Nitrogen in tires - Myth or Fact?
Old Nov 24, 2015 | 12:12 PM
RLX-Sport Hybrid's Avatar
It was 19 degrees this morning and I noticed a little flat spotting in the tires for about the first minute. Could replacing the traditional air with nitrogen solve that minor issue? I see signs at tire stores all the time for this, but have ignored them until today. What do you all think?
Old Nov 24, 2015 | 12:22 PM
TacoBello's Avatar
Air is 70% nitrogen.
Do these shops vacuum out the existing air and then fill only nitrogen? Are you willing to drive to a shop every time your tire is a little low?
Marketing gimmick.
Old Nov 24, 2015 | 12:31 PM
getakey's Avatar
minimal advantages (air is 78% nitrogen)
http://www.tirerack.com/tires/tirete...jsp?techid=191
Old Nov 24, 2015 | 12:59 PM
getakey's Avatar
Don't the RLX's have nitrogen in the tires from the Factory/Dealer?
My stem caps are labelled nitrogen, but I have topped off with air
Old Nov 24, 2015 | 01:15 PM
I have no idea. My caps are grey. Does that mean anything? I guess the flat spotting is just something that I have to deal with. I'm at just under 20,000 miles and have 7/32nds of tread at all 4 corners. Seems like that is fairly good. I typically replace tires when I am at about 4/32nds and it is close to winter. At my current pace I will replace them next November very likely.
Old Nov 24, 2015 | 01:18 PM
TacoBello's Avatar
Whoops, yup, you're right. I had a feeling my 70% number was wrong. Either way, even less of a reason to get it
Old Nov 24, 2015 | 01:23 PM
flat spotting could be an attribute to the specific rubber compound of that tire manufacture and not necessarily attributed to air or lack there of.
Old Nov 24, 2015 | 04:03 PM
Edward'TLS's Avatar
6G TLX-S
Flat spotting is usually tire model specific.
For example, the Bridgestone Turanza EL400 is notorious of being flat spotting in cold temperatures.
Old Nov 24, 2015 | 06:02 PM
nist7's Avatar
In fact I would say it is disadvantageous due to the much higher of cost to benefit ratio
That article mentions a "reasonable $5/tire" WTF?
Who the hell would pay $5 a tire for about 12% increase in their nitrogen in their tires? Friggin un-believable.
Old Nov 24, 2015 | 06:17 PM
it is also getting cold out.
Old Nov 24, 2015 | 07:03 PM
neuronbob's Avatar
Nitrogen has no benefit for ordinary drivers. The end.
It has theoretical benefit for race car drivers, in that it is supposedly easier to predict the rate of pressure increase in the tires during the course of a race.
As it happens, my RLX's stock tires were filled with nitrogen, at no cost, at the time I leased the car. Guess what? I still had to fill the tires a little more when the temperatures dropped to the single digits during the worst of last winter.
Nitrogen is bull-oney.
As for the flat spotting, my stock tires were doing that as well. The only fix is to keep the tires inflated to the manufacturer's specs.
Old Nov 24, 2015 | 07:21 PM
I try to keep them at 35-36 psi cold but it is good to know that my experience is not unusual. Thanks very much!
Old Jan 8, 2016 | 07:39 PM
jim_c's Avatar
Nitrogen is used in racing series because they don't want compressed air in the pits which might contribute to a fire hazard. It is also used in aircraft tires where pressure is critical. Nitrogen molecule is smaller than oxygen molecule (lighter but smaller) so nitrogen is slightly less likely to permeate the tire and reduce pressure over time. May be an issue when plane is at altitude. (?) For regular cars nitrogen fill is hype and a scam to sell you something you don't need. A more important consideration is to keep water out of the air mixture in your tires. Airlines at gas stations contain huge amounts of water and should be avoided.
Old Jan 8, 2016 | 07:56 PM
EE4Life's Avatar
Forum Contributor
See page 1 of the November 2012 and September 2006 Acura Service News.
https://acurazine.com/forums/third-g...8/#post8398357
Old Jan 10, 2016 | 09:28 AM
George Knighton's Avatar
Grandpa
I'm not clearing my cache to look at something, just like I'm not going to consider for a moment putting nitrogen in my tyres.
Old Jan 10, 2016 | 04:53 PM
neuronbob's Avatar
Thank you! The enginerds at Honda=win, likely after overstudying the issue . Bottom line, again, nitrogen in passenger tires is bull-oney. Further, the 2012 Acura Service Bulletin directly addresses RLXSH's original question, whether nitrogen in tires helps flatspotting--it doesn't.
CheeseyPoofs McNut
Oct 2, 2016 11:37 AM
gschra11
Nov 19, 2015 09:01 AM
clapham
Nov 17, 2015 07:12 PM
copmagnet82
Nov 5, 2015 01:17 PM
08KBP_VA
Nov 2, 2015 11:21 AM
