com/BLUE-3-CHIP-5-...99342-1-2.html
Thanks Majofo!
Undying Dreams (06-26-2012)
#4115
Need to do some lighting upgrades myself.
#4116
#4118
^^ Bahahahaha!!! I missed posting on here last night.. watched my boys get worked by an amazing Arizona pitching staff
Anyway.. any of you got experience with Memphis stuff??? Looking at these..
http://www.woofersetc.com/p-8428-15-...subwoofer.aspx
