A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
Old 08-19-2016, 02:04 PM
  #2121
freddiemercury1's Avatar
Originally Posted by 94eg!
I found the pin on the tensioner too soft. It wouldn't pull out (with pliers even) once the tip of the pin popped out of the first hole. The hydraulic pressure bent the pin so much there was no way you could pull it through the next two holes. I tried twice to straighten the pin and have another go, but ended up with the same problem both times. Finally I chucked the pin and replaced it with a drill bit. Plenty stiff and slipped right out with pliers when the time came.
BTW: A simple large C-clamp works great to compress the tensioner. I've used an old rusty one to do this at least 6 times. Just go slow and you won't have any trouble.
I completed my job a few weeks ago. Everything runs fine. I did some other stuff too like ATF 3x3 etc.,
I had to use a drill bit on the tensioner in the end. Thanks for the suggestion 94eg! That thing was the most
difficult part of the whole job for me
Also I used the Milwaukee 2763 impact wrench. The CP bolt came out easily with a normal impact socket.
Just took a couple of tries. I am loving working on my car!! thanks for the awesome write up and help people!
Old 09-12-2016, 10:19 AM
  #2122
jkuhn76's Avatar
I have to get my 105k maintenance done and the dealer is wanting me to pay like $2700 dollars. Pretty clear they're ripping me off.
I love this post however the pictures aren't showing up anymore and I'd like to purchase all the products myself and bring it all to a trusted mechanic to install (because I do not have the physical means to do it).
Is there a specific parts list somewhere with links to all the items I need to buy? I see a lot of part lists, but not specific part numbers or links. Just want to make sure I buy all the right items.
Old 09-12-2016, 10:59 AM
  #2123
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
Pics are showing for me....
Old 09-12-2016, 12:30 PM
  #2124
jkuhn76's Avatar
Weird, tried in two different browsers and get nothing. Doesn't really matter though b/c I don't intend on doing the work myself. I just need a specific parts list so I can buy everything needed. Acura also told me I need to replace the Accelerator Pedal Position Sensor (for $575 dollars) because the VSA keeps coming on causing my car not to go above 2k rpm.
Pretty sure they're trying to rip me off, so I want to buy all the parts myself. Any help is appreciated because my car is taken apart right now at the dealer and I'm sure they need an answer and want their loaner car back lol.
Old 09-12-2016, 12:31 PM
  #2125
jkuhn76's Avatar
I also keep getting a message saying my fuel cap needs to be tightened. Doesn't effect performance and is just more annoying than anything but I'd like to get that resolved as well.
Old 09-12-2016, 12:37 PM
  #2126
Received 8,711 Likes on 6,718 Posts
https://acurazine.com/forums/third-g...essage-915682/
https://acurazine.com/forums/3g-tl-p...sensor-730958/
Old 09-12-2016, 12:53 PM
  #2127
jkuhn76's Avatar
Thank you for those links! Crazy how people on here have had the exact same problems as me ;-) What a great community this is.
Old 09-12-2016, 12:54 PM
  #2128
Yeah those are two VERY common issues on our otherwise great cars!
Old 09-14-2016, 11:47 AM
  #2129
Majofo's Avatar
Received 11,842 Likes on 8,573 Posts
Maybe you can see the pics here.. just search Majofo
https://www.diyauto.com/diys
Old 09-15-2016, 07:40 AM
  #2130
billzblaze's Avatar
I wonder if this is the exact same procedure on the old 06 RL? I beleive we share the same motor with the type-s, i know wrong part of the forum but u guys have waaaay more info than we do on our side..
Old 10-26-2016, 06:46 AM
  #2131
nfnsquared's Avatar
Dewalt DCF899B bare tool for $205
Save $25. Good though Oct 31.
