Contact Alarm for Security?
Old Oct 26, 2019 | 10:11 PM
samantha.winslow's Avatar
5th Gear
Hi, I’m wondering if there’s a way to set my car so that if someone pulls the drivers side door handle and the fob is NOT present, the alarm will go off. For example, in the middle of the night some kids will go through my neighborhood and just pull on car door handles to see if anyone left their cars unlocked so they can steal stuff...Is there a way to set my car so that the alarm will sound when they pull my driver’s side door? Like a contact sensor?
If not, does anyone have suggestions for me?
Obviously I lock my car every time but it’d be nice to scare the bad guys away.
Old Oct 27, 2019 | 07:17 AM
kboo74656's Avatar
There is no setting for that. Place your car in a garage if you have one.
Old Oct 27, 2019 | 09:01 AM
5th Gear
Shame
Thats a shame...I feel like at this point there should be something like that or at least an add on.
I don’t have a garage or it would definitely be in there...obviously?
Old Oct 27, 2019 | 09:07 AM
kboo74656's Avatar
Do you have the option of placing a camera to overlook your car and record?
Old Oct 27, 2019 | 04:45 PM
Dereileak's Avatar
I’m sure the door handle has some physical switch, you can always do an aftermarket alarm and use that as a trigger wire also
Old Oct 28, 2019 | 04:41 AM
Cuzz's Avatar
If pulling on the door handle turns on the internal lighting, then an aftermarket alarm that senses current drain will work well.
Old Oct 28, 2019 | 10:24 AM
beancount1's Avatar
I have the ring video doorbell. I receive an alert on my iphone anytime there's movement in my front yard and driveway. You can set the phone for banner and/or audio alert if it detects movement. That would work while you're home.
Old Oct 28, 2019 | 11:00 AM
Wire in a tilt sensor to your car
https://acurazine.com/forums/third-g...-alarm-855658/ obviously, you'll have to get it to work with your specific model but here's a DIY you can loosely follow.
madehtsobi
Jun 19, 2005 03:21 PM
tcp100
May 22, 2005 11:31 PM
fusionnv
Sep 22, 2004 10:11 AM
Frank92si
Apr 16, 2003 04:32 PM
NYCCL3.0
Dec 8, 2001 02:03 AM
