Brake squealing
Old Nov 26, 2018 | 05:21 PM
  #41
Lale93's Avatar
I have had the same issue with my 2019 RDX and struggled through the same issue on my 2106 RDX. It started happening with my 2016 a month after I got it in August; brought it in three times and they could never replicate it or had ANY other issues with other vehicles. I simply gave up and dealt with it only to discover that they had issued a TSB for it and it was the number one complaint of that year. It gives me hope that you have already been able to have the rotors and pads replaced. I have never experienced this with any of my other new cars besides Acura.
Old Dec 4, 2018 | 07:33 PM
  #42
mode360's Avatar
Finally had mine looked at. They will replace the rear pads and rotors next week because parts will come in late this week.
Old Dec 7, 2018 | 04:24 PM
  #43
JustMe65's Avatar
I have heard the brakes squeal on mine a few times but I live in Phoenix and it’s dusty here which can cause brakes to squeal so I was thinking that was what was causing it. My 2010 Nissan Murano had squealing brakes and Nissan said it’s not a problem, just dust.
But maybe with this car it is a problem.
Old Dec 8, 2018 | 08:07 AM
  #44
tabs31's Avatar
To those who had their dealerships "fix" this issue, where they able to remedy the problem?
Old Dec 8, 2018 | 10:58 AM
  #45
Dereileak's Avatar
mine came back, the service director said Acura is working on a fix for this
Old Dec 12, 2018 | 11:38 AM
  #46
mode360's Avatar
Just had my rear brake pads and rotors replaced yesterday but the squeal was still there.
During the first drive this morning, I didn’t hear anything which I thought was gone; but when I went out for lunch, I could hear the squeal again.
Old Dec 14, 2018 | 12:22 AM
  #47
Rocket_man's Avatar
Summer is Coming
Factories don't apply anti-squeal compound on the back of the pads. Dealerships may if you ask them. You may have to supply it. Or you can do it yourself.
Old Dec 14, 2018 | 04:49 AM
  #48
Marty790's Avatar
Agree but doesn't make any difference with the RDX brakes, they still squeal even if they have anti-squeal compound! I did it at home--> not working and went to the dealership to get it done and also not working!
Old Dec 15, 2018 | 07:27 PM
  #49
securityguy's Avatar
Read post #17
Old Dec 18, 2018 | 10:05 AM
  #50
stephensils's Avatar
Same issue here everyone. Brakes squeel in the mornings very loud, but then goes away after 10 mins. Also squeel after the car is parked for an hour after a drive.
Hopefully acura will rectify the issue soon. It's pretty annoying to have a brand new car act like this. Lots of small issues with the car so far. Starting to lose faith in acura.
Old Dec 21, 2018 | 07:18 PM
  #51
Mikeg040's Avatar
I have the same problem with the squealing brakes with the first few stops. I also seem to hear a little grinding once the squealing stop at low speed. Anyone else hearing the grinding noise.
Old Dec 22, 2018 | 04:32 PM
  #52
Yupp. Mine does the same thing as your described. Dealership just changed my front pads and the squeeling is gone, but I still hear the grinding noise. Getting them checked out this week. Hopefully they just replace the rotors and it'll solve the issue.
Old Dec 22, 2018 | 05:26 PM
  #53
JustAnotherOne's Avatar
Did the dealer mention what was the issue with original pads? Since the new pads should be same part number as original. Just wondering if replacement is a long term fix. Then again dealership would not just change pads without any reason.
Old Dec 27, 2018 | 04:14 PM
  #54
Granz007's Avatar
had same problem
I've read a lot of threads on the 2019 RDX brake squealing in cold and wet weather I'm curious as to why nobody finds this as annoying as I do in a brand new high end vehicle is it the fact that the people saying dont worry about it live in a warmer climate to me it has become so bad that I'm questioning whether I made the right move buying this vehicle I always said Acura was the best running car I ever had until now I've tried to get the problem fixed and the dealership claimed there is no fix for it that it's under investigation which I'm sorry there's always a way to fix something anyone else having a concern on this topic please respond ive gone as far as contacting customer relations and still not getting anywhere with that I know people say let the brakes warm up and the squealing should stop but I've had plenty of new vehicles and never had this issue
i had this same problem with my 2019 rdx took it twice to get fixed although sometimes there is still a slight squeak i plan to mention it when i get my first oil change since it’s a pita the go to the dealership. First time i took my brakes in they said they cleaned the pads there was dust or dirt on them. Still continued to happen so second time they told me they had to grind the rotors down, which kinda didn’t sound good but they ensured it would be fine and now most of the noise is gone if not all. The guy said Acura was going to issue a bulletin on this it seemed like a known issue but idk he could have just been trying to make me feel better
Old Dec 30, 2018 | 05:56 PM
  #55
drs2rt's Avatar
9th Gear
Mine also makes noise when it gets cold outside and by the time I get to the dealer it stops the noise. Had it checked twice now but no problems found. Waiting for it to get colder and stay that way all day then I will leave the RDX at the dealer and let them drive it when it is cold.