Dewalt DCF899B 20V MAX XR Cordless Lithium-Ion 1/2 in. Brushless Detent Pin Impact Wrench (Bare Tool) - Rakuten.com
Old 11-14-2016, 09:31 AM
  #2132
StephTL2580
LAGS8005's Avatar
Red face
I was going to have my brotherinlaw do the 105k service on my car but he's not 100% confident he can do it. So.... I'm not about to drop 300 in parts and then for him to get however far into the job and say, ummm. just kidding lol! So, I found a local car shop here in dallas that will do it for $720 plus tax with a 2 year or 24k mileage warranty. I feel safer that way and know that this shop specializes in Honda & Acura's.
Old 11-14-2016, 11:45 AM
  #2133
Majofo's Avatar
720+tax and you bring the parts... that's steep labor price IMO.
The 2yrs 24k miles is just marketing.. if they eff it up, it'll be apparent right away, and they'd be liable anyways.
Parts are warrantied as well..
Anyways, I'd encourage you to shop around a bit more or gather the muster to DIY.
If that price includes parts, just make sure it includes the auto tensioner, idler pulley, and adjuster (full OE kit, get the plugs and t-stat done too)
I'd also recommend the aisin water pump.. that's the one thing they could eff up with the gates pump that could show later (pinch the o-ring, not seat it right).
Personally, Gates pump was fine with my install.
Old 11-14-2016, 12:17 PM
  #2134
UlsterBoy13's Avatar
720 with parts? or 720 and you bring parts? If they supplying parts are they installing new seals and tensioners and everything or just the belts and the WP?
Which shop if you dont mind me asking?
Old 11-14-2016, 02:48 PM
  #2135
nfnsquared's Avatar
$720 labor plus parts (TB, water pump, tensioner, tensioner pulley, idler pulley) is a bit high IMO, considering that a Gates kit can be had for ~$125 or an Aisin kit can be had for ~$185, but it's not outlandish.
If that rate includes plugs and /or a valve adjustment, it's a good deal.
P.S. FYI, I'm on my second gates pump with no issues (~35K miles so far). The first gates pump was fine also, lasted ~107K until I replaced it at my 2nd TB change.
Old 11-14-2016, 03:49 PM
  #2136
$720 if it includes all the parts, not including sparks and valve adjustment) is actually a good deal for the DFW area. I haven't found it under 900 with all the parts. one place will charge me 85/hr labor if i buy the parts and they est 5 hours but the kit on ebay is $297.
http://www.ebay.com/itm/Genuine-Aisin-OEM-Timing-Belt-Water-Pump-Kit-Honda-Acura-V6-Factory-Parts/171540570047?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D38530%26meid%3Da8895e89099443dd82046c510893c6d0%26pid%3D100011%26rk%3D1%26rkt%3D3%26sd%3D161197983767
Old 11-14-2016, 04:19 PM
  #2137
nfnsquared's Avatar
FWIW, that Aisin kit has the seals which really aren't needed. The quality drive belt can be had for ~$20. If one wants to replace the seals, then that kit is still a little pricey IMO. I don't think those seals cost $35 each???
Old 11-15-2016, 09:39 AM
  #2138
StephTL2580
LAGS8005's Avatar
Timing belt package for parts and labor is $720 (2 year 24,000 mile warranty all OE parts).
It comes with timing belt, outer drive belt, timing belt, hydraulic tensioner, water pump and anti freeze flush.
Time to complete job is 3-5 hours.
North Dallas Imports is the place. Its super convenient and its only 5 min away from work and home.
I've already had the spark plugs replaced and air filter
Old 11-16-2016, 03:56 PM
  #2139
6th Gear
bass.cpt's Avatar
That was one helluva write up! I'm definitely going to save this thread!
Would I have to do another timing belt swap at 210K?
Old 11-16-2016, 04:18 PM
  #2140
nfnsquared's Avatar
Yep, did my 2nd one almost exactly 1 year ago
Old 01-19-2017, 10:47 AM
  #2141
StephTL2580
LAGS8005's Avatar
Genuine / Aisin OEM Timing Belt & Water Pump Kit Honda/Acura V6 Factory Parts! eBay
Hey, I already did my timing belt package and I know you are in fort worth but right now Acura Plano is running a deal for a timing belt package for $749.95
https://www.davidmcdavidacuraplano.c...ls/service.htm
Good luck if you haven't already done it!
