Splash Guard - DIY .. anyone?
Old Oct 23, 2018 | 07:18 AM
Coolguy's Avatar
Dealer is asking for 250 (installed) and the same set is available at other dealer for 115. I am tempted to install it myself. Anyone tried it? how was your experience and recommendation ?
Old Oct 23, 2018 | 07:39 AM
subin's Avatar
Should be pretty easy.
http://www.urvi.net/forumfiles/SB/BII07802-10.PDF
Here is the thread
https://acurazine.com/forums/third-g...ctions-969946/
Old Oct 23, 2018 | 08:16 AM
CozZo6's Avatar
6th Gear
I did this last weekend. Only issue was I was short one speed clip but dealer I purchased from had a replacement in the mail in no time.
Old Oct 23, 2018 | 08:43 AM
securityguy's Avatar
One of the easiest things you can install on a car with the proper tools. Save your money and DIY.
Old Oct 23, 2018 | 02:23 PM
Yotrek's Avatar
I thought they all come with splash guard..
Old Oct 23, 2018 | 02:38 PM
Nope. Dealer installed option
Old Oct 23, 2018 | 02:43 PM
EddieN's Avatar
Planning on installing this week, received my set yesterday.
Old Oct 23, 2018 | 03:45 PM
Yotrek's Avatar
Lucky me my A Spec comes with it..
Old Oct 23, 2018 | 06:04 PM
Mine came with it too...dealer installed
Old Oct 24, 2018 | 03:35 AM
Outfitter's Avatar
I installed mine. Fronts a piece of cake, just cock the wheels to gain access. Rears not as easy unless you remove the wheels.
Old Oct 24, 2018 | 11:43 AM
RangersRule99's Avatar
I ended up removing the rear wheels and then it was a breeze...
Old Oct 24, 2018 | 06:06 PM
EFR's Avatar
EFR
Fronts were easy....I didn't even turn the wheels. The backs....as I have no spare, no jack (A-Spec)...took it to the dealer and had to pay $65.
Old Oct 24, 2018 | 07:08 PM
EddieN's Avatar
[QUOTE=EddieN;16318525]Planning on installing this week/QUOTE]
Just finished my install, did the rears first; as stated by others fronts were easy. I did not remove the rear wheels, took a little longer on the first side due to the learning curb but then the other side was easy. Used a stubby Phillips screw driver and a little manipulation of the fabric inner fender. They look great!
Old Oct 29, 2018 | 02:47 PM
Mustachio's Avatar
I'm planning to do this myself once my RDX arrives. For those who are still considering DIY, you may find this 90° drill attachment useful.
Old Oct 31, 2018 | 07:25 PM
mode360's Avatar
I installed mine this evening after I washed the car. It took about 45 mins max. Took off the rear wheels to install them. It took roughly 15-20 mins to do the rear for the first side and less than 10 mins to do the other side. The fronts were easy, 5 mins max for each side.
Old Oct 31, 2018 | 07:29 PM
Coolguy's Avatar
good job done.. btw.. your ride looks awesome
Old Nov 13, 2018 | 12:36 PM
subin's Avatar
Just finished mine. The rear ones are difficult to do without taking off the wheels. It is not easy to align the screws to the spring nuts, even with the stubby screw driver. It took me 30 minutes each side.
Tips for the rear ones (if you are not removing the wheels):
- For the one spring nut (each side) that is vertical to the ground, you may need to close the gap a little, so that it would stay on the installed location.
- Before you install the brackets, just put the screws on through the spring nuts first and back them out. It is easier to align the holes on the bracket to the spring nuts this way.
Old Nov 19, 2018 | 01:35 AM
csj0952's Avatar
Chris
I'm wondering a couple of questions about this:
1) Why did you guys want splash guards? Are they to keep salt and debris from hitting your paint on the sides? what are you protecting do you think by putting them on?
2) Where can I order just the part without installation? Do they sell on ebay or somewhere online?
Old Nov 20, 2018 | 01:51 PM
Dizzyg12's Avatar
Geez got a quote from my local acura dealer $145 just for parts. That’s insane isn’t it?
Old Nov 20, 2018 | 02:00 PM
EFR's Avatar
EFR
Pretty much almost pays to buy online either from ebay or other acura dealers that aggressively sell online and at much better prices....curryacura is one of several. They sell some things on ebay and others online through their store. Even the extended warranty is much cheaper. I got two price quotes online then went to the local Acura dealer with printouts in hand. They wanted a LOT more for the D80 plan that I had quotes for, but then they matched the best price. Presently I am getting running boards and heated steering wheel installed and saved several hundred dollars by buying online and having the dealer install. Some things you can install yourself, others not so much. Acura makes great install instructions but the amount of work it takes is a bit unnerving sometimes. Depends on your skill level and...bravery.
Old Nov 20, 2018 | 03:11 PM
Buy online and install yourself. Super cheap and easy.
Old Dec 3, 2018 | 09:44 AM
Coolguy's Avatar
Finally got time to install splash guards last night. Front was super easy but rear was bit difficult. Main issue was aligning all 4 holes to screw - specially lower holes.
But it was worth saving 100+
Old Dec 3, 2018 | 01:59 PM
i69fstop's Avatar
I bought online for full set, and did it myself aroudn 45-60 mins, the rear take more time since it come with 2 parts. Just follow pdf instruction above.
Old Dec 3, 2018 | 03:30 PM
ULEWZ's Avatar
This should be my first mod, after the trailer hitch. Thanks for posting. Oh, My A-spec did not come with splash guards!!
Old Dec 4, 2018 | 01:07 PM
Mustachio's Avatar
I installed mine a couple weeks ago. Fronts were easy. Rears were a pain with the wheel mounted. I couldn't get one of the screws installed, so I plan to remove the wheel finish it up soon.
Old Dec 4, 2018 | 06:25 PM
Coolguy's Avatar
Get right angle adapter https://www.homedepot.com/p/DEWALT-R...B&gclsrc=aw.ds
It makes life very easy
Old Dec 6, 2018 | 01:34 AM
akahimaro's Avatar
8th Gear
question about the rear
Can anyone take some pictures as a guide for me? I'm struggling to install the two in the back,
Is that behind the fender? i did look under my car and saw something like that but not really sure how i would take that off and replace the spring nut
Old Dec 7, 2018 | 08:10 AM
subin's Avatar
You would need to push the felt like cover toward the car to reveal it.
Old Dec 7, 2018 | 09:09 AM
Coolguy's Avatar
Push black rough fender to expose the metal part .. its right behind fender. Also, you don't need to install 2, just one in the middle.
markk2
Mar 8, 2013 10:58 AM
drdug27
Nov 11, 2007 11:21 PM
chocodai
1G TSX Photograph Gallery
37
Feb 6, 2006 05:06 PM
Santa Rosa Steve
Nov 30, 2004 05:08 PM
chocodai
Nov 20, 2003 11:07 PM