Old Dec 30, 2018 | 06:03 PM
  #56
If you all read more into this thread, you will see that Acura has stated that they are aware of the issue and that a "fix" is coming. What you are experiencing is a known issue and cannot be fixed "today" by replacing pads or rotors. I would just hang tight and await Acura's communication and TSB/Recall as going back to your dealer today is futile. Most of our guesses is that Acura will change the pad material but that is just a guess that some have mentioned. A rotor is a rotor so I can't imagine that being the issue but they may decide to replace both to resolve the issues many are facing. Being in the South, we have experienced the light sounding "grinding" but no squealing to date as we approach 4500 miles.
Old Dec 31, 2018 | 09:34 AM
  #57
Monster_HK's Avatar
Anyone has your brake fixed? I picked up my RDX 3 weeks ago with about 800 mileages on it. The temperature dropped below 40, the brakes squeal for the first 4-5 mins of driving.
Old Dec 31, 2018 | 09:39 AM
  #58
Monster_HK's Avatar
Old Dec 31, 2018 | 09:43 AM
  #59
Midnight Mystery's Avatar
Null and proud of it
Duplicates?
Website must be messed up, this thread appeared twice for no reason, lol!
Old Dec 31, 2018 | 12:47 PM
  #60
Read post #28 in the link below:
https://acurazine.com/forums/3g-rdx-...ealing-974575/
Old Dec 31, 2018 | 01:08 PM
  #61
Monster_HK's Avatar
Originally Posted by securityguy
okay thanks I will mention the squealing noise next time I do the oil change.
Old Dec 31, 2018 | 08:04 PM
  #62
Mikeg040's Avatar
I took my RDX to the dealer for this issue and they didn't even look at it. All they said is there is nothing they can do .they were going to contact the district manager to see if they will do anything. My guess they won't. Basically told me to deal with it and didn't know if there will be a fix anytime. They did not mention anything about a bulletin or anything like that .
Old Jan 1, 2019 | 01:36 PM
  #63
Dizzyg12's Avatar
find a new dealer
Old Jan 5, 2019 | 08:39 AM
  #64
Stclark13's Avatar
For what it’s worth I was having the same issue everyone else was having with their brakes. After seeing no one got anywhere with their respective dealers I decided to take care of it myself. Went on rock auto.com and ordered new ceramic pads for $50 front and rear. Swapped them out and not only is there no squealing the pad feel is sooooo much better and car has more predictable stopping power now.
Old Jan 5, 2019 | 08:43 AM
  #65
Thanks @Stclark13 ...the only possible explanation is the OEM pads so happy to hear you took care of the issue. Mine aren't squealing down here in FL so I'm going to hold out until Honda introduces the updated pads and replaced them for free.
Old Jan 5, 2019 | 08:58 AM
  #66
Stclark13's Avatar
The pads were so pitted it was crazy. No joke probably 30+ pits on each pad. For me it was below 35 degrees the made noise but more importantly after a few high speed stops the pads felt like they weren’t there....super scary and kind of crappy for a sporty suv. $50 and about 30 mins of work was well worth it.
Old Jan 5, 2019 | 09:04 AM
  #67
Dereileak's Avatar
that’s good to hear, I figured it was the pads. Question regarding using aftermarket brake pads, are there any warranty issues with that? I would be fine swapping out my pads myself with some high performance ones, the squeeling hasnt been as bad lately but sometimes after sitting it has a few good stops where the squeeling sounds like I’m driving a city bus, then it goes away. Also do you have any pics of the old pads?
Old Jan 5, 2019 | 09:23 AM
  #68
Stclark13's Avatar
I can’t imagine a senario that aftermarket pads would void a brake warranty on anything other than the pads which have a warranty themselves anyway. Acura obviously knows they suck and won’t do anything about it. I refuse to keep going to a dealer and have no car for a day while nothing is actually fixed. I have 4K on my car and there was so much pad left on my stock pads I didn’t even need to retract the caliper piston to put the new ones on so it was a super easy swap. No special tools needed.
