Trunk noise when driving over 60 km/h
Old Jan 28, 2019 | 08:57 PM
mattman3234's Avatar
Hi all...been lurking for awhile. I've had my new Platinum Elite RDX for about 3 weeks and all has been good but I'm having a sound issue from the trunk. When I'm going over 60 km/h or so I start hearing a rattling or knocking sound. It sounds like there is something in the underneath storage bin knocking up and down. Very plastic sound. I had some stuff stored in their but took everything out and the noise is still there. It almost sounds like the bottom of trunk floor cover plastic is bouncing on the plastic bin. It's pretty loud (Unless I crank the stereo ;-). Anyone else have that issue? I may try putting additional padding on the top of the bins to see if that helps.
Thanks!
Old Jan 29, 2019 | 05:07 AM
bluntman72's Avatar
I can't say that I've experienced anything like what you have described, but make sure to check your spare tire and the mechanism that holds it in place underneath the rear of the vehicle.
Old Jan 29, 2019 | 07:31 AM
DHood's Avatar
Thanks!
There is a Secondary Plastic Tray at the far right side of the trunk in the storarge area, and there are a few emergency items below the tray, are any of them rattling?
Old Jan 29, 2019 | 03:12 PM
Had that thought as well...reached under and tried to rock the spare but it wasn't moving...
Old Jan 29, 2019 | 03:13 PM
Checked that...I even pulled the top of the tray off to see if that was making the noise...no luck.
Old Feb 10, 2019 | 07:45 PM
Just an update in case someone else runs into the same issue....so....not really much of an issue. Had my wife drive the car while I was in the back listening and found the culprit....the dealership didn't fasten down the license plate all the way so the wind was catching it.
Old Feb 11, 2019 | 12:23 PM
DrWoo's Avatar
Dealers always tend to just use 2 screws to fasten the license plate. The first thing I do when I bring home a new car -- fasten down the license plate with 4 screws, after adding a few rubber bumpers underneath.
cray159
Dec 17, 2020 05:58 PM
charmer37
Dec 9, 2014 11:11 AM
simonjiang
Oct 31, 2013 12:12 AM
Sondinh
Apr 14, 2010 09:32 PM
Fuda
1G TSX Problems & Fixes
May 31, 2008 08:45 PM
