A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
Old 05-17-2014, 11:12 AM
  #961
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
I guess in hindsight I should have gone OEM on that. The gates one seemed less substantial than what was in there although I've had no issues with it. I also think it was a couple degrees less...
Old 05-17-2014, 07:03 PM
  #962
Majofo's Avatar
Received 11,842 Likes on 8,573 Posts
Gates is fine. In many cases they are the OEM.
Old 05-20-2014, 01:35 PM
  #963
tihomirbg's Avatar
Do you guys think the side engine mount will be shot- I know now it is a good time to change it but the car has only 60K miles- I don't know if one can tell if that engine mount is shot just by driving and not literally checking it for damage
Old 05-20-2014, 02:07 PM
  #964
I know when mine was busted it was easy to see it...if you lift the boot on it, you'll easily see it, it's only a few bolts holding it in.
tihomirbg (05-20-2014)
Old 05-20-2014, 03:27 PM
  #965
tihomirbg's Avatar
^ got it. Will try to peak at it to see before I go buy the coolant and the thermostat from the stealership
Old 05-23-2014, 10:10 AM
  #966
tihomirbg's Avatar
Tomorrow is the the day- quick question- I was going over the DIY and I got the gates kit from a member on here and the water pump that it came with has china written on it. Is the gates water pump made in china? I will post a pic of it tonight
Old 05-23-2014, 10:14 AM
  #967
I can't remember but I posted a picture of mine a few pages back too...double check but I think it might have been. Also have had zero issues with it thus far.
Old 05-23-2014, 10:15 AM
  #968
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
I have 55K on the Gates water pump, no issues. There are plenty of Azine members who have used the Gates kit/water pump and I've heard of zero issues. I wouldn't worry about it in the least.
Old 05-23-2014, 10:16 AM
  #969
Majofo's Avatar
China..
Old 05-23-2014, 10:17 AM
  #970
Biggest complaint about the non oem water pump is that there is one that doesn't have the channel to securely hold the gasket in place, IIRC. The gates one does!
  #971
China makes Kia, doesn't it? So there's that going for it
Old 05-23-2014, 11:19 AM
  #972
tihomirbg's Avatar
Hmmm- I will look for WP pics and compare it to what I got. Hope mine is the Gates water pump and not some other made up China sh!t lol
Old 05-23-2014, 11:26 AM
  #973
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
I wouldn't run any critical component that's made in China unless there's no other choice. Been there, done that, got burned several times, won't do it again.
Old 05-23-2014, 01:37 PM
  #974
tihomirbg's Avatar
^ yeah- I am worried too- haven't been burned but I am not surprised when it comes to parts made in China
Old 05-23-2014, 01:42 PM
  #975
Hmmm...this latest review on amazon has me second guessing my decision.
Amazon.com: Gates TCKWP329 Engine Timing Belt Kit with Water Pump: Automotive Amazon.com: Gates TCKWP329 Engine Timing Belt Kit with Water Pump: Automotive
Old 05-23-2014, 01:47 PM
  #976
tihomirbg's Avatar
I found ur pic of the WP and I am not sure if the WP I have has the 5957 stamp and on yours I don't see any where China- hmmm- I gotta check it when I get home tonight
Old 05-23-2014, 01:51 PM
  #977
What post was it please? I went into my photobucket and couldn't find it. I know I showed Majofo and he was like, STFU yours is fine but the review on amazon has me doubting it.
Old 05-23-2014, 01:53 PM
  #978
Majofo's Avatar
Koreans doofus.
Old 05-23-2014, 01:56 PM
  #979
Korean doofus? Is that another Pho platter?
Old 05-23-2014, 02:03 PM
  #980
tihomirbg's Avatar
Page 16 post #622
Old 05-23-2014, 02:05 PM
  #981
Majofo's Avatar
Originally Posted by Majofo
You dolt J, that's a Gates pump.. see the 5957 stamp. You'll be fine, just don't bump the o-ring out of the track.
rockstar143 (05-23-2014)
Old 05-23-2014, 02:54 PM
  #982
read that fargin review on amazon though...fkr got me thinking again
Old 05-23-2014, 02:57 PM
  #983
tihomirbg's Avatar
^ I read it too- I don't know what to think as of right now. There are many ppl on here running gates WP and no problems as of yet I think lol
I can't wait to get home today and see if my WP has the 5957 stamp of approval
Old 05-23-2014, 03:11 PM
  #984
Majofo's Avatar
He probably didn't ensure the track of the o-ring was aligned, or used shitty coolant after install.
