2019 RDX advance rattles
Old Oct 24, 2022 | 02:18 PM
r0oki3's Avatar
9th Gear
Anybody else have similar rattles inside the cabin. I know some of them are coming from the hud. But it feels like the interior of the whole car is vibrating when going over roads that has cracks in them or roads that have rumble strip like texture.
https://youtube.com/shorts/twadZcIL8fo
is this normal in RDX? I tried to put foam, took it to the dealer but still can’t figure out where the noise is coming from. Around the bottom of the windshield and passenger door area. Any suggestions on how to isolate the problem?
Old Oct 25, 2022 | 07:32 AM
ELIN's Avatar
I had a "tap tap tap" sound from my 2021 TLX that neither I or the dealer could figure out until recently. It only happened when driving over uneven road (like a manway cover, turning on a slope, etc).
Turns out it was the driver-side seat belt mount hitting against the seat. There's some very small padding there but apparently not enough to mitigate the sound. Try putting something soft there or hold it while driving over uneven ground to see if the noise disappears.
Old Oct 25, 2022 | 08:43 AM
leomio2.0's Avatar
I have a 2020 RDX A-Spec that rattles, creaks & clicks. People on here have berated me for highlighting how poor the interior build quality is on my RDX. I've seen other complaints crop up here and on Reddit. I've resigned to just "dealing" with the fact that build quality is not great on these cars. I've addressed some and fixed them, others still persist.
I still have rattles from various areas of the dash, panoramic sunroof still pops/clicks & rattle from the B-pillar on the driver's side. They're nearly all intermittent but with no consistency in what causes them. Different temperatures, different spots on the same road.
I'll have to wait to see if the lower control arms start rattling this winter when we get sub-freezing temps. Hopefully get those replaced before the warranty expires.
Old Oct 25, 2022 | 09:00 AM
r0oki3's Avatar
9th Gear
i was able to fix couple of rattles myself from the a pillar. One was the clip itself that is used to hold the a pillar cover. I put thin electrical tape on to the clip housing and made a slit with a scissors or a knife for the clip to slide through. Plus put tiny bits of tape around the center where the pointy thing of the clip moves around. That reduced one concern. Another thing was the speaker in the pillar was moving when I knocked around that area. So used some Velcro tape to hold it in place.
I tried stuffing foam in between the hud plastic and the dashboard but that didn’t help. Tried putting foam in between the wooden trim and the dash on the left and right areas but that didn’t help. I understand that the quality isn’t there but it’s just that it’s so bad that these cars shouldn’t even be passing quality control checks. My car is at the dealer right now. Had to beg the service director to do some more of what his dept did, because whatever they did helped to some extent.
Btw, my hud still rattles and if I go on roads with cracks in them, the whole interior of the car jiggles as if nothing is holding it in place.
Old Oct 25, 2022 | 11:22 AM
leomio2.0's Avatar
Yea, I had issues with the A-pillar as well. That's one of the few that were actually fixable.
If I got over a string of fixed potholes (which are common where I live), the dash sometimes sounds like it's rattling apart. It's embarrassing. Honestly, my 2001 Chevy Monte Carlo with 108k miles, which is my daily work beater, has less rattles and is better put together.
Old Oct 26, 2022 | 08:01 PM
Burger Steak & Eggs's Avatar
3G RDX is the rattles champion. I've chased and sorted quite a few myself also, using double sided tape, bits of rubber, bungee cords. The worst one was the square rubber bumpers under the spare tire hatch.
Old Oct 28, 2022 | 11:28 PM
leomio2.0's Avatar
I fixed this by using thin foam sheets with adhesive on one side that's sold at Michael's (craft store).
Old Dec 19, 2022 | 09:55 AM
Jay6's Avatar
3rd Gear
Regarding the HUD rattle. My 2019 did it over sharp bumps at most speeds. I had a strip of soft but firm rubbery felt-like material that I could fold to get the right thickness and wedged it between the HUD unit and the dash. It's wedged pretty tight, only on the left side, and the rattle is gone. Hope this helps.
JustMe65
3G RDX Problems & Fixes
90
Jun 25, 2021 12:30 PM
ARfan395
Oct 13, 2016 05:09 AM
tlrulz
2G RDX Problems & Fixes
Jun 16, 2014 10:39 AM
G35C2STI2RDX
Apr 28, 2013 02:51 PM
calcio22
1G RDX (2007-2012)
Mar 1, 2009 05:08 PM
