RLX problems
Old Feb 24, 2015 | 08:30 AM
timmins's Avatar
RLX Hybrid #053
RLX problems
anyone having issues with their RLX?
the windshield washer jets are very very weak on mine. the MDX and the TL before are/were very strong they spray like a jet stream. the RLX is just a weak piss. is this a common problem?
Old Feb 24, 2015 | 09:11 AM
neuronbob's Avatar
No. Mine sprays to about 3/4 of the way up the windshield. The only exception is in frigid conditions when they can become partially or completely frozen. Seems like a video is in order so you can show us what you mean.
Old Feb 24, 2015 | 01:10 PM
timmins's Avatar
RLX Hybrid #053
Thanks for the reply. I will get the dealer to check them. It could be something is loose they have no pressure.
Old Feb 24, 2015 | 02:23 PM
holografique's Avatar
mine are pretty powerful and cover the same area that Bob mentions.
Old Feb 25, 2015 | 02:30 PM
Malibu Flyer's Avatar
Poor range on garage door opener
I don't want to pile on since I basically really enjoy my sport hybrid but..... I have noticed a very short range on the garage door opener. I am comparing it to my '05 RL. Sometimes I can be within 20 feet of the door and it doesn't recognize my button push. I wonder if it is a directional issue?
Anybody else experience this? I plan to have it addressed when they get the headlight parts [ordered about 10 days ago]. Since my car is the only Sport Hybrid the local dealer will sell and even the PAWS cars are far and few between in my part of the country. I doubt they have sold more than a few dozen in the last 18 months. The experience and expertise on Acurazine is likely at least as good as my dealer, probably better.
Old Feb 25, 2015 | 06:45 PM
scv76's Avatar
@Malibu Flyer
I have noticed the same thing; I have to be right in front of the garage door for it too work.
To give perspective, my 4-runner will open the garage door 1.5 houses away!!
Maybe this should be in another thread so we don't hijack this one about window washers?
Old Feb 25, 2015 | 07:25 PM
dzionny_dzionassi's Avatar
Quick response on range issue.
Installed mine new garage door opener(motor) couple months ago. In instruction was stated not to use LED bulbs in motor because it reduces range.
Maybe Jewel leds got something to do with it?
Old Feb 25, 2015 | 08:29 PM
neuronbob's Avatar
I notice the same issue with remote range in my car. I thought I was the only one.
Old Feb 25, 2015 | 09:33 PM
same here, and interestingly enough, it started happening only when I placed the plastic housing cover back over the motor section. before it was off for the longest time (since we moved in) and I always got good range.
I am also using LED bulbs in the garage motor area. I'll try replacing them with incandescents to see if this works per dzionny's post.
Old Feb 26, 2015 | 02:56 AM
timmins's Avatar
RLX Hybrid #053
now that you mentioned it, mine (the garage door opener) has a short range also.
Old Feb 26, 2015 | 03:01 AM
timmins's Avatar
RLX Hybrid #053
the centre console armrest feels not closed. not a complaint but when you push down on it it gives some 1/4".
Old Feb 26, 2015 | 05:34 AM
RLX-Sport Hybrid's Avatar
Mine does the same but it is about 1/8" by my estimation. I asked yesterday about that too and it is designed that way to allow for the dual movement of its opening both ways. If there was not that clearance it would not open.
Old Feb 27, 2015 | 06:42 AM
R. White's Avatar
The driver's side window washer is anemic. I'll have them check it next time in. The garage opener is inconsistent. Sometime I can open the door from 100' away; other times I have to drive right up to the door. I wonder what the issue is with LEDs ? RF interference ?
Old Feb 27, 2015 | 10:02 PM
regarding the center armrest, you guys know that there is separation on purpose so that you can run a charging cable out through the front left and right areas while it's closed?
that's what the odd shaped "hooks" are on the front of the inner center console tray is. you run the cable through front middle opening, then run it through either the left or right hook area and from there it can peak outwards external to the armrest even while it's completely closed.
Old Feb 28, 2015 | 05:27 AM
mgalbr22's Avatar
Range
It is clearly defective. Mine is very short. No led bulbs. It is the home link system in the RLX.
Old Feb 28, 2015 | 06:42 AM
George Knighton's Avatar
Grandpa
That could make "Hey SIRI" a lot easier. I'll give it a try.
Old Feb 28, 2015 | 07:39 AM
timmins's Avatar
RLX Hybrid #053
Thank you! Now it make sense. I'll try it rather than the lighter plug. I guess I didn't read the manual properly.
Old Feb 28, 2015 | 07:59 AM
Grandpa
Originally Posted by Internet Personality
Ain't nobody got time fa dat.
Old Feb 28, 2015 | 08:00 AM
neuronbob's Avatar
I didn't know that. Thanks!
Old Feb 28, 2015 | 04:44 PM
^ lol...your welcome guys
funny enough, I don't think this is mentioned at all in the manual.
Old Feb 28, 2015 | 11:12 PM
victorber's Avatar
RLX Advanced #3606
I think I was the first to bring this to the boards attention, Bottom line even after Acura replaced the "Home Link Unit" I had to replace my garage door opener to cure the problem.
It seems that there is a difference in frequencies and the newer GD openers transmit on a higher Freq.
Go figure!!!
Old Mar 1, 2015 | 08:54 AM
Grandpa
You've given me something to think about. The car has never been able to open my garage door.
Are you saying you had to upscale your garage opener, or downscale it?
Old Mar 1, 2015 | 12:16 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
Possible solution?
https://secure.homelink.com/homelink...ter-kit-detail
Old May 23, 2015 | 12:15 PM
EE4Life's Avatar
Forum Contributor
See TSB 15-023 - HomeLink System Has Weak or Limited Range in the TSB sticky thread.
https://acurazine.com/forums/third-g...thread-921955/
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
IIDXholic
3G RLX (2013+)
23
Oct 19, 2015 09:40 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