  #69
You will have ZERO warranty issues using any aftermarket pad designed for the RDX so no worries there.
Old Jan 5, 2019 | 05:50 PM
  #70
Burger Steak & Eggs's Avatar
The only time I've noticed squealing is early mornings / late fall. There is a layer of condensation on the rotors and a bit of surface rust. The brakes squeal and get extra grabby for the first few stops, then return to normal after the rust profile gets scrubbed off.
Old Jan 6, 2019 | 01:17 AM
  #71
Dizzyg12's Avatar
same - although I Park in a garage so I don’t know about dew. i Get minor squeal backing out and the first stop at the end of the first road and the it’s done.
Old Jan 6, 2019 | 03:22 AM
  #72
skarface's Avatar
So different brake pads fix the problem and Acura is still claiming they are working on it? Sounds about right. Based on this link, it looks like the brake pads have been revised already, so it might be worth going to the dealer and making sure you get the updated pads part number.
https://www.acuraoemparts.com/oem-pa...1hY3VyYQ%3D%3D
  • Part Number:45022-TJB-A01
  • Part:Pad Set, Front
  • Replaces:45022-TJB-A00
Old Jan 6, 2019 | 08:39 AM
  #73
subin's Avatar
Please see post #2, looks like Dereileak's dealer already put in the new pads, but the squeak came back.
Old Jan 6, 2019 | 09:17 AM
  #74
May be best to go aftermarket.
Old Jan 6, 2019 | 01:15 PM
  #75
skarface's Avatar
Yeah, I was saying to make sure you actually get the new part number since it looks like it was updated. The service advisor can write it up to use the new part number that pops up in the computer but the parts department might just finish up their batch of the "front pads for the 2019 RDX" that are the old part number thinking there isn't a difference and that is what the mechanic ends up actually installing.
Or just spend the $50 and try some new aftermarket pads. Just seems annoying to have to change brake pads on a brand new car when it should be a simple fix. I would probably end up just doing it myself if I had a squeak the dealer couldn't fix it after a couple tries. You only lose an hour put them in and popping them out if it doesn't fix the problem.
Old Jan 6, 2019 | 05:56 PM
  #76
Stclark13's Avatar
I agree on a $40k+ car you shouldn’t have to change pads within a few month of purchase but I’ve had my fair share of German cars that will dust so bad your wheels turn black in a week. So I’m used to changing them out pretty quickly.
Old Jan 6, 2019 | 06:51 PM
  #77
tabs31's Avatar
Aren't you supposed to have the rotors cut down when you change out pads?
Old Jan 6, 2019 | 08:17 PM
  #78
Not necessary if the rotors are in good shape, i.e. no grooving etc.
Old Jan 6, 2019 | 09:36 PM
  #79
skarface's Avatar
Well it is a "pad slap" and probably not the "proper" way to do it but if the rotors aren't damage, you probably won't notice any problems. Better than having squealing brakes when you could easily swap pads at home. If different pads actually solve the problem, it would be very disappointing that Acura is taking this long to figure it out. Not sure how anyone could ever defend them in the future regarding other issues when they claim they are working on a solution. Maybe people will have to swap in an aftermarket infotainment system on their own next?
Old Jan 7, 2019 | 09:59 AM
  #80
cagey's Avatar
My brakes have been chronically squealy (2013 RDX) for as long as I can remember. The dealership service dept has not been helpful (though they have confirmed my brakes are safe). Online searches seem to indicate this is a common problem. Highly frustrating, especially considering the cost of this vehicle! I have resigned myself to living with it since it's not a safety issue. I too have been told all the usual things: 1) All brakes squeal; 2) Well, WE can't hear it; 3) Acura is looking into this. Acura has been "looking into this" for years, as that was one of the first things I was told when I brought it up.
Well, I don't know why, but my brakes have been quiet as a mouse for the past 3 days. Two things to note: my battery died a few days ago, and I had to leave my car outside overnight in freezing temps. I only noticed the brakes being quiet after I picked up my car from the battery place, though I wasn't paying attention to how they sounded driving to the battery place. Now, I know this place (primarily a tire shop) also works on brakes, but I can't imagine they would do anything without consulting me first, and if they did, surely they would tell me they fixed a problem. My husband said that maybe the freezing temps did something, but that is just a wild guess. Anyway, I have zero idea why my brakes are now quiet, but I hope hope hope this is not a fluke and that it keeps being quiet. I just want to know HOW.
