VSA/ABS Troubleshooting
Old Nov 21, 2024 | 11:48 AM
schubbydoo's Avatar
Hi,
I was not sure if I should start a new thread or pile on. Here's my situation. Yesterday, I made a quick turn and accelerated and the VSA error message came on. Coincidently the ABS errors as well. The car doesn't seem to perform any differently but admittedly, I didn't test the brakes to see if the ABS was actually working or not. I took it to the dealership and they quoted me a $5500 repair cost to replace the VSA module ($4500) with a brake bleed. I almost fell out of my chair when they told me. I've seen some recommendations on checking the performance of the brakes and that's what I'll do after I retrieve the car. I've also done some searches for the part (57110-TL2-S01) that they propose to replace and the pricing is less to much less. Before throwing more $$ at the problem, I wanted to know what you would recommend that I do next and if purchasing a part is what I should do, where would you recommend I look that is reputable.
Car Info:
Acura TSX 2010
OD: 56,346
Error codes:
81-1 Modulator-control unit internal circuit malfunction
122-1 VSA Solenoid valve malfunction
121-1 VSA Solenoid valve malfunction
18-1 Left-rear wheel speed sensor signal malfunction
16-1 Right-rear wheel speed sensor signal malfunction
Thank you,
Steve
Fr3shAcuraTL
May 25, 2019 07:44 AM
Katyvg81
1G TSX Problems & Fixes
Jan 14, 2015 03:38 PM
whitetls02
4G TL Problems & Fixes
Jan 29, 2014 10:59 PM
I hate cars
Jul 31, 2009 05:11 PM
SFzip
Jan 4, 2004 05:29 PM
