'06 vs '07 Tranny reliability?
Old 01-21-2015, 02:20 AM
Dazment's Avatar
There seem to be little to no complaints about the 07 tl's Tranny compared to the numerous amount of complaints about the 04-06 tranny... Is there a reason to that?
Old 01-21-2015, 05:18 AM
bla8291's Avatar
The tranny in the 07-08 TL/TL-S is different. It's said to be the same as the one in the RL, which some have called "bulletproof". I wouldn't go that far with my confidence in it, but then again, I don't ever recall someone on here with those two model years complaining about it.
Dazment (01-21-2015)
Old 01-21-2015, 08:18 AM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
07-08 TL using the modified version of the Acura RL AT, suppose to be a improvement design. I too never heard any major complaint about 07-08 trany.
Old 01-21-2015, 09:26 AM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Plus, unsurprisingly, 04-06 are older than 07-08 cars. Issues might take a bit longer to popup, if issues there is.
Old 01-21-2015, 09:30 AM
GKinColo08TL's Avatar
+1 for what those guys ^ there said...
Old 01-21-2015, 11:36 AM
07 NBP 5A/T UA6 NAVI
JL-TL_07's Avatar
I have an 07 and have had a brief issue. Once on a cold morning I warmed up the car and headed on the highway for work. Making my way on the on ramp I red lined first and second then let off the gas. It would not up shift into 3rd 4th or 5th. It was stuck in second screaming. Tried to put it into ss and manually shift it but no luck so I quickly tried to make my way to the next exit. As I was about to exit it finally got into the correct gear and I continued to head to work. Soon after I changed the pressure switches and switched over to the redline atf. Haven't had an issue since.
Old 01-21-2015, 07:56 PM
Dazment's Avatar
I have heard of 3rd and 4th gear pressure switches but what is redline atf? I know its some kind of flui you put in the car but I don't get what it does and what it replaces. Tranny fluid?
Old 01-21-2015, 08:39 PM
Flip 2's Avatar
Redline is an oil brand.
Best synthetic Race Oil many think.
ATF is their fluid for automatic transmissions.
Old 01-22-2015, 12:03 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
ATF stands for automatic transmission fluid
Old 01-23-2015, 09:07 PM
Registered Losers
3stageWDP's Avatar
2006 TL nine years old and 55k miles later nothing so far knock on wood.
Replaced the rear main seal one year ago at the stealership the most it has cost me since buying it new.
Old 01-25-2015, 08:33 AM
warterdesmanne's Avatar
I bought an 07 AT 130k and seems to be fine. Fluid looked neglected when I bought it so attribute my "early down shift" to 3rd to this. I believe I found a DIY for cleaning the screens on the solenoids and think this could be the issue. While braking from right around 45 MPH she well drop into 3rd at around 35 mph and this causes a slight "engine brake" effect.
Old 01-25-2015, 08:35 AM
And late 07-08 have 3 pressure sensors. Of which I have replaced all three. Two 2nd to 3rd and one 3rd to 4th. Could be the other way around but I remember it being backwards of the way I thought it would be.
Some say early 07s would have the 04-06 setup. Mine is 35k into the production run and had three sensors. Never saw a number of how many 07s were made WITHOUT the improved tranny.
Old 01-25-2015, 04:19 PM
Dazment's Avatar
How would I be able to tell? Im still in the market for a 07 tl type s
Old 01-26-2015, 08:39 AM
truonghthe's Avatar
nope all 07-08 had three switches, 04-06 has two. People stop giving out false info.
Old 01-29-2015, 09:28 AM
Please understand I am not trying to give out "false info" and honestly was just trying to be helpful. Go blame the people who have indicated this.
On another note, I have a hard time telling if this down shift "engine brake" effect is normal operation. I feel like it is light enough that it might actually be but no one seems to be able to tell me for sure.
Old 01-29-2015, 09:57 AM
truonghthe's Avatar
the engine brake you talking about is called "grade logic shift" it bascially mimic the way of MT been driven.
QuickTL07 (02-01-2015)
Old 01-30-2015, 02:21 PM
Does this on level surface, mostly when slowing from around 35-40 as you pull up to a stop... Braking gently.
Old 01-30-2015, 04:30 PM
truonghthe's Avatar
yes my TL does it when I breaking gently for a red light and I can felt the car down shift into the lower gear and come to a stop. It's get more annoying if you driving where hill espcially when you going down hill, the car always love to hold lower gear.
Old 02-01-2015, 01:21 AM
QuickTL07's Avatar
Im glad mine is 07TL,, but I do have a question not to steal OP thread,
I noticed some fast shif in between gears, and when the car slows down, I could feel downshift gears, just wondering if that's normal, I never had an auto car, and this is my first one.... what are you thoughts guys, is that normal just wondering.
Old 02-01-2015, 01:22 AM
QuickTL07's Avatar
ops never mind guys i didn't read the upper post...Thank You~
Pham Alvan
05-18-2021 06:48 AM
Charles Bennett
01-28-2018 08:53 PM
Pham Alvan
03-16-2016 09:17 AM
CL-S progression 01
01-26-2016 04:15 PM
xsilverhawkx
10-05-2015 11:00 AM
Quick Reply: '06 vs '07 Tranny reliability?