Old 05-23-2014, 07:27 PM
  #985
I trust in Majofo. Hence, I used it.
Old 05-23-2014, 08:20 PM
  #986
nfnsquared's Avatar
2 bad reviews out of 65? Meh. The one dude can't even use proper grammar or spelling, so rule that moron's review out. The other dude had leaks. Probably because he fucked up the gasket when installing it.
I don't remember the stamping on my Gates pump, but it definitely didn't have China on it (not that I'd really care). And Honda/Acura isn't using Aisin water pumps any more. I forget who they switched to.
rockstar143 (05-24-2014)
Old 05-23-2014, 08:31 PM
  #987
Registered Big Dog
BC2G's Avatar
-put the e brake on
-have someone view the side mount from the outside of the car
-put the car in drive
-put your foot on brake strong
***BE CAREFUL***
-accelerate just so... to the point where the engine shifts slightly...
-look for play/cracking on side mount
-Alternate between reverse and drive and do this method
IF ITS BROKEN IT WILL BE ABUNDANTLY CLEAR
**PLEASE BE CAREFUL**
tihomirbg (05-23-2014)
Old 05-23-2014, 09:51 PM
  #988
tihomirbg's Avatar
Just checked the WP i have- it does have the 5957 stamp
That is a bit of a relieve i guess
Old 05-23-2014, 10:27 PM
  #989
nfnsquared's Avatar
See, you're getting worked up over nothing when instead you should be doing your pre-TB service Yoga exercises
Old 05-23-2014, 11:25 PM
  #990
tihomirbg's Avatar
the pre-TB started lol- got the car on stands, sprayed the CP bolt with PB blaster and I and the TB will be tomorrow
Btw, I am getting a bit ahead of myself but what is the re-learning process again when ready to test drive it
Old 05-23-2014, 11:59 PM
  #991
Majofo's Avatar
Teh fuck
Please don't do what BC2G suggested.
Old 05-24-2014, 12:00 AM
  #992
Majofo's Avatar
Old 05-24-2014, 07:21 AM
  #993
Lmao...you ain't kidding either
Old 05-24-2014, 08:33 AM
  #994
nfnsquared's Avatar
...Btw, I am getting a bit ahead of myself but what is the re-learning process again when ready to test drive it
If you mean the CKP pattern learn procedure, it can't be done without an HDS. I don't know of any of us DIYers who did it and there have been no problems not doing it.
Old 05-24-2014, 09:07 AM
  #995
Drive the car.
It seems to speed up the process if you let it sit there and find idle. Then rev it and let off quickly so it has to find idle after snapping the throttle closed. Put it in drive , let it find idle, then back in park. Put it in drive again and with the brake on, blip the throttle easy and quickly. Turn the AC on with it in gear and out of gear. Do each step a few times until it seems to get it.
All of this is learned normally and naturally from driving and these steps aren't necessary unless you want to speed up the process. This is my way that I came up with, the manual probably has something different if it has anything at all. All it's doing is putting the ECU through different idling scenarios that it would encounter on the street but you're doing them all at once and several times in a row. If you really need to get it perfect quickly, do it while the engine is cold and again when it's hot but that's REALLY not necessary. If you can think of any other idle scenario I didn't mention, it would probably be a good idea. This still won't get you a perfect idle right away but it will be close.
Good luck with the install. Have a heating pad and some pain killers/alcohol ready for the day after.
tihomirbg (05-24-2014)
Old 05-24-2014, 09:44 AM
  #996
To add, the dealer probably does their relearn procedure because many customers would bring the cars back before they got home if they were hunting for idle and almost stalling.
Old 05-24-2014, 09:52 AM
  #997
nfnsquared's Avatar
Based on the SM procedure, I get the impression that the ECU/PCM will not initiate a CKP pattern learn without first being reset and a reset can only be done via the HDS...
Old 05-24-2014, 09:54 AM
  #998
tihomirbg's Avatar
Hope that stubborn CP bolt gives up on the first try
Old 05-24-2014, 09:58 AM
  #999
nfnsquared's Avatar
It won't
What is your "Plan B"?
Old 05-24-2014, 11:04 AM
  #1000
the overexplainer
ez12a's Avatar
Starter method. Works as the last resort.
Quick Reply: A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
