2007 & 2008 Acura TL Recall
#161
Anyone know how much this service costs? My 04 p/s hose was replaced in the last recall, but is leaking again. When I called, all they said was that it was done already. Anyway to have them do it again?
#162
I went in at noon and they finished the work in 90 minutes.
#163
#164
I got an e-mail from Jay Wolfe in KC today that my car was included and that they would proved me a loaner.
So about the O-Ring, I remember reading about a noise that this O-ring caused on cold days, is this is the same O-ring? Is it confirmed to be included with the service or am I going to have to ask for it to be done. I can't imagine even if I had to pay for it (since they are in there already anyway) that it would be more than $10.
My last loaner was a base '12 TL, yeah, liked a few small things, but my 3G is still better. The time before that I had a RDX Turbo. Easily chirped the tires going into 2nd w/out even trying!
#165
AZ Community Team
Received 7,770 Likes
The O-ring in question is 1.) part of the replacement hose kit and 2.) specified to be replaced per the recall kit installation instructions. This is 100% fact; just look at TSB 12-020 (and/or TSB 08-016).
Whether they actually do it or not - - they are absolutely, 100% supposed to.
Power Steering Feed Hose Kit: P/N 06535-SEP-307
(Contains P/S feed hose, P/S pressure switch
O-ring, P/S pump inlet O-ring, and all bolts, nuts, and
gaskets needed for the repair.)
10. Replace the P/S pump inlet joint O-ring:
• Remove the inlet joint from the pump (one bolt).
• Remove the O-ring from the inlet joint.
• Lubricate a new O-ring with clean P/S fluid, then
install it on the end of the joint.
• Reinstall the inlet joint, and torque its bolt to
11 N.m (8 lb-ft). .....
#166
#167
#169
3? Are you sure? I would assume that they just drain the reservoir and refill it after doing the recall. In that case, the reservoir would only hold 1. If they flushed everything from rod to rod, then they would get 3. Maybe your fluid looked like crap and they decided to do it in good will.
#170
AZ Community Team
Read the TSB.
REQUIRED MATERIALS
Acura Precision Crafted Power Steering Fluid:
P/N 08206-9002A
(Each vehicle may need up to three 12 oz. bottles.)
REQUIRED MATERIALS
P/N 08206-9002A
Whether or not they actually needed to use 3 bottles of PS fluid, would anyone be surprised if a dealer charged Acure for 3 bottles on every recall they do?
#171
AZ Community Team
#176
'07 TL Type-S
So what's your verdict on it aside from looks?
#177
JMonte626
#179
#180
i got my baby back, right away pulling out of my parking spot i felt the power steering was a bit lighter than what I was used to. Overall i went from quite stiff to a decently stiff steering wheel.
#182
'07 TL Type-S
^You need to give them a call. The online database is not updated yet.
And yes, the Type-S is included.
#183
I bought an 07 TL Type-S last week, I bet it hasnt been brought in yet ???
So all I have to do is take it to any Acura dealer? Right? I bought it from a private seller, not an Acura dealer.
#184
AZ Community Team
Call the dealer with your VIN to confirm you're in the recall pool. Then, assuming you are, make an appt with the dealer. Doesn't matter where you bought it, a recall is a required warranty repair.
#186
'07 TL Type-S
^How do you like it?
#187
feels and handles better (at least better than my TL)
seems to have more torque (even thou it doesn;t)
interior is ok..navigation is better but not touchscreen
overall i like it...until i get out and see what it actually looks like from the outside
#188
For the Canadians
I can view the recall info on acura.ca/recalls...
ACURA, A DIVISION OFHONDA CANADA INC.
180 HONDA BOULEVARD • MARKHAM • ON • L6C 0H9 • TEL 1-888-9ACURA9 • FAX (TOLL FREE) 1-877-939-0909 • acura_cr@ch.honda.com
June 2012
Campaign K53
Safety Recall: Power Steering Fluid Leak
Dear Acura TL Owner:
In accordance with the requirements of Canadian Motor Vehicle Safety Act (CMVSA), we are sending
this letter to notify you of a Safety Recall that applies to your vehicle.
Please check that the 17-digit Vehicle Identification Number (VIN) at the top of this letter matches the
17-digit VIN on the upper left of your vehicle’s dashboard.
What is the problem?
Prolonged exposure to high under-hood temperature may cause the power steering hose to deteriorate
prematurely and develop a fluid leak. A power steering fluid leak could lead to a loss of power steering
assist. Power steering fluid leaking onto a hot catalytic convertor may generate smoke or, in the worst
case, lead to an under-hood fire.
What should you do?
Contact your Acura dealer to schedule an appointment to have your vehicle’s power steering hose
replaced. This will also allow your dealer to give you an idea of how long they will require your vehicle –
usually less than a day. The dealer will perform the repair free of charge.
Who to contact if you experience problems:
If you need assistance with locating an Acura dealer, please contact Acura Canada’s Client Services at
the contact information provided below, or visit our website at www.acura.ca.
If the dealer fails or is unable to make the necessary repairs free of charge, you may contact Acura
Canada’s Client Services.
What to do if our information is incorrect:
This notice was mailed to you according to the most current information we have available. If you no
longer own this vehicle, or some information in this notice is incorrect, please fill out and return the
included postage paid Information Change Card or forward this notice to the new owner if possible.
Thank you for your co-operation. We apologize for any inconvenience this may cause you.
Sincerely,
Jerry Chenkin
Executive Vice PresidentACURA, UNE DIVISION DE HONDA CANADA INC.
180 HONDA BOULEVARD • MARKHAM • ON • L6C 0H9 • TEL 1-888-9ACURA9 • TELEC. (SANS FRAIS) 1-877-939-0909 • acura_cr@ch.honda.com
June 2012
Campaign K53
What should you do?
Sincerely,
Jerry Chenkin
#189
#192
ok guys I need help here. I just called a local Acura dealership and they told me that they would need to inspect it first to see if the service need to be done.
I completely disagree with this and am thinking a recall means I bring my car in and they need to work on whatever the recall is for, no question asked. Wouldn't you guys agree?
Also, I remember seeing an Acura service bulletin on how to work on this recall but can't seem to find it now under "Acura ServiceNews Bulletins". I'd appreciate it if anyone can post me a link to that bulletin. Thanks
#193
Called another local dealership Acura of Peabody, got a loaner and appointment done in 2 min.
Bottom line: Fk Acura of Boston
#194
Make sure to tell them not to wash the car!! I failed and forgot to tell them and I have a bunch of light swirls . Called up the dealership and they claim that they handwash all the cars but I'm pretty sure they injected this as they weren't there after my previous hand wash. I hate dealers!!!
#196
I went in for an oil change on Saturday and asked them about the recall and they said they could do it that day no problem. Gave me a loaner for a few hours in case I had anything to do. Got a 2012 TL SH-AWD with 1,000 miles on it. I must say that after driving it around for a while I was happy to get my '07 back. Inside and out I like everything about the '07's better.
#198
I did mine last week and just waited for the car to be done took them about 2 hours to do. I went back in my car and the steering did feel slightly different. It was not as firm as it was but it did feel smoother when turning. I am just starting to get use to the new steering feel but it is still firmer than say the new TSX steering so I say kudos to that lol
#199
Dang. Got my oil change last week and they didn't have the parts yet for recall. (Knew nothing about it till I told them)
I hope steering is a bit easier after... to be honest I really like the stiffness initially, it inspires a lot more confidence hitting high speeds on the highway, but ... it's starting to be a bit painful having to turn it so hard around town a few days after going hardcore at the gym and having all sore and tender arms.