Old 01-19-2017, 11:45 AM
  #2142
Majofo's Avatar
It's not as good of a deal as you think. That only includes timing belt and water pump. They'll upcharge auto-tensioner, idler pulley, plus spark plugs, tstat, etc..
Old 01-20-2017, 10:05 PM
  #2143
Si_jeff's Avatar
Hey guys, if I decide I will have someone do this service for me, what is a reasonable labor price? $250 sound fair ?
Old 01-20-2017, 11:23 PM
  #2144
Sure
Old 02-23-2017, 10:22 PM
  #2145
nfnsquared's Avatar
Great deal if you need a nut buster for that nasty crank bolt
Milwaukee, 1100 ft-lbs for $250:
Special Buy Of The Day
Only 4 hours left....Sorry for the late notice, just found it in my email...
Old 02-24-2017, 12:08 AM
  #2146
Majofo's Avatar
Hey ladiboi (@thoiboi)
If you don't buy this, I'll be so ashamed of you.. might even have to put you on my ignore list
Old 02-24-2017, 12:10 AM
  #2147
treal512's Avatar
Wow, what a writeup!
Old 02-24-2017, 12:12 AM
  #2148
Majofo's Avatar
Geez NFN.. that's a deal. So tempting and less than 3 hrs left.. Must resist.. Have DeWalt...
Old 02-24-2017, 12:48 AM
  #2149
Damnit! Trying to add to my cart and it's erroring out.. You guys having any luck?
Old 02-24-2017, 01:06 AM
  #2150
I guess when they say "while supplies last" they meant it.. sold out it seems..
I've actually been eyeing the new Mid-torque Milwaukee M18 FUEL 18-Volt Lithium-Ion Brushless 1/2 in. Cordless Mid Torque Impact Wrench with Friction Ring Kit-2861-22 - The Home Depot that just came out. It's 600 ft-lb of torque as opposed to 1100
Old 02-24-2017, 01:13 AM
  #2151
Majofo's Avatar
Why pay more and get less?
Old 02-24-2017, 08:07 AM
  #2152
Logic being I may not necessarily need all 1100 torquies besides for jobs like the Crank Pulley.
Old 02-24-2017, 08:55 AM
  #2153
Majofo's Avatar
Pussy.. and for always regurgitating the manual.. you didn't read this one.
  • REDLINK PLUS Intelligence: allows the operator to choose between 2 fastening modes with Milwaukee's proprietary DRIVE CONTROL feature. Mode 1 delivers up to 100 ft-lbs of maximum fastening torque, and Mode 2 up to 700 ft-lbs maximum fastening torque
Old 02-24-2017, 08:57 AM
  #2154
Majofo's Avatar
btw.. the DeWalt has 3 speeds
rockstar143 (02-24-2017)
  #2155
Majofo's Avatar
I never use the other two modes though..
Old 02-24-2017, 09:00 AM
  #2156
You have me on the fence of whether or not to just buy into Dewalt and call it a day..
Old 02-24-2017, 09:10 AM
  #2157
nfnsquared's Avatar
You can still get the Milwaukee from ToolUp for $270. Not as good a deal as the HD deal, but still a good price.
I almost pulled the trigger at $250 even though I have the IR....
Old 02-24-2017, 09:12 AM
  #2158
Majofo's Avatar
but your color scheme
btw.. the milwaukee can be had for 2 bills.. getting a charger and battery on the low low is your goal.
DeWalt has 3rd party support so batteries and charges are inexpensive.
  #2159
Majofo's Avatar
270 is a very good price, I'd get that... that comes with charger and battery? Deal
Old 02-24-2017, 09:14 AM
  #2160
Majofo's Avatar
Dang.. not bad.. especially if no tax and free ship.. that's a steal
Milwaukee 2763-21XC M18 FUEL 1/2" High Torque Impact Wrench Kit
Quick Reply: A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
